I do have the Logitech k400 wireless keyboard (integrated touchpad) connected to the Pi.
Most times it works ok. But often (say 1 out of 3 times) the keyboard/mouse doesnt connect. on boot.
It looks like the usb dongle is detected (from the console text output). If I dont touch anything, it does boot into xbmc by default.
To check I press space on the keyboard to see if the keyboard responds during bootup. If it doesnt respond it does help to quickly unplug and plug the usb dongle. Then the keyboard starts working again.
If I let it launch xbmc without working keyboard it doesnt seem to help to replug the dongle.
I have the dongle plugged in the powered usb-hub, but it does behave the same if I plug it directly in the Pi usb.
This will happen both if I reboot or from a cold start. But for the reboot, it looks like the situation have improved a bit after some of the later firmware updates. Because before it happened almost every time after a reboot, now not so often.
Does anyone else experience similar problems, or have a solution for this?
