Conner Labs
Using RTC with non-standard I2C port
Wed Jun 28, 2017 3:57 pm
Hi all
I have a PCF2127 RTC chip connected to my Compute Module 3. I am running the latest Raspbian Jessie Lite official image.
I am using the i2c-gpio overlay to drive it through a software emulated I2C port, to save the real I2C port for something more important.
If I use dtoverlay=i2c-rtc,pcf2127, it only looks for the RTC on i2c-1, and fails, as the emulated I2C port is i2c-3.
If I remove the dtoverlay line, and issue the following commands:
modprobe i2c-dev
modprobe rtc-pcf2127
echo pcf2127 0x51 >> /sys/bus/i2c/devices/i2c-3/new_device;
the driver loads successfully and the hwclock command talks to the RTC chip as it should.
But I can't figure out which file to put these commands in to make it work automatically at boot time. I also can't figure out how to make the overlay work with i2c-3.
Any help appreciated.
Steve Conner
DirkS
Re: Using RTC with non-standard I2C port
Wed Jun 28, 2017 4:46 pm
Why? Do you see problems when you use the RTC on i2c1?
PhilE
Thu Jun 29, 2017 8:28 am
Rather like the other current question on using an ads7846 on spi1, this shows up a hole in the DT overlay mechanism - it is almost impossible to parameterise an overlay for different I2C or SPI busses. For now you will have to copy the standard i2c-rtc overlay and modify it to reference i2c-3 instead. Actually it would be better if you make it an i2c-rtc-gpio overlay instead - a combination of i2c-gpio and i2c-rtc.
Conner Labs
Thu Jun 29, 2017 9:24 am
I had no problems using the RTC on i2c-1. It's just that our product has an array of data acquisition boards connected to i2c-1. I want a real hardware I2C port for these as it's faster, and I want the RTC on a different port so the RTC driver doesn't conflict with our data acquisition driver.
(I have no idea if they would in fact conflict, I just don't even want to go there, and I've already signed off on the PCB design.)
It worked fine on the CM1 which had 2 real I2C ports. :? On the CM3, i2c-0 is actually used by the GPU for something.
PhilE: I suspected this was the case. I am aiming to develop a script that customises the standard Jessie Lite image into the image for our product. So this means I need to make the script compile a DTB overlay, and have it break every time you change device tree, which seems to be quite often?
If I developed this i2c-rtc-gpio overlay and got it working, would you let me push it into the official distribution?
PhilE
Thu Jun 29, 2017 9:46 am
Yes of course - and I'm happy to help if you get stuck.
Conner Labs
Thu Jun 29, 2017 12:04 pm
OK, so I tried what seemed to me the obvious approach. I got the relevant .dts files from the 4.9.y branch on github, pasted the contents of i2c-rtc-overlay.dts and i2c-gpio-overlay.dts together into a file called i2c-gpio-rtc-overlay.dts, replaced "i2c_arm" for "i2c_gpio", and changed the fragment numbers about.
And... it worked :D
How would I go about pushing this upstream?
// Definitions for several I2C based Real Time Clocks
// Available through i2c-gpio
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2708";
  [email protected] {
		target-path = "/";
		__overlay__ {
			i2c_gpio: [email protected] {
				compatible = "i2c-gpio";
				gpios = <&gpio 23 0 /* sda */
					 &gpio 24 0 /* scl */
				i2c-gpio,delay-us = <2>;        /* ~100 kHz */
				#address-cells = <1>;
				#size-cells = <0>;
	[email protected] {
		target-path = "/aliases";
		__overlay__ {
			i2c_gpio = "/[email protected]";
	[email protected] {
		target-path = "/__symbols__";
		__overlay__ {
	[email protected] {
		target = <&i2c_gpio>;
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			abx80x: [email protected] {
				compatible = "abracon,abx80x";
				reg = <0x69>;
				abracon,tc-diode = "standard";
				abracon,tc-resistor = <0>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			ds1307: [email protected] {
				compatible = "maxim,ds1307";
				reg = <0x68>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			ds1339: [email protected] {
				compatible = "dallas,ds1339";
				trickle-resistor-ohms = <0>;
				reg = <0x68>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			ds3231: [email protected] {
				compatible = "maxim,ds3231";
				reg = <0x68>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			mcp7940x: [email protected] {
				compatible = "microchip,mcp7940x";
				reg = <0x6f>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			mcp7941x: [email protected] {
				compatible = "microchip,mcp7941x";
				reg = <0x6f>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			pcf2127: [email protected] {
				compatible = "nxp,pcf2127";
				reg = <0x51>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			pcf8523: [email protected] {
				compatible = "nxp,pcf8523";
				reg = <0x68>;
				status = "okay";
	[email protected] {
		__dormant__ {
			#size-cells = <0>;
			status = "okay";
			pcf8563: [email protected] {
				compatible = "nxp,pcf8563";
				reg = <0x51>;
				status = "okay";
	__overrides__ {
		abx80x = <0>,"+3";
		ds1307 = <0>,"+4";
		ds1339 = <0>,"+5";
		ds3231 = <0>,"+6";
		mcp7940x = <0>,"+7";
		mcp7941x = <0>,"+8";
		pcf2127 = <0>,"+9";
		pcf8523 = <0>,"+10";
		pcf8563 = <0>,"+11";
		trickle-diode-type = <&abx80x>,"abracon,tc-diode";
		trickle-resistor-ohms = <&ds1339>,"trickle-resistor-ohms:0",
					<&abx80x>,"abracon,tc-resistor";
		wakeup-source = <&ds1339>,"wakeup-source?",
				<&ds3231>,"wakeup-source?",
				<&mcp7940x>,"wakeup-source?",
				<&mcp7941x>,"wakeup-source?";
    i2c_gpio_sda = <&i2c_gpio>,"gpios:4";
    i2c_gpio_scl = <&i2c_gpio>,"gpios:16";
    i2c_gpio_delay_us = <&i2c_gpio>,"i2c-gpio,delay-us:0";
This compiled ok (I'm a Real Programmer, warnings don't count ;) )
[email protected]:~/i2c-gpio-rtc $ dtc [email protected] -I dts -O dtb -o i2c-gpio-rtc.dtbo i2c-gpio-rtc-overlay.dts
Warning (unit_address_vs_reg): Node /[email protected] has a unit name, but no reg property
Warning (unit_address_vs_reg): Node /[email protected]/__overlay__/[email protected] has a unit name, but no reg property
I instantiated it with
dtoverlay=i2c-gpio-rtc,pcf2127,i2c_gpio_sda=5,i2c_gpio_scl=6
PhilE
Thu Jun 29, 2017 12:15 pm
Nice job. The correct way to get it into the kernel is to create a Pull Request in the raspberrypi/linux GitHub repo:
https://github.com/raspberrypi/linux/pulls
Using the GitHub GUI you will be able to create new files and modify others, then turn those commits into a Pull Request. The overlay sources belong in: https://github.com/raspberrypi/linux/tr ... s/overlays
You'll also need to edit the Makefile and README in that directory. Be careful with alphabetical ordering and formatting of the README file - no TABs, same indents, two blank lines between entries.
If that sounds too much, create an issue instead (https://github.com/raspberrypi/linux/issues), including or linking to your overlay and asking for it to be included. Either way, it will be answered by my GH alter ego.
Conner Labs
Thu Jun 29, 2017 12:25 pm
I'll give it a go thanks. What branch should I be raising the pull request on? rpi-4.9.y?
PhilE
Thu Jun 29, 2017 12:26 pm
Yes - that's what we're currently building against. I can take care of merging into the newer branches.
Conner Labs
Thu Jun 29, 2017 1:30 pm
OK, I've submitted the pull request. I don't normally use Git so hopefully I haven't done anything too dreadful.
PhilE
Thu Jun 29, 2017 1:45 pm
No, it looks good. I have some relatively minor feedback, but once that's addressed it can be merged.
Return to “Device Tree”
