shawt
New Block Coding Tool for the Pi
Fri Jun 30, 2017 5:58 pm
Hi Folks,
Wanted to let you know about a new tool I created to use with students in our summer program. It's block based and tries to include lots of the features of the Pi. It creates Python code. The programming can be done on the Pi directly or from any other web-enabled device if you are running headless.
There's LOTS of blocks to control Minecraft as well as blocks to do GPIO, email, and file I/O.
Have a look and let me know what you think.
http://www.genlrn.com/iForge/rpi.html
Note that you have to install the server component on your pi before it will work (sudo pip install piforge)
Trevor
samygo333
Re: New Block Coding Tool for the Pi
Thu Sep 06, 2018 12:37 pm
Once you install the server component on your pi, how to you start the program on the pi. Also, when I'm on the web interface (https://iforge.genlrn.com/rpi.html) and I type in my ip address, how do I know I'm actually connected to our pi?
Return to “Teaching and learning resources”
