I got them. :)
And thanks to a recommendation from a friend, I also found an ideal solution for the filling valve. :) I used part of a long-necked plastic energy drink bottle, neutral construction silicone and electrical tape.
Recipe:
- cut off bottle neck
- make it smooth, wrap cutting line in two layers of isolating tape for extra smoothness
- apply silicone on the outer side of the bottle neck evenly in a layer about 1 mm thick
- with great care and clean gloves, place balloon on top of the siliconed valve tube
- apply a few more layers of tape to press the balloon against the valve, at least 4 tape turns on the pressurized side
- leave to dry for 24 hours while inflated just a *tiny* bit above ambient pressure (no stretching should occur - just enough pressure to have form)
Tools needed: disposable rubber gloves, scizzors, silicone press.
Seems to hold so far. :) Inflating it with air was quite a test for lungs, I needed to rest and have lunch before it reached 1.2 meters length and 35 cm diameter. :P The balloon with valve weighs 60 grams. Net lift for payload would seem to be around 300 grams, but it likely can be inflated to 1.5 meters too, then it will have more. Since I'm preparing for a robotics contest, I need my airship to be reasonably small, so I won't do that.
- lääh.jpg (242.23 KiB) Viewed 10564 times
