Hi there,
I just got a pi dac+ from iqaudio and therefore need a new case. However I'd like to have a fan as with the old case.I saw this one https://www.modmypi.com/raspberry-pi/ca ... case-black
but I was wondering if the fan would be better on top (as with normal cases) or maybe on the back side, above the sd slot? As the heat comes from hte cpu which is under the dac + what do you think it's the best spot for the fan to be?
Cheers!
P.
