heckmic
PI freezes
Sat Sep 29, 2012 7:56 am
My PI freezes in a randome time.
I've testes several SD Cards, another DC Power (ipad charger, mobile Charger 1,2A, 3s Lipo Battery with 5V step down) - Same result. Any ideas?
elatllat
Re: PI freezes
Sat Sep 29, 2012 8:25 am
dmesg
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
heckmic
Re: PI freezes
Sat Sep 29, 2012 8:33 am
If it freezes there is no change to type in demsg, but here is the "normal" output:
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.2.27+ (dc4@dc4-arm-01) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #160 PREEMPT Mon Sep 17 23:18:42 BST 2012
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] Machine: BCM2708
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] On node 0 totalpages: 49152
[    0.000000] free_area_init_node: node 0, pgdat c050d508, node_mem_map c05b5000
[    0.000000]   Normal zone: 384 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 48768 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 48768
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x2 bcm2708.serial=0x1e8923c1 smsc95xx.macaddr=B8:27:EB:89:23:C1 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 192MB = 192MB total
[    0.000000] Memory: 188980k/188980k available, 7628k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xcc800000 - 0xe8000000   ( 440 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xcc000000   ( 192 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04c1ec8   (4840 kB)
[    0.000000]       .init : 0xc04c2000 - 0xc04e1930   ( 127 kB)
[    0.000000]       .data : 0xc04e2000 - 0xc050dba0   ( 175 kB)
[    0.000000]        .bss : 0xc050dbc4 - 0xc05b4ae8   ( 668 kB)
[    0.000000] NR_IRQS:330
[    0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[    0.000000] timer_set_mode: unhandled mode:1
[    0.000000] timer_set_mode: unhandled mode:3
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.000940] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060155] pid_max: default: 32768 minimum: 301
[    0.060631] Mount-cache hash table entries: 512
[    0.061119] Initializing cgroup subsys cpuacct
[    0.061212] Initializing cgroup subsys devices
[    0.061250] Initializing cgroup subsys freezer
[    0.061280] Initializing cgroup subsys blkio
[    0.061423] CPU: Testing write buffer coherency: ok
[    0.061776] hw perfevents: enabled with v6 PMU driver, 3 counters available
[    0.062994] devtmpfs: initialized
[    0.073193] NET: Registered protocol family 16
[    0.074878] vc_mem_connected_init: called
[    0.074961] bcm2708_vcio: bcm_mailbox_property failed (-19)
[    0.075004] vc_mem_update: success=-19 resp 0, vcbase=0 vcsize=0 armbase=0 armsize=0
[    0.075050] vc-mem: mm_vc_mem_phys_addr = 0x00000000
[    0.075080] vc-mem: mm_vc_mem_size      = 0x00000000 (0 MiB)
[    0.075560] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.075615] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.075654] mailbox: Broadcom VideoCore Mailbox driver
[    0.075748] bcm2708_vcio: mailbox at f200b880
[    0.075839] bcm_power: Broadcom power driver
[    0.075877] bcm_power_open() -> 0
[    0.075902] bcm_power_request(0, 8)
[    0.576587] bcm_mailbox_read -> 00000080, 0
[    0.576626] bcm_power_request -> 0
[    0.576652] Serial: AMBA PL011 UART driver
[    0.576806] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[    0.902783] console [ttyAMA0] enabled
[    0.927602] bio: create slab <bio-0> at 0
[    0.932778] SCSI subsystem initialized
[    0.936877] usbcore: registered new interface driver usbfs
[    0.942497] usbcore: registered new interface driver hub
[    0.948131] usbcore: registered new device driver usb
[    0.954061] Switching to clocksource stc
[    0.958418] FS-Cache: Loaded
[    0.961594] CacheFiles: Loaded
[    0.977818] NET: Registered protocol family 2
[    0.982741] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.990818] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.998336] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    1.004980] TCP: Hash tables configured (established 8192 bind 8192)
[    1.011393] TCP reno registered
[    1.014561] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    1.020473] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    1.027249] NET: Registered protocol family 1
[    1.032436] RPC: Registered named UNIX socket transport module.
[    1.038567] RPC: Registered udp transport module.
[    1.043290] RPC: Registered tcp transport module.
[    1.048005] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.054762] bcm2708_dma: DMA manager at cc808000
[    1.059546] bcm2708_gpio: bcm2708_gpio_probe c04e9c18
[    1.064992] vc-mem: Videocore memory driver
[    1.070005] audit: initializing netlink socket (disabled)
[    1.075489] type=2000 audit(0.740:1): initialized
[    1.192618] VFS: Disk quotas dquot_6.5.2
[    1.196767] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.204354] FS-Cache: Netfs 'nfs' registered for caching
[    1.210664] msgmni has been set to 369
[    1.216450] io scheduler noop registered
[    1.220558] io scheduler deadline registered (default)
[    1.225865] io scheduler cfq registered
[    1.246772] Console: switching to colour frame buffer device 82x26
[    1.259047] kgdb: Registered I/O driver kgdboc.
[    1.275038] brd: module loaded
[    1.285062] loop: module loaded
[    1.291167] vcos: [1]: vchiq_init_state: slot_zero = 0xffd80000, is_master = 0
[    1.300776] vcos: [1]: vchiq_init_state: called
[    1.308345] vcos: [1]: vchiq: initialised - version 2 (min 2), device 252.0
[    1.318246] usbcore: registered new interface driver smsc95xx
[    1.326176] cdc_ncm: 04-Aug-2011
[    1.331668] usbcore: registered new interface driver cdc_ncm
[    1.339558] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.547679] Core Release: 2.80a
[    1.553110] Setting default values for core params
[    1.560137] Finished setting default values for core params
[    1.768027] Using Buffer DMA mode
[    1.773517] Periodic Transfer Interrupt Enhancement - disabled
[    1.781521] Multiprocessor Interrupt Enhancement - disabled
[    1.789277] OTG VER PARAM: 0, OTG VER FLAG: 0
[    1.795746] Dedicated Tx FIFOs mode
[    1.801600] dwc_otg: Microframe scheduler enabled
[    1.801655] dwc_otg bcm2708_usb: DWC OTG Controller
[    1.808864] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[    1.818396] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[    1.826059] Init: Port Power? op_state=1
[    1.832245] Init: Power Port (0)
[    1.837707] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.846754] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.856222] usb usb1: Product: DWC OTG Controller
[    1.863135] usb usb1: Manufacturer: Linux 3.2.27+ dwc_otg_hcd
[    1.871081] usb usb1: SerialNumber: bcm2708_usb
[    1.878651] hub 1-0:1.0: USB hub found
[    1.884524] hub 1-0:1.0: 1 port detected
[    1.891278] dwc_otg: FIQ enabled
[    1.891296] dwc_otg: NAK holdoff enabled
[    1.891317] Module dwc_common_port init
[    1.891654] usbcore: registered new interface driver uas
[    1.899134] Initializing USB Mass Storage driver...
[    1.906326] usbcore: registered new interface driver usb-storage
[    1.914494] USB Mass Storage support registered.
[    1.921502] usbcore: registered new interface driver libusual
[    1.929783] mousedev: PS/2 mouse device common for all mice
[    1.938343] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[    1.944197] bcm2835-cpufreq: switching to governor powersave
[    1.951989] bcm2835-cpufreq: switching to governor powersave
[    1.959851] cpuidle: using governor ladder
[    1.967874] cpuidle: using governor menu
[    1.973863] sdhci: Secure Digital Host Controller Interface driver
[    1.982061] sdhci: Copyright(c) Pierre Ossman
[    1.988693] sdhci: Enable low-latency mode
[    1.994735] bcm_power_open() -> 1
[    2.001238] Registered led device: mmc0::
[    2.002650] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[    2.014487] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[    2.022559] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.031774] Registered led device: led0
[    2.032169] usbcore: registered new interface driver usbhid
[    2.039970] usbhid: USB HID core driver
[    2.047099] TCP cubic registered
[    2.052598] Initializing XFRM netlink socket
[    2.061158] NET: Registered protocol family 17
[    2.070898] Registering the dns_resolver key type
[    2.079922] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    2.094013] Indeed it is in host mode hprt0 = 00021501
[    2.106472] registered taskstats version 1
[    2.128327] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.148767] Waiting for root device /dev/mmcblk0p2...
[    2.162198] mmc0: problem reading SD Status register.
[    2.185633] mmc0: new high speed SDHC card at address b368
[    2.208835] mmcblk0: mmc0:b368 00000 7.51 GiB
[    2.217577]  mmcblk0: p1 p2
[    2.338257] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.348386] Indeed it is in host mode hprt0 = 00001101
[    2.558552] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[    2.568784] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.579170] hub 1-1:1.0: USB hub found
[    2.586424] hub 1-1:1.0: 3 ports detected
[    2.868413] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    2.978913] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    2.989348] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.002220] smsc95xx v1.0.4
[    3.074091] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:89:23:c1
[    3.168448] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[    3.279654] usb 1-1.3: New USB device found, idVendor=0403, idProduct=6001
[    3.290459] usb 1-1.3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    8.215282] EXT4-fs (mmcblk0p2): recovery complete
[    8.452932] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.465926] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    8.475795] devtmpfs: mounted
[    8.482196] Freeing init memory: 124K
[    9.825260] udevd[138]: starting version 175
[   10.921557] usbcore: registered new interface driver usbserial
[   11.032775] USB Serial support registered for generic
[   11.211634] usbcore: registered new interface driver usbserial_generic
[   11.421688] usbserial: USB Serial Driver core
[   11.702373] USB Serial support registered for FTDI USB Serial Device
[   11.886131] ftdi_sio 1-1.3:1.0: FTDI USB Serial Device converter detected
[   11.959872] usb 1-1.3: Detected FT232BM
[   11.966299] usb 1-1.3: Number of endpoints 2
[   12.129580] usb 1-1.3: Endpoint 1 MaxPacketSize 64
[   12.136826] usb 1-1.3: Endpoint 2 MaxPacketSize 64
[   12.245767] usb 1-1.3: Setting MaxPacketSize 64
[   12.298259] ftdi_sio ttyUSB0: Unable to read latency timer: -32
[   12.338582] usb 1-1.3: FTDI USB Serial Device converter now attached to ttyUSB0
[   12.384432] usbcore: registered new interface driver ftdi_sio
[   12.410927] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[   16.666800] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.137617] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[   17.889002] bcm2835 ALSA card created!
[   25.586953] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
[   36.032042] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
elatllat
Re: PI freezes
Mon Oct 01, 2012 5:01 pm
you can use
watch "dmesg | tail -n 45"
to get the output just before it fails.
albundy
Re: PI freezes
Mon Oct 01, 2012 5:14 pm
I see you have an USB to serial adapter connected. Remove it for a while and search the forum. There are issues reported where eth0 disappears when an FTDI adapter is connected.
In fact your pi doesn't freeze, it is still running but eth0 is no longer there.
heckmic
Re: PI freezes
Mon Oct 01, 2012 6:53 pm
The problem ist still without any device connected.
heckmic
Re: PI freezes
Mon Oct 01, 2012 8:07 pm
[ 4802.340017] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:251: I/O error writing to inode 1233 (offset 2621440 size 524288 starting block 316160)
[ 4802.564648] mmc0: final write to SD card still running
[ 4812.592093] mmc0: Timeout waiting for hardware interrupt - cmd12.
[ 4812.592301] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[ 4813.044412] JBD2: Detected IO errors while flushing file data on mmcblk0p2-8
[ 4827.276628] mmc0: final write to SD card still running
[ 4837.292556] mmc0: Timeout waiting for hardware interrupt - cmd12.
[ 4837.293905] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[ 4847.312742] mmc0: Timeout waiting for hardware interrupt - cmd25.
[ 4847.312784] mmc0: resetting ongoing cmd 25DMA before 442368/442368 [4]/[4] complete
[ 4847.317358] mmcblk0: error -110 transferring data, sector 2752512, nr 1024, cmd response 0x900, card status 0xc00
[ 4847.317537] mmc0: DMA IRQ 6 ignored - results were reset
[ 4847.317651] end_request: I/O error, dev mmcblk0, sector 2752989
[ 4847.317678] end_request: I/O error, dev mmcblk0, sector 2752992
[ 4847.317699] end_request: I/O error, dev mmcblk0, sector 2753000
[ 4847.317720] end_request: I/O error, dev mmcblk0, sector 2753008
[ 4847.317739] end_request: I/O error, dev mmcblk0, sector 2753016
[ 4847.317758] end_request: I/O error, dev mmcblk0, sector 2753024
[ 4847.317777] end_request: I/O error, dev mmcblk0, sector 2753032
[ 4847.317796] end_request: I/O error, dev mmcblk0, sector 2753040
[ 4847.317816] end_request: I/O error, dev mmcblk0, sector 2753048
[ 4847.317835] end_request: I/O error, dev mmcblk0, sector 2753056
[ 4847.317853] end_request: I/O error, dev mmcblk0, sector 2753064
[ 4847.317872] end_request: I/O error, dev mmcblk0, sector 2753072
[ 4847.317891] end_request: I/O error, dev mmcblk0, sector 2753080
[ 4847.317909] end_request: I/O error, dev mmcblk0, sector 2753088
[ 4847.317928] end_request: I/O error, dev mmcblk0, sector 2753096
[ 4847.317946] end_request: I/O error, dev mmcblk0, sector 2753104
[ 4847.317964] end_request: I/O error, dev mmcblk0, sector 2753112
[ 4847.317983] end_request: I/O error, dev mmcblk0, sector 2753120
[ 4847.318001] end_request: I/O error, dev mmcblk0, sector 2753128
[ 4847.318019] end_request: I/O error, dev mmcblk0, sector 2753136
[ 4847.318037] end_request: I/O error, dev mmcblk0, sector 2753144
[ 4847.318055] end_request: I/O error, dev mmcblk0, sector 2753152
[ 4847.318072] end_request: I/O error, dev mmcblk0, sector 2753160
[ 4847.318090] end_request: I/O error, dev mmcblk0, sector 2753168
[ 4847.318107] end_request: I/O error, dev mmcblk0, sector 2753176
[ 4847.318125] end_request: I/O error, dev mmcblk0, sector 2753184
[ 4847.318142] end_request: I/O error, dev mmcblk0, sector 2753192
[ 4847.318159] end_request: I/O error, dev mmcblk0, sector 2753200
[ 4847.318176] end_request: I/O error, dev mmcblk0, sector 2753208
[ 4847.318194] end_request: I/O error, dev mmcblk0, sector 2753216
[ 4847.318211] end_request: I/O error, dev mmcblk0, sector 2753224
[ 4847.318228] end_request: I/O error, dev mmcblk0, sector 2753232
[ 4847.318244] end_request: I/O error, dev mmcblk0, sector 2753240
[ 4847.318261] end_request: I/O error, dev mmcblk0, sector 2753248
[ 4847.318278] end_request: I/O error, dev mmcblk0, sector 2753256
[ 4847.318294] end_request: I/O error, dev mmcblk0, sector 2753264
[ 4847.318311] end_request: I/O error, dev mmcblk0, sector 2753272
[ 4847.318327] end_request: I/O error, dev mmcblk0, sector 2753280
[ 4847.318344] end_request: I/O error, dev mmcblk0, sector 2753288
[ 4847.318360] end_request: I/O error, dev mmcblk0, sector 2753296
[ 4847.318376] end_request: I/O error, dev mmcblk0, sector 2753304
[ 4847.318392] end_request: I/O error, dev mmcblk0, sector 2753312
[ 4847.318408] end_request: I/O error, dev mmcblk0, sector 2753320
[ 4847.318424] end_request: I/O error, dev mmcblk0, sector 2753328
[ 4847.318440] end_request: I/O error, dev mmcblk0, sector 2753336
[ 4847.318456] end_request: I/O error, dev mmcblk0, sector 2753344
[ 4847.318471] end_request: I/O error, dev mmcblk0, sector 2753352
[ 4847.318487] end_request: I/O error, dev mmcblk0, sector 2753360
[ 4847.318502] end_request: I/O error, dev mmcblk0, sector 2753368
[ 4847.318518] end_request: I/O error, dev mmcblk0, sector 2753376
[ 4847.318533] end_request: I/O error, dev mmcblk0, sector 2753384
[ 4847.318548] end_request: I/O error, dev mmcblk0, sector 2753392
[ 4847.318563] end_request: I/O error, dev mmcblk0, sector 2753400
[ 4847.318578] end_request: I/O error, dev mmcblk0, sector 2753408
[ 4847.318593] end_request: I/O error, dev mmcblk0, sector 2753416
[ 4847.318608] end_request: I/O error, dev mmcblk0, sector 2753424
[ 4847.318622] end_request: I/O error, dev mmcblk0, sector 2753432
[ 4847.318637] end_request: I/O error, dev mmcblk0, sector 2753440
[ 4847.318651] end_request: I/O error, dev mmcblk0, sector 2753448
[ 4847.318666] end_request: I/O error, dev mmcblk0, sector 2753456
[ 4847.318680] end_request: I/O error, dev mmcblk0, sector 2753464
[ 4847.318694] end_request: I/O error, dev mmcblk0, sector 2753472
[ 4847.318709] end_request: I/O error, dev mmcblk0, sector 2753480
[ 4847.318723] end_request: I/O error, dev mmcblk0, sector 2753488
[ 4847.318737] end_request: I/O error, dev mmcblk0, sector 2753496
[ 4847.318750] end_request: I/O error, dev mmcblk0, sector 2753504
[ 4847.318764] end_request: I/O error, dev mmcblk0, sector 2753512
[ 4847.318778] end_request: I/O error, dev mmcblk0, sector 2753520
[ 4847.318792] end_request: I/O error, dev mmcblk0, sector 2753528
[ 4847.318818] Buffer I/O error on device mmcblk0p2, logical block 328704
[ 4847.318846] Buffer I/O error on device mmcblk0p2, logical block 328705
[ 4847.318864] Buffer I/O error on device mmcblk0p2, logical block 328706
[ 4847.318881] Buffer I/O error on device mmcblk0p2, logical block 328707
[ 4847.318898] Buffer I/O error on device mmcblk0p2, logical block 328708
[ 4847.318914] Buffer I/O error on device mmcblk0p2, logical block 328709
[ 4847.318931] Buffer I/O error on device mmcblk0p2, logical block 328710
[ 4847.318948] Buffer I/O error on device mmcblk0p2, logical block 328711
[ 4847.318965] Buffer I/O error on device mmcblk0p2, logical block 328712
[ 4847.318982] Buffer I/O error on device mmcblk0p2, logical block 328713
[ 4847.318999] Buffer I/O error on device mmcblk0p2, logical block 328714
[ 4847.319016] Buffer I/O error on device mmcblk0p2, logical block 328715
[ 4847.319032] Buffer I/O error on device mmcblk0p2, logical block 328716
[ 4847.319049] Buffer I/O error on device mmcblk0p2, logical block 328717
[ 4847.319066] Buffer I/O error on device mmcblk0p2, logical block 328718
[ 4847.319083] Buffer I/O error on device mmcblk0p2, logical block 328719
[ 4847.319099] Buffer I/O error on device mmcblk0p2, logical block 328720
[ 4847.319116] Buffer I/O error on device mmcblk0p2, logical block 328721
[ 4847.319133] Buffer I/O error on device mmcblk0p2, logical block 328722
[ 4847.319150] Buffer I/O error on device mmcblk0p2, logical block 328723
[ 4847.319167] Buffer I/O error on device mmcblk0p2, logical block 328724
[ 4847.319184] Buffer I/O error on device mmcblk0p2, logical block 328725
[ 4847.319201] Buffer I/O error on device mmcblk0p2, logical block 328726
[ 4847.319217] Buffer I/O error on device mmcblk0p2, logical block 328727
[ 4847.319234] Buffer I/O error on device mmcblk0p2, logical block 328728
[ 4847.319251] Buffer I/O error on device mmcblk0p2, logical block 328729
[ 4847.319268] Buffer I/O error on device mmcblk0p2, logical block 328730
[ 4847.319284] Buffer I/O error on device mmcblk0p2, logical block 328731
[ 4847.319300] Buffer I/O error on device mmcblk0p2, logical block 328732
[ 4847.319317] Buffer I/O error on device mmcblk0p2, logical block 328733
[ 4847.319334] Buffer I/O error on device mmcblk0p2, logical block 328734
[ 4847.319351] Buffer I/O error on device mmcblk0p2, logical block 328735
[ 4847.319367] Buffer I/O error on device mmcblk0p2, logical block 328736
[ 4847.319384] Buffer I/O error on device mmcblk0p2, logical block 328737
[ 4847.319401] Buffer I/O error on device mmcblk0p2, logical block 328738
[ 4847.319417] Buffer I/O error on device mmcblk0p2, logical block 328739
[ 4847.319434] Buffer I/O error on device mmcblk0p2, logical block 328740
[ 4847.319451] Buffer I/O error on device mmcblk0p2, logical block 328741
[ 4847.319468] Buffer I/O error on device mmcblk0p2, logical block 328742
[ 4847.319484] Buffer I/O error on device mmcblk0p2, logical block 328743
[ 4847.319501] Buffer I/O error on device mmcblk0p2, logical block 328744
[ 4847.319518] Buffer I/O error on device mmcblk0p2, logical block 328745
[ 4847.319535] Buffer I/O error on device mmcblk0p2, logical block 328746
[ 4847.319551] Buffer I/O error on device mmcblk0p2, logical block 328747
[ 4847.319568] Buffer I/O error on device mmcblk0p2, logical block 328748
[ 4847.319585] Buffer I/O error on device mmcblk0p2, logical block 328749
[ 4847.319601] Buffer I/O error on device mmcblk0p2, logical block 328750
[ 4847.319618] Buffer I/O error on device mmcblk0p2, logical block 328751
[ 4847.319634] Buffer I/O error on device mmcblk0p2, logical block 328752
[ 4847.319651] Buffer I/O error on device mmcblk0p2, logical block 328753
[ 4847.319668] Buffer I/O error on device mmcblk0p2, logical block 328754
[ 4847.319686] Buffer I/O error on device mmcblk0p2, logical block 328755
[ 4847.319703] Buffer I/O error on device mmcblk0p2, logical block 328756
[ 4847.319720] Buffer I/O error on device mmcblk0p2, logical block 328757
[ 4847.319736] Buffer I/O error on device mmcblk0p2, logical block 328758
[ 4847.319753] Buffer I/O error on device mmcblk0p2, logical block 328759
[ 4847.319769] Buffer I/O error on device mmcblk0p2, logical block 328760
[ 4847.319786] Buffer I/O error on device mmcblk0p2, logical block 328761
[ 4847.319803] Buffer I/O error on device mmcblk0p2, logical block 328762
[ 4847.319819] Buffer I/O error on device mmcblk0p2, logical block 328763
[ 4847.319836] Buffer I/O error on device mmcblk0p2, logical block 328764
[ 4847.319852] Buffer I/O error on device mmcblk0p2, logical block 328765
[ 4847.319869] Buffer I/O error on device mmcblk0p2, logical block 328766
[ 4847.319885] Buffer I/O error on device mmcblk0p2, logical block 328767
[ 4847.319902] Buffer I/O error on device mmcblk0p2, logical block 328768
[ 4847.319919] Buffer I/O error on device mmcblk0p2, logical block 328769
[ 4847.319936] Buffer I/O error on device mmcblk0p2, logical block 328770
[ 4847.319952] Buffer I/O error on device mmcblk0p2, logical block 328771
[ 4847.319969] Buffer I/O error on device mmcblk0p2, logical block 328772
[ 4847.319986] Buffer I/O error on device mmcblk0p2, logical block 328773
[ 4847.320002] Buffer I/O error on device mmcblk0p2, logical block 328774
[ 4847.320019] Buffer I/O error on device mmcblk0p2, logical block 328775
[ 4847.320035] Buffer I/O error on device mmcblk0p2, logical block 328776
[ 4847.320052] Buffer I/O error on device mmcblk0p2, logical block 328777
[ 4847.320069] Buffer I/O error on device mmcblk0p2, logical block 328778
[ 4847.320085] Buffer I/O error on device mmcblk0p2, logical block 328779
[ 4847.320103] Buffer I/O error on device mmcblk0p2, logical block 328780
[ 4847.320119] Buffer I/O error on device mmcblk0p2, logical block 328781
[ 4847.320136] Buffer I/O error on device mmcblk0p2, logical block 328782
[ 4847.320153] Buffer I/O error on device mmcblk0p2, logical block 328783
[ 4847.320170] Buffer I/O error on device mmcblk0p2, logical block 328784
[ 4847.320187] Buffer I/O error on device mmcblk0p2, logical block 328785
[ 4847.320204] Buffer I/O error on device mmcblk0p2, logical block 328786
[ 4847.320220] Buffer I/O error on device mmcblk0p2, logical block 328787
[ 4847.320237] Buffer I/O error on device mmcblk0p2, logical block 328788
[ 4847.320253] Buffer I/O error on device mmcblk0p2, logical block 328789
[ 4847.320270] Buffer I/O error on device mmcblk0p2, logical block 328790
[ 4847.320287] Buffer I/O error on device mmcblk0p2, logical block 328791
[ 4847.320303] Buffer I/O error on device mmcblk0p2, logical block 328792
[ 4847.320320] Buffer I/O error on device mmcblk0p2, logical block 328793
[ 4847.320337] Buffer I/O error on device mmcblk0p2, logical block 328794
[ 4847.320353] Buffer I/O error on device mmcblk0p2, logical block 328795
[ 4847.320370] Buffer I/O error on device mmcblk0p2, logical block 328796
[ 4847.320387] Buffer I/O error on device mmcblk0p2, logical block 328797
[ 4847.320403] Buffer I/O error on device mmcblk0p2, logical block 328798
[ 4847.320420] Buffer I/O error on device mmcblk0p2, logical block 328799
[ 4847.320436] Buffer I/O error on device mmcblk0p2, logical block 328800
[ 4847.320453] Buffer I/O error on device mmcblk0p2, logical block 328801
[ 4847.320470] Buffer I/O error on device mmcblk0p2, logical block 328802
[ 4847.320487] Buffer I/O error on device mmcblk0p2, logical block 328803
[ 4847.320503] Buffer I/O error on device mmcblk0p2, logical block 328804
[ 4847.320520] Buffer I/O error on device mmcblk0p2, logical block 328805
[ 4847.320537] Buffer I/O error on device mmcblk0p2, logical block 328806
[ 4847.320553] Buffer I/O error on device mmcblk0p2, logical block 328807
[ 4847.320570] Buffer I/O error on device mmcblk0p2, logical block 328808
[ 4847.320587] Buffer I/O error on device mmcblk0p2, logical block 328809
[ 4847.320604] Buffer I/O error on device mmcblk0p2, logical block 328810
[ 4847.320620] Buffer I/O error on device mmcblk0p2, logical block 328811
[ 4847.320637] Buffer I/O error on device mmcblk0p2, logical block 328812
[ 4847.320654] Buffer I/O error on device mmcblk0p2, logical block 328813
[ 4847.320670] Buffer I/O error on device mmcblk0p2, logical block 328814
[ 4847.320687] Buffer I/O error on device mmcblk0p2, logical block 328815
[ 4847.320703] Buffer I/O error on device mmcblk0p2, logical block 328816
[ 4847.320720] Buffer I/O error on device mmcblk0p2, logical block 328817
[ 4847.320737] Buffer I/O error on device mmcblk0p2, logical block 328818
[ 4847.320753] Buffer I/O error on device mmcblk0p2, logical block 328819
[ 4847.320770] Buffer I/O error on device mmcblk0p2, logical block 328820
[ 4847.320786] Buffer I/O error on device mmcblk0p2, logical block 328821
[ 4847.320803] Buffer I/O error on device mmcblk0p2, logical block 328822
[ 4847.320819] Buffer I/O error on device mmcblk0p2, logical block 328823
[ 4847.320846] Buffer I/O error on device mmcblk0p2, logical block 328824
[ 4847.320863] Buffer I/O error on device mmcblk0p2, logical block 328825
[ 4847.320880] Buffer I/O error on device mmcblk0p2, logical block 328826
[ 4847.320897] Buffer I/O error on device mmcblk0p2, logical block 328827
[ 4847.320913] Buffer I/O error on device mmcblk0p2, logical block 328828
[ 4847.320930] Buffer I/O error on device mmcblk0p2, logical block 328829
[ 4847.320946] Buffer I/O error on device mmcblk0p2, logical block 328830
[ 4847.320963] Buffer I/O error on device mmcblk0p2, logical block 328831
[ 4847.320988] EXT4-fs warning (device mmcblk0p2): ext4_end_bio:251: I/O error writing to inode 1233 (offset 4194304 size 524288 starting block 344192)
[ 4847.547961] mmc0: final write to SD card still running
[ 4857.552932] mmc0: Timeout waiting for hardware interrupt - cmd12.
[ 4857.554297] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[ 4857.778055] mmc0: final write to SD card still running
[ 4867.793143] mmc0: Timeout waiting for hardware interrupt - cmd12.
[ 4867.794451] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[ 4868.019422] mmc0: final write to SD card still running
[ 4878.033320] mmc0: Timeout waiting for hardware interrupt - cmd12.
[ 4878.034618] mmcblk0: error -110 sending stop command, original cmd response 0x900, card status 0x900
[ 4878.493563] JBD2: Detected IO errors while flushing file data on mmcblk0p2-8
I've tested now 4 SD Cards (2 new) - all have these Errors.
elatllat
Re: PI freezes
Thu Oct 04, 2012 4:15 am
are you over clocked? what distro are you using?
heckmic
Re: PI freezes
Thu Oct 04, 2012 4:51 am
No overclocking. wheezy.
rkward
Re: PI freezes
Thu Oct 04, 2012 1:09 pm
I don't have any other info to provide on this towards a solution but I have the exact same issue with mine. I have been using SSH and have also used the FTDI cable and terminal access. If it sits (seemingly) without access/interaction it always seems to lock up. This is an unmoded, out of the box model without any additional HW.
I was pretty excited about these until this started happening. I am hoping that it is not typical and that I can rely on this 24/7 if I can find a solution.
heckmic
Re: PI freezes
Fri Oct 05, 2012 9:01 am
NEW Pi - No Problems.
Re: PI freezes
Fri Oct 05, 2012 9:09 am
Using the same SD card?
RaTTuS
Contact: Twitter YouTube
Re: PI freezes
Fri Oct 05, 2012 9:21 am
power?
Covfefe
rkward
Re: PI freezes
Fri Oct 05, 2012 12:35 pm
Power supply from Adafruit (very reliable as most of us know). I can communicate with the unit for hours while working on scripts with no problems. I leave it unattended for a while, it locks up. I can substitute in my second board to see if the problem remains. I can do the same with the SD card as well.
I would suspect that if this was a wide-spread problem if would have lot more visibility by now, so it must be specific to the hw of just a few of us.
heckmic
Re: PI freezes
Fri Oct 05, 2012 12:43 pm
Yes, all 4 SD Cards now working. All 4 have errors in the other PI.
scruss
Re: PI freezes
Fri Oct 26, 2012 1:54 pm
This is exactly the problem I am having with my new 512MB Raspberry Pi: mmcblk0: error -110 sending stop command
Pronouns: he/him
meufeu
Re: PI freezes
Sun Jan 06, 2013 9:48 pm
hi from france
it seems my problem is right the same
in my case i have usb>serial FTDI drivers > my raspi look alive but i cannot connect through ssh
Return to “Debian”
