mikeandlauren
Emulated Wemo Triggering Relay
Sat Jul 15, 2017 7:54 pm
I'm in way over my head, but I've been able piece together almost exactly what I'm looking for, with one exception.
The project:
I make YouTube videos in my workshop. When I want to record I have to turn off the music, turn off the fans and dust collection, then press record. I want to have an echo dot that I can say "Turn on the recording" and it shuts everything off and triggers the shutter on my camera.
The problem:
I have everything working except triggering the shutter on my camera. I've taken apart an IR remote and now when I close the connection on the relay it starts recording, however it doesn't stop sending the IR signal. I need relay #3 (GPIO 4) to flash once for .5 seconds.
I've slightly modified the fauxmo script to suit my needs, I just can't figure out this simple hurdle. How can I control a single GPIO differently (On then Off in .5 sec) when the rest are in an alexa group to either all turn off, or all turn on?
Any help would be appreciated. I can make a quick demo video if I wasn't clear.
This is the section I've been modifying:
class gpio_handler(object):
    def __init__(self, pin_number):
        self.pin = pin_number
        GPIO.setmode(GPIO.BCM)
        GPIO.setup(self.pin, GPIO.OUT)
    def on(self):
        GPIO.output(self.pin, 0)
        return True
    def off(self):
        GPIO.output(self.pin, 1)
        return True
# Each entry is a list with the following elements:
# name of the virtual switch
# object with 'on' and 'off' methods
# port # (optional; may be omitted)
# NOTE: As of 2015-08-17, the Echo appears to have a hard-coded limit of
# 16 switches it can control. Only the first 16 elements of the FAUXMOS
# list will be used.
FAUXMOS = [
    # use GPIO pin 11 to trigger a relay
	['The Fan', gpio_handler(2)],
	['The Speaker', gpio_handler(3)],
	['The Camera', gpio_handler(4)],
if len(sys.argv) > 1 and sys.argv[1] == '-d':
    DEBUG = True
This is the entire script:
#!/usr/bin/env python
The MIT License (MIT)
Copyright (c) 2015 Maker Musings
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files (the "Software"), to deal
in the Software without restriction, including without limitation the rights
to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in
all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
THE SOFTWARE.
# For a complete discussion, see http://www.makermusings.com
import email.utils
import requests
import select
import socket
import struct
import sys
import time
import urllib
import uuid
import RPi.GPIO as GPIO
# This XML is the minimum needed to define one of our virtual switches
# to the Amazon Echo
SETUP_XML = """<?xml version="1.0"?>
<root>
  <device>
    <deviceType>urn:MakerMusings:device:controllee:1</deviceType>
    <friendlyName>%(device_name)s</friendlyName>
    <manufacturer>Belkin International Inc.</manufacturer>
    <modelName>Emulated Socket</modelName>
    <modelNumber>3.1415</modelNumber>
    <UDN>uuid:Socket-1_0-%(device_serial)s</UDN>
  </device>
</root>
DEBUG = False
def dbg(msg):
    global DEBUG
    if DEBUG:
        print msg
        sys.stdout.flush()
# A simple utility class to wait for incoming data to be
# ready on a socket.
class poller:
    def __init__(self):
        if 'poll' in dir(select):
            self.use_poll = True
            self.poller = select.poll()
        else:
            self.use_poll = False
        self.targets = {}
    def add(self, target, fileno = None):
        if not fileno:
            fileno = target.fileno()
        if self.use_poll:
            self.poller.register(fileno, select.POLLIN)
        self.targets[fileno] = target
    def remove(self, target, fileno = None):
        if not fileno:
        if self.use_poll:
            self.poller.unregister(fileno)
        del(self.targets[fileno])
    def poll(self, timeout = 0):
        if self.use_poll:
            ready = self.poller.poll(timeout)
        else:
            ready = []
            if len(self.targets) > 0:
                (rlist, wlist, xlist) = select.select(self.targets.keys(), [], [], timeout)
                ready = [(x, None) for x in rlist]
        for one_ready in ready:
            target = self.targets.get(one_ready[0], None)
            if target:
                target.do_read(one_ready[0])
# Base class for a generic UPnP device. This is far from complete
# but it supports either specified or automatic IP address and port
# selection.
class upnp_device(object):
    this_host_ip = None
    @staticmethod
    def local_ip_address():
        if not upnp_device.this_host_ip:
            temp_socket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
            try:
                temp_socket.connect(('8.8.8.8', 53))
                upnp_device.this_host_ip = temp_socket.getsockname()[0]
            except:
                upnp_device.this_host_ip = '127.0.0.1'
            del(temp_socket)
            dbg("got local address of %s" % upnp_device.this_host_ip)
        return upnp_device.this_host_ip
    def __init__(self, listener, poller, port, root_url, server_version, persistent_uuid, other_headers = None, ip_address = None):
        self.listener = listener
        self.poller = poller
        self.port = port
        self.root_url = root_url
        self.server_version = server_version
        self.persistent_uuid = persistent_uuid
        self.uuid = uuid.uuid4()
        self.other_headers = other_headers
        if ip_address:
            self.ip_address = ip_address
        else:
            self.ip_address = upnp_device.local_ip_address()
        self.socket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
        self.socket.bind((self.ip_address, self.port))
        self.socket.listen(5)
        if self.port == 0:
            self.port = self.socket.getsockname()[1]
        self.poller.add(self)
        self.client_sockets = {}
        self.listener.add_device(self)
    def fileno(self):
        return self.socket.fileno()
    def do_read(self, fileno):
        if fileno == self.socket.fileno():
            (client_socket, client_address) = self.socket.accept()
            self.poller.add(self, client_socket.fileno())
            self.client_sockets[client_socket.fileno()] = client_socket
        else:
            data, sender = self.client_sockets[fileno].recvfrom(4096)
            if not data:
                self.poller.remove(self, fileno)
                del(self.client_sockets[fileno])
            else:
                self.handle_request(data, sender, self.client_sockets[fileno])
    def handle_request(self, data, sender, socket):
        pass
    def get_name(self):
        return "unknown"
    def respond_to_search(self, destination, search_target):
        dbg("Responding to search for %s" % self.get_name())
        date_str = email.utils.formatdate(timeval=None, localtime=False, usegmt=True)
        location_url = self.root_url % {'ip_address' : self.ip_address, 'port' : self.port}
        message = ("HTTP/1.1 200 OK\r\n"
                  "CACHE-CONTROL: max-age=86400\r\n"
                  "DATE: %s\r\n"
                  "EXT:\r\n"
                  "LOCATION: %s\r\n"
                  "OPT: \"http://schemas.upnp.org/upnp/1/0/\"; ns=01\r\n"
                  "01-NLS: %s\r\n"
                  "SERVER: %s\r\n"
                  "ST: %s\r\n"
                  "USN: uuid:%s::%s\r\n" % (date_str, location_url, self.uuid, self.server_version, search_target, self.persistent_uuid, search_target))
        if self.other_headers:
            for header in self.other_headers:
                message += "%s\r\n" % header
        message += "\r\n"
        temp_socket.sendto(message, destination)
# This subclass does the bulk of the work to mimic a WeMo switch on the network.
class fauxmo(upnp_device):
    @staticmethod
    def make_uuid(name):
        return ''.join(["%x" % sum([ord(c) for c in name])] + ["%x" % ord(c) for c in "%sfauxmo!" % name])[:14]
    def __init__(self, name, listener, poller, ip_address, port, action_handler = None):
        self.serial = self.make_uuid(name)
        self.name = name
        persistent_uuid = "Socket-1_0-" + self.serial
        other_headers = ['X-User-Agent: redsonic']
        upnp_device.__init__(self, listener, poller, port, "http://%(ip_address)s:%(port)s/setup.xml", "Unspecified, UPnP/1.0, Unspecified", persistent_uuid, other_headers=other_headers, ip_address=ip_address)
        if action_handler:
            self.action_handler = action_handler
        else:
            self.action_handler = self
        dbg("FauxMo device '%s' ready on %s:%s" % (self.name, self.ip_address, self.port))
    def get_name(self):
        return self.name
        if data.find('GET /setup.xml HTTP/1.1') == 0:
            dbg("Responding to setup.xml for %s" % self.name)
            xml = SETUP_XML % {'device_name' : self.name, 'device_serial' : self.serial}
                       "CONTENT-LENGTH: %d\r\n"
                       "CONTENT-TYPE: text/xml\r\n"
                       "DATE: %s\r\n"
                       "LAST-MODIFIED: Sat, 01 Jan 2000 00:01:15 GMT\r\n"
                       "SERVER: Unspecified, UPnP/1.0, Unspecified\r\n"
                       "X-User-Agent: redsonic\r\n"
                       "CONNECTION: close\r\n"
                       "\r\n"
                       "%s" % (len(xml), date_str, xml))
            socket.send(message)
        elif data.find('SOAPACTION: "urn:Belkin:service:basicevent:1#SetBinaryState"') != -1:
            success = False
            if data.find('<BinaryState>1</BinaryState>') != -1:
                # on
                dbg("Responding to ON for %s" % self.name)
                success = self.action_handler.on()
            elif data.find('<BinaryState>0</BinaryState>') != -1:
                # off
                dbg("Responding to OFF for %s" % self.name)
                success = self.action_handler.off()
            else:
                dbg("Unknown Binary State request:")
                dbg(data)
            if success:
                # The echo is happy with the 200 status code and doesn't
                # appear to care about the SOAP response body
                soap = ""
                           "CONTENT-TYPE: text/xml charset=\"utf-8\"\r\n"
                           "DATE: %s\r\n"
                           "EXT:\r\n"
                           "\r\n"
                           "%s" % (len(soap), date_str, soap))
        else:
            dbg(data)
    def on(self):
        return False
    def off(self):
        return True
# Since we have a single process managing several virtual UPnP devices,
# we only need a single listener for UPnP broadcasts. When a matching
# search is received, it causes each device instance to respond.
# Note that this is currently hard-coded to recognize only the search
# from the Amazon Echo for WeMo devices. In particular, it does not
# support the more common root device general search. The Echo
# doesn't search for root devices.
class upnp_broadcast_responder(object):
    TIMEOUT = 0
    def __init__(self):
        self.devices = []
    def init_socket(self):
        ok = True
        self.ip = '239.255.255.250'
        self.port = 1900
        try:
            #This is needed to join a multicast group
            self.mreq = struct.pack("4sl",socket.inet_aton(self.ip),socket.INADDR_ANY)
            #Set up server socket
            self.ssock = socket.socket(socket.AF_INET,socket.SOCK_DGRAM,socket.IPPROTO_UDP)
            self.ssock.setsockopt(socket.SOL_SOCKET,socket.SO_REUSEADDR,1)
            try:
                self.ssock.bind(('',self.port))
            except Exception, e:
                dbg("WARNING: Failed to bind %s:%d: %s" , (self.ip,self.port,e))
                ok = False
            try:
                self.ssock.setsockopt(socket.IPPROTO_IP,socket.IP_ADD_MEMBERSHIP,self.mreq)
                dbg('WARNING: Failed to join multicast group:',e)
                ok = False
            dbg("Failed to initialize UPnP sockets:",e)
            return False
        if ok:
            dbg("Listening for UPnP broadcasts")
    def fileno(self):
        return self.ssock.fileno()
        data, sender = self.recvfrom(1024)
        if data:
            if data.find('M-SEARCH') == 0 and data.find('urn:Belkin:device:**') != -1:
                for device in self.devices:
                    time.sleep(0.1)
                    device.respond_to_search(sender, 'urn:Belkin:device:**')
            else:
                pass
    #Receive network data
    def recvfrom(self,size):
        if self.TIMEOUT:
            self.ssock.setblocking(0)
            ready = select.select([self.ssock], [], [], self.TIMEOUT)[0]
        else:
            self.ssock.setblocking(1)
            ready = True
        try:
            if ready:
                return self.ssock.recvfrom(size)
            else:
                return False, False
            dbg(e)
            return False, False
    def add_device(self, device):
        self.devices.append(device)
        dbg("UPnP broadcast listener: new device registered")
# This is an example handler class. The fauxmo class expects handlers to be
# instances of objects that have on() and off() methods that return True
# on success and False otherwise.
# This example class takes two full URLs that should be requested when an on
# and off command are invoked respectively. It ignores any return data.
class rest_api_handler(object):
    def __init__(self, on_cmd, off_cmd):
        self.on_cmd = on_cmd
        self.off_cmd = off_cmd
    def on(self):
        r = requests.get(self.on_cmd)
        return r.status_code == 200
    def off(self):
        r = requests.get(self.off_cmd)
    def on(self):
        return True
    def off(self):
        return True
FAUXMOS = [
    DEBUG = True
# Set up our singleton for polling the sockets for data ready
p = poller()
# Set up our singleton listener for UPnP broadcasts
u = upnp_broadcast_responder()
u.init_socket()
# Add the UPnP broadcast listener to the poller so we can respond
# when a broadcast is received.
p.add(u)
# Create our FauxMo virtual switch devices
for one_faux in FAUXMOS:
    if len(one_faux) == 2:
        # a fixed port wasn't specified, use a dynamic one
        one_faux.append(0)
    switch = fauxmo(one_faux[0], u, p, None, one_faux[2], action_handler = one_faux[1])
dbg("Entering main loop\n")
try:
    while True:
        try:
        # Allow time for a ctrl-c to stop the process
            p.poll(100)
            time.sleep(0.1)
            dbg(e)
            break
finally:
    GPIO.cleanup()
Return to “Advanced users”
