the exact mounting hole coordinates have already been posted.
Upcoming board revision
Two 2.5mm (drilled 2.9mm for M2.5 screw) non plated mounting holes have been provided to assist with ATE test mounting. Positions of these holes relative to the bottom left of the PCB (Power Input Corner) are:
Corner: 0.0mm,0.0mm
First Mount: 25.5mm,18.0mm
Second Mount: 80.1mm, 43.6mm
My two RPi boards, from different batches measure 84.99 x 56.00 mm and 84.99 x 55.93 mm so I think you can say they are "supposed" to be 85 x 56 mm but of course there is some variation due to router tool accuracy so you cannot count on a consistent size at the 10 micron level. I am using calipers, not a ruler.
