snackpak
Re: How to install/ build/ play Quake 3....
Sun Oct 23, 2016 3:25 pm
PhillPi wrote:Hi. I have followed your instructions before and it worked a treat (thanks). This time I am installing on RPI3 Raspbian Pixels released on 23rd September 16 and I get an error:
UI_CC_MISSIONPACK code/game/bg_lib.c
LD build/release-linux-arm/ioq3ded.arm
/usr/bin/ld: cannot find -lvmcs_rpc_client
collect2: error: ld returned 1 exit status
Makefile:1657: recipe for target 'build/release-linux-arm/ioq3ded.arm' failed
make[2]: *** [build/release-linux-arm/ioq3ded.arm] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/home/pi/quake3'
Makefile:981: recipe for target 'targets' failed
make[1]: *** [targets] Error 2
make[1]: Leaving directory '/home/pi/quake3'
Makefile:975: recipe for target 'release' failed
make: *** [release] Error 2
[email protected]:~/quake3 $
I have tried this loads of times and even with other tutorials and I still get the same error.
Can you help me please?
PhillPi
Edit build.sh and remove -lvmcs_rpc_client from line 31
PhillPi
Tue Oct 25, 2016 9:27 pm
Thanks snackpak. I removed the text from that line, saved and re-ran the compilation process, now it ends with...
make[2]: *** [build/release-linux-arm/baseq3/qagamearm.so] Error 1
/usr/bin/ld: cannot find -lvchostif
/usr/bin/ld: cannot find -lvcfiled_check
/usr/bin/ld: cannot find -lbcm_host
/usr/bin/ld: cannot find -lkhrn_static
/usr/bin/ld: cannot find -lvchiq_arm
/usr/bin/ld: cannot find -lopenmaxil
/usr/bin/ld: cannot find -lEGL
/usr/bin/ld: cannot find -lGLESv2
/usr/bin/ld: cannot find -lvcos
Makefile:1517: recipe for target 'build/release-linux-arm/ioquake3.arm' failed
make[2]: *** [build/release-linux-arm/ioquake3.arm] Error 1
make[2]: Leaving directory '/home/pi/src/quake3'
make[1]: Leaving directory '/home/pi/src/quake3'
[email protected]:~/src/quake3 $
It send I am missing something from /usr/bin/ld
I am afraid I have no idea what this means. Any help is greatly appreciated.
ChrisAU
Sat Nov 05, 2016 10:02 am
Hi Chaps,
I set about trying to solve this and ended up writing a whole guide...
Link: http://www.lowefamily.com.au/2016/11/05 ... pberry-pi/
Shortlink: http://wp.me/p6g71G-29e
The short answer is that you just needed to remove the -lvmcs_rpc_client from build_rpi_raspbian.sh - so you were already doing the right thing, but not sure why you got the next error.
Anyway, have a read of my guide if you are still having problems.
Kind Regards,
Chris. :)
Rploesser
Sun Nov 06, 2016 5:36 am
Once installed how well does Quake 3 run?
www.Helixduo.com / Twitter @HelixDuoSystems / facebook.com/Helixduo - where the DNA of old and new come together for a truly unique gaming experience
PrettyCoolBruh
Sun Nov 27, 2016 11:36 pm
Rploesser wrote:Once installed how well does Quake 3 run?
Depends on your Raspberry Pi. Can only confirm no lag on Pi 3
People who think they know everything are a great annoyance to those of us who do
tryco2
Tue Jan 03, 2017 11:58 pm
my Pi2 quake install was a success, required building like the rest, but a bit long:
The build:
run first!
sudo apt-get update
update all distros and packs
sudo apt-get dist-upgrade
then update the raspbian os
sudo rpi-update
reboot
sdl1.2-dev is bugged. use this:
sudo apt-get install git gcc build-essential libsdl2-2.0-0
then follow this forum's guide for steps 2 through the end of 3, you may or may not need to sudo this codelist.
git clone https://github.com/raspberrypi/quake3.git
cd quake3
nano build.sh
change arm_libs (line 8) values to:
ARM_LIBS=/opt/vc/lib
do the same to includes/pthreads (line 16) values:
INCLUDES="-I/opt/vc/include -I/opt/vc/include/interface/vcos/pthreads"
remark out bcm now that we deleted it from all the other places (line19):
#CROSS_COMPILE=bcm2708-
now for the one that THIS site wont tell you, but will bork your compile for both the pi 2 and 3:
Control+O to save, Control+X to exit
then do the same to build_rpi_raspbian.sh
nano build_rpi_raspbian.sh
locate and remove the -lvmcs_rpc_client entry
Now you can begin the compilation process by typing
./build.sh
you may need to sudo it. the process takes approximately 30 minutes (yes, it really does,take about 20-30 min).
The file copy:
you will then need pak0(off of ORIGINAL CD), all patch data from https://ioquake3.org/extras/patch-data/, you can choose to get
http://ioquake3.org/files/xcsv_hires.zip for high res texture packs,and any additional pk3's you have. then after copying all this into build/release-linux-arm/baseq3 and missionpack, using
sudo pcmanfm
move release-linux-arm folder to root of pi(home dir). rename it to quake3
First run:
cd into quake 3 folder, run ioquake3.arm
can skip cdkey(or enter one)
when at main menu, quit
copy in your seperate q3config and q3 keys for baseq3 and missionpak from the pc game folders to respective /home/pi/quake3 folders, overwriting everything if prompted.
goto .q3a
copy in the data from C:\Users\(yourusername)\AppData\Roaming\Quake3 to this location (.q3a), overwriting everything
then now update ur quake3 folder permissions for directFB access:
from console, run
sudo usermod -a -G video [your_username]
(default username is pi in this case)
logout, log backin.
log back in and cd to quake3 and run ioquake to confirm your settings and cdkey have been transferred. now is a good chance to set the res to widescreen. the pi's, while physically capable of running 1600x900, lag bad, and are happer at the native 856x480 res. very gamable
Desktop icon:
Now its time to create the desktop icon:
locate a quake3 png (256x256), save it to your pi somewhere
create a new empty file on the desktop
open in text editor and type this (image name changeable, but must be a direct path):
[Desktop Entry]
Type=Application
Name=ioQuake III Arena
Icon=/home/pi/img/Image.png
Exec=/home/pi/quake3/ioquake3.arm
Path=/home/pi/quake3/
Terminal-false
Name[en_US]=ioQuake III Arena x86
GenericName=Quake III Arena
save this.
should now have a new shortcut to the game, and a fully unlocked game with all your maps and games.
Done!
This build process is identical for 2 and 3, only difference is 2 is x86 and 3 is x64.
enjoy!
ICantThinkOfAUsrName
Wed Feb 01, 2017 10:23 am
I have a question, do I need to unzip the pak files?
victagayun
Sat Mar 04, 2017 3:08 pm
Quick question, can I play network with a PC from raspi?
hollipl
Tue Mar 28, 2017 8:54 am
This failed for me, as did EVERY other quake 3 compiling tutorial I have followed online. I feel like flinging the pi out the door and into the trash.... Way frustrating to try something 30 times to watch it fail.
Doubt this stupid board could compile a picture of a dog turd.
CSpr3itz3r
Tue Oct 31, 2017 10:39 pm
Hi! Thanks for taking the time to do all this. I got it working. However I was wanting to use an Xbox 360 (wired) controller and was wondering how this could be done. Is key mapping automatic? If not how can I input them? Thanks!
Mitchell13
Thu Nov 02, 2017 1:04 pm
Can you update the link http://dl.dropbox.com/u/1816557/Q3%20Demo%20Paks.zip please? I get the error 404. And i realy want to make this work.
Thank you! :D
alutov
Mon Dec 04, 2017 3:25 am
When I compile quake3 on raspberry pi3 raspbian stretch I get an error "missing libEGL.so". To solve problem I advise to use keys " -lbrcmEGL -lbrcmGLESv2" instead of "-lEGL -lGLESv2" in file build.sh.
ptitSeb
Tue Dec 05, 2017 2:56 pm
If someone want to try, I added some RPi support to my fork of OpenArena: https://github.com/ptitSeb/OpenArenaPandora.git
After cloning the repo, a simple
make RPI=1
should build the game.
cdev-tux
Sat Dec 09, 2017 3:08 am
The version of ioquake3 that’s in the repository is an older version based on SDL1.2, and it’s missing many features and bug/security fixes. I made available an updated version that’s based on the latest ioquake3 codebase as well as SDL2. Please feel free to try it out.
viewtopic.php?f=78&t=198680
cdev-tux
Q3lite source code: https://github.com/cdev-tux/q3lite
Documentation, game FAQ and Compiling/Installation Guide: https://github.com/cdev-tux/q3lite/wiki
ptitSeb
Mon Dec 11, 2017 9:40 am
Yeah, I've checked your repo, and it's a nice up-to-date version with all ARM/GLES bits gathered.
Nice work!
cdev-tux
Mon Dec 11, 2017 8:41 pm
Nice work!
Much appreciated. It’s based on some of your excellent previous work, thank you!
cdev-tux
forj1900
Fri Feb 23, 2018 2:34 pm
When I run
sudo ioquake3.arm
I get
ioquake3.arm: command not found
What's wrong? I can see from ls command than file ioquake3.arm is exist.
Thanks in advance
Zarnir
Tue Mar 20, 2018 11:15 pm
The guide works fine until I start the compilation process. This is the code that pops up every time I attempt to do it.
make[1]: Entering directory '/home/pi/quake3'
Building ioquake3 in build/release-linux-arm:
PLATFORM: linux
ARCH: arm
VERSION: 1.35
COMPILE_PLATFORM: linux
COMPILE_ARCH: armv7l
CC: gcc
CFLAGS:
-DVCMODS_MISC
-DVCMODS_OPENGLES
-DVCMODS_DEPTH
-DVCMODS_REPLACETRIG
-I/opt/vc/include
-MMD
-Wall
-fno-strict-aliasing
-Wimplicit
-Wstrict-prototypes
-pipe
-DUSE_ICON
-I/usr/include/SDL
-D_GNU_SOURCE=1
-D_REENTRANT
-DNO_VM_COMPILED
-Icode/SDL12/include
-DUSE_MUMBLE
-DUSE_VOIP
-DFLOATING_POINT
-DUSE_ALLOCA
-Icode/libspeex/include
-DUSE_LOCAL_HEADERS
-DPRODUCT_VERSION="1.35"
-DNDEBUG
-O3
-ffast-math
-funroll-loops
-fomit-frame-pointer
LDFLAGS:
-L/opt/vc/lib
-Llib
-lSDL
-lvchostif
-lvcfiled_check
-lbcm_host
-lkhrn_static
-lvchiq_arm
-lopenmaxil
-lEGL
-lGLESv2
-lvcos
-lrt
LIBS:
-ldl
-lm
Output:
build/release-linux-arm/baseq3/cgamearm.so
build/release-linux-arm/baseq3/uiarm.so
build/release-linux-arm/missionpack/cgamearm.so
build/release-linux-arm/missionpack/qagamearm.so
build/release-linux-arm/missionpack/uiarm.so
make[2]: Entering directory '/home/pi/quake3'
LD build/release-linux-arm/ioquake3.arm
LD build/release-linux-arm/baseq3/cgamearm.so
build/release-linux-arm/ded/common.o: file not recognized: File truncated
LD build/release-linux-arm/baseq3/qagamearm.so
Makefile:1697: recipe for target 'build/release-linux-arm/baseq3/cgamearm.so' failed
make[2]: *** [build/release-linux-arm/baseq3/cgamearm.so] Error 1
Makefile:1794: recipe for target 'build/release-linux-arm/baseq3/qagamearm.so' failed
Any help would be greatly appreciated.
yfpiLiker
Sat Mar 24, 2018 7:52 am
If try to download the dropboxfile I get this error:
20: Die Anzahl der Verweise ist zu groß.
Can anyone tell me what to do?
Not English. But Pythish.
yfpiLiker
Sun Mar 25, 2018 6:51 am
Thank you! :D
Sorry for my last post!
I have the same problem like Mitchell13.
Thank you in advance! :)
darkbibble
Thu Aug 09, 2018 5:35 pm
i have tryed following the last guide abouve to build and install quake 3 but it keeps failing.
here is my error output
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
lolli
Fri Nov 02, 2018 10:43 am
Im having troubles downloading files from dropbox. I got the 404 cannot find the page youŕe looking for.
is there another way to share files?
Thanks for help!!! :P
agasilov
Sun Nov 04, 2018 3:13 am
I have the following issue when I do these instructions:
Then it just goes to the prompt, and I can't run the game. This happens after doing ./build.sh. Please help. Thank you.
Return to “Gaming”
