sbaratheon
Cannot uninstall package
Sun Sep 30, 2012 10:53 am
Hi everyone,
I'm trying to uninstall a package I installed via apt. I've tried "apt-get remove [package name]" but I get "dpkg was interrupted you must manually run sudo dpkg --configure -a" but this says that there is no space left on the device.
Any help would be great.
stevepdp
Re: Cannot uninstall package
Sun Sep 30, 2012 11:35 am
You can look at your disk usage by using the command:
df -h
An easy way to free up some space:
sudo apt-get clean
That will remove package cache which can be quite weighty if you've been running lots of installs and upgrades.
Run df -h again to see how much space you've freed up, and if it looks good then attempt the dpkg command again.
Let us know how you get on.
sbaratheon
Sun Sep 30, 2012 11:52 am
Ah, I've got more space now and successfully ran "dpkg -- configure -a" but "sudo apt-get remove [packge]" said the package didn't exist.
Running "dpkg -s hplip [package]" came out with:
Package: hplip
Status: install ok not-installed
Priority: optional
Section: utils
Architecture: armhf
Return to “Beginners”
