lerner
MQTT - stuck.
Fri Jul 14, 2017 3:27 am
Hi folks,
"I'm ba-ack!"....
My MQTT interest has again been spiked and I am doing some reading on getting it working,
Alas, not all good news.
I can get it to talk "locally" but it falls over when I wan to talk machine to machine.
I also shall say that I may have had an "older" version of MQTT but after reading I found a link to the CORRECT version - or so I believe.
As the thread is OLD, I am asking anew.
But this is the cux of it:
(No offence Dougie)
viewtopic.php?p=1072534#p1072534
by DougieLawson » Mon Nov 09, 2015 11:33 pm
Nope. It's because you mosquitto server is not listening on the inaddr-any address.
Take a look at your mosquitto.conf, is there a "listener" line in there? Change
listener 1883 127.0.0.1
to
listener 1883
Um......... There is no line in /etc/mosquitto/mosquitto.conf that says that.
I used the walk through from:
http://mosquitto.org/2013/01/mosquitto- ... epository/
which was referenced in the above thread.
But all the "examples" given /that I find are for LOCAL stuff.
They don't go into the "between two separate machines" scenario.
On the one machine I get the messages sent through, but if I try from Machine 1 to Machine 2, it says
mosquitto_pub -d -t test -m "Test"
Error: Connection refused
Yeah, right..... And I can't see how to get around that.
Thanks in advance.
pieuser
Re: MQTT - stuck.
Fri Jul 14, 2017 6:35 am
i have installed geany in raspbian and its working fine. but when i try to install mqtt mosquito its successfully installed but its not connecting in server to client and vice versa. is raspbian is not sufficient for mqtt and iot.
rpdom
Re: MQTT - stuck.
Fri Jul 14, 2017 6:41 am
pieuser wrote:i have installed geany in raspbian and its working fine. but when i try to install mqtt mosquito its successfully installed but its not connecting in server to client and vice versa. is raspbian is not sufficient for mqtt and iot.
Please don't hijack unrelated posts.
pieuser
Re: MQTT - stuck.
Fri Jul 14, 2017 6:46 am
is there any solution for this problem or no solution for this.
DirkS
Re: MQTT - stuck.
Fri Jul 14, 2017 6:50 am
lerner wrote:On the one machine I get the messages sent through, but if I try from Machine 1 to Machine 2, it says
The program has to know where your mosquitto server is.
It assumes 'localhost' when none is given.
mosquitto_pub -h yourmosquittoserver -d -t test -m "Test"
lerner
Re: MQTT - stuck.
Fri Jul 14, 2017 7:42 am
From what I can see about "Geany", that is a text editor type program.
What does that have to do with MQTT?
lerner
Re: MQTT - stuck.
Fri Jul 14, 2017 8:02 am
Can you please indulge me how to then tell it where to send it then?
As I explained: Following what I read on the posts referenced in the first post, it doesn't explain how to do that.
DirkS
Re: MQTT - stuck.
Fri Jul 14, 2017 8:06 am
Euh... as I showed: use the -h parameter. Use name (e.g. rasperrypi.local) or IP address as the parameter
See https://mosquitto.org/man/mosquitto_pub-1.html
bensimmo
Re: MQTT - stuck.
Fri Jul 14, 2017 8:36 am
If it's not twigged.
Is the bit you are sending to as an IP 198.1.1.34 or its network name.
-h 198.1.1.34
-h PiAtHome.local
-h lerner.dyndys.org
(I've never used it, but reading so I can at some point).
Either way the first one need the IP to be reserved in the router for the Pi otherwise it might change. The second needs it to actually work on the network like that, the third is if you are trying from outside your network etc)
Re: MQTT - stuck.
Fri Jul 14, 2017 8:42 am
Please start a new topic for this.
lerner
Re: MQTT - stuck.
Fri Jul 14, 2017 9:58 pm
Thanks. Somehow I missed that.
Return to “Beginners”
