Quincy
How to set up the Raspberry Pi 3 without a monitor
Sat Jul 15, 2017 7:22 pm
Hello, I do not have a monitor, and recently purchased the Pi 3. I was wondering if I could set it up with out one on a mac. Thanks so much! :D
Re: How to set up the Raspberry Pi 3 without a monitor
Sun Jul 16, 2017 9:03 am
Quincy wrote:Hello, I do not have a monitor, and recently purchased the Pi 3. I was wondering if I could set it up with out one on a mac. Thanks so much! :D
If your Mac is running x86-64 OS X / macOS you can use Etcher to create a Raspbian Jessie with Desktop SD Card (Etcher both unzips and 'burns' image), you will need a SDHC compliant Internal or USB Card Reader:
https://etcher.io/
You will need to enable SSH by following instructions here:
https://www.raspberrypi.org/blog/a-secu ... ian-pixel/
Presuming your Mac is connected to your Router by Wireless and the Raspberry Pi by Ethernet Cable, you need to set up Connection Sharing:
https://support.apple.com/kb/PH18704
Pop the SD Card in the Raspberry Pi and apply power, you should be able to SSH into the Raspberry Pi from the Terminal !
