Heiner188
omxplayer cannot display VOB-Video any more
Sat Sep 29, 2012 11:38 am
i changed from Raspbian as of 2012-08-16 to Raspbian 2012-09-18, made an new installation, did
update and upgrade. But the omxplayer did'n show VOD-Videos any more.
I have installed my MPEG2-Key as bevore!
vcgencmd codec_enabled MPG2 shows not enabled!
What is going wrong? Is there a bug?
greetings from Werner
dom
Re: omxplayer cannot display VOB-Video any more
Sat Sep 29, 2012 11:48 am
Can you PM me your config.txt file and the output of
cat /proc/cpuinfo
Heiner188
Sat Sep 29, 2012 3:13 pm
[quote="dom"]Can you PM me your config.txt file and the output of
cat /proc/cpuinfo[/quote]
Hi, here commes my config.txt
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# MPEG2-Decoder
Decode_MPG2=0x71bc7328
# for more options see http://elinux.org/RPi_config.txt
and here comes my cpuinfo:
Processor : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2708
Revision : 0002
Serial : 000000004c94523e
Please take in care that because the omxplayer which comes with the Raspbian 2012-0918 did not show VOB-Videos i removed the omxplayer and have installed actually from omxplayer_0.2.1~git20120927~0dfcba62_armhf.deb. Same result!
Thanks for your reply, Heiner188
dom
Sat Sep 29, 2012 4:37 pm
Well that's easy:
decode_MPG2
starts with a lower case d.
Dweeber
Sat Sep 29, 2012 5:10 pm
Using the commands:
$ /opt/vc/bin/vcgencmd codec_enabled MPG2
MPG2=enabled
$ /opt/vc/bin/vcgencmd codec_enabled WVC1
WVC1=enabled
Is an easy way to confirm that the key(s) you are using are actually enabled.
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
Heiner188
Sat Sep 29, 2012 6:10 pm
[quote="dom"]Well that's easy:
decode_MPG2
starts with a lower case d.[/quote]
Oh, Oh, Oh
Thank you very much. Now omxplayer works again!
Microsoft Word did a change (as ever) in my documentation and made a capital D as first character.
When i was setting up Raspbian 2012-0918 i trusted my documentation and i was taking "Decode...".
Oh, Oh, Oh
plugwash
Sun Sep 30, 2012 12:30 pm
Yeah, if you use word to write technical documents where case matters you probably want to turn that feature off (it's in the autocorrect settings iirc)
Return to “Raspberry Pi OS”
