rpiMike
Re: How to setup Minecraft 1.12.1 on Raspberry Pi 3
Mon Nov 06, 2017 4:21 pm
Are you on a Pi3 running the latest Raspbian Stretch ? Did you get glxgears running at 60fps ? Any more detail in the log?
terminallyToreador
Thu Nov 09, 2017 10:50 pm
The link gives me a 404 error message
rpiMike
Fri Nov 10, 2017 8:04 am
Which link ?
Kurzov
Contact: Twitter
Tue Nov 14, 2017 2:00 am
Well, this is a conundrum.
I have a 2B Model Pi (Raspberry Pi 3), I've installed 1.12.2 for both Minecraft and OptiFine - I've updated the LWJGL to the latest stable build, and I keep getting two different errors.
When I do NOT use OptiFine:
Exception in thread "main" java.lang.UnsatisifiedLinkError: (home directory)/.minecraft/versions/1.12.2/1.12.2-(natives folder)/liblwjgl.so [...]
 Cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on an ARM-bit platform)
When I do use OptiFine:
[main/ERROR]: Unable to launch
java.lang.reflect.InvocationTargetException: null
What do I do now?
~ Kurzov
Kurze, kurze~
Newbie at Pi. May be inactive for long periods of time.
rpiMike
Tue Nov 14, 2017 12:19 pm
Are you using runOptifine1_12_2.sh that I provided on page 4 of this thread ? If so are you using OptiFine-1.12.2_HD_U_C5.jar ?
Kurzov
Contact: Twitter
Tue Nov 14, 2017 12:26 pm
Yes to both.
Kurze, kurze~
rpiMike
Tue Nov 14, 2017 2:24 pm
I've retested this on a fresh sd card and all worked fine. I'm assuming your using Raspbian Stretch and logged in as user 'pi' ?
What does the following return :
ls ~/.minecraft/libraries/optifine/OptiFine/
I can only think that you have missed a step.
yfaykya
Tue Nov 14, 2017 8:46 pm
Hi - great resource! Thanks!
My 6 year old wants minecraft from Santa so I was going to set this up. I was wondering what controller I should get? We have no console in the house so she is not used to anything in particular. If there was something minecraft themed then all the better! Ho ho ho!
rpiMike
Tue Nov 14, 2017 8:50 pm
I've only ever used keyboard and mouse for Minecraft on a PC or Pi. Maybe someone else reading this thread has tried other controllers.
Don't forget this is pushing the Pi to its limits - so can crash occasionally.
Kurzov
Contact: Twitter
Wed Nov 15, 2017 1:58 am
It returns:
1.12.2_HD_U_C5
Kurze, kurze~
rpiMike
Wed Nov 15, 2017 1:39 pm
Thats right. Have you looked at the video tutorial to see if you missed something ?
Kurzov
Contact: Twitter
Wed Nov 15, 2017 10:50 pm
It seems that I've followed all the steps...
Although, the gears application only brings back from 40-45 FPS, but that has nothing to do with any library problems, I assume?
Also, would I have to download an earlier version of LWJGL? I installed the latest stable version.
Kurze, kurze~
rpiMike
Wed Nov 15, 2017 11:00 pm
That could be the problem, I've not updated LWJGL on my Pi3.
glxgears should run at close to 60fps if OpenGL is working.
trnt
Sat Dec 02, 2017 8:12 am
I only get this:
./runOptifine1_12_1.sh
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 439 100 265 100 174 662 434 --:--:-- --:--:-- --:--:-- 664
todays access token = dfaa674015df47bb9070a6626c5e2ab8
100 73 100 62 100 11 231 41 --:--:-- --:--:-- --:--:-- 231
MINECRAFT_UUID=2c6f9b7607e049e6bad121952e583aea
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Fehler: Hauptklasse net.minecraft.launchwrapper.Launch konnte nicht gefunden oder geladen werden
Why?
rpiMike
Sat Dec 02, 2017 6:30 pm
When you installed Minecraft with 'java -jar Minecraft.jar', did you click 'edit profile' and select use release - 'release 1.12.1', then 'save profile' ?
Xynus
Mon Dec 11, 2017 1:03 am
100 436 100 271 100 165 352 214 --:--:-- --:--:-- --:--:-- 352
todays access token = e163ee5d65e74bd09a6645ee13907fc9
100 79 100 65 100 14 96 20 --:--:-- --:--:-- --:--:-- 96
MINECRAFT_UUID=c1152dec519f45209e8c1abc70c85241
./runOptifine1_12_1.sh: 52: ./runOptifine1_12_1.sh: /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java: not found
Has anyone else gotten this error? I can't seem to get past it
rpiMike
Mon Dec 11, 2017 11:44 am
Are you running the latest Raspbian Stretch with Desktop ?
Xynus
Mon Dec 11, 2017 9:26 pm
I'm running Ubuntu Mate, latest with desktop.
rpiMike
Mon Dec 11, 2017 9:40 pm
I don't believe oracle java 8 is installed on Ubuntu Mate.
See this info from the old thread : viewtopic.php?f=78&t=137279&start=300#p1186185
Xynus
Mon Dec 11, 2017 10:46 pm
Well, I've certainly gotten much farther, but now whenever I try to join hypixel, my game just crashes lol
[17:41:02] [main/INFO]: Connecting to mc.hypixel.net, 25565
Java HotSpot(TM) Client VM warning: You have loaded library /tmp/libnetty-transport-native-epoll9034611418377695069.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Killed
Edit: Also kills on single player with no warning.
<My Username>] logged in with entity id 685 at (-229.5, 69.0, 243.5)
[17:54:16] [Server thread/INFO]:<Again, my username> joined the game
Killed
Edit II: I've come to realize that the killed process has nothing to do with the error in the multiplayer readout, as I've gotten this error before as far as I can see and it worked just fine
jdonald
Tue Dec 12, 2017 5:11 am
This error message literally means your liblwjgl.so was compiled for Intel x86. If you aren't using the one linked on the first page, you need to make sure you download the one for ARM 32-bit, not IA 32-bit.
Xynus
Tue Dec 12, 2017 10:16 pm
Hoping this will help with my problem lol
[17:13:59] [main/INFO]: [OptiFine] *** Reflector Forge ***
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.Attributes
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: mods.betterfoliage.client.BetterFoliageClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.asm.transformers.BlamingTransformer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.ChunkWatchEvent$UnWatch
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.relauncher.CoreModManager
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.DimensionManager
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.GuiScreenEvent$DrawScreenEvent$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$CameraSetup
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$FogColors
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.EntityViewRenderEvent$RenderFogEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.EventBus
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.eventhandler.Event$Result
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.ExtendedBlockState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.FMLClientHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.common.FMLCommonHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: anh.getWaterColorMultiplier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addDestroyEffects
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.addHitEffects
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canCreatureSpawn
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.canRenderInLayer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.doesSideBlockRendering
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getBedDirection
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getExtendedState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getFogColor
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightOpacity
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getLightValue
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.getSoundType
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.hasTileEntity
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isAir
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBed
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isBedFoot
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aow.isSideSolid
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: and.isSideSolid
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.canRiderInteract
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.captureDrops
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: vg.capturedDrops
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRenderInPass
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: vg.shouldRiderSit
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.ForgeEventFactory
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeHooks
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ForgeHooksClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Field not present: ain.delegate
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getDurabilityForDisplay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.getRGBDurabilityForDisplay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.isShield
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.onEntitySwing
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.shouldCauseReequipAnimation
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ain.showDurabilityBar
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bwa.handleItemState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: agv.hasOverlay
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyConflictContext
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.setKeyModifierAndCode
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bhy.getKeyModifier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.ForgeModContainer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: bvv.parseFromReader
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.shouldRenderHUD
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: uz.renderHUDEffect
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: va.isCurativeItem
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.canRenderBreaking
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.getRenderBoundingBox
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.hasFastRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: avj.shouldRenderInPass
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.preDraw
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: ceb$b.postDraw
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.countEntities
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.getPerWorldStorage
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: amu.initCapabilities
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getCloudRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getSkyRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Method not present: aym.getWeatherRenderer
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.GuiModList
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.property.IExtendedBlockState
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.IModel
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.IRenderHandler
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.ItemModelMesherForge
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyConflictContext
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.settings.KeyModifier
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.pipeline.LightUtil
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.common.MinecraftForge
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.MinecraftForgeClient
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.model.ModelLoader
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.gui.NotificationModUpdateScreen
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderBlockOverlayEvent$OverlayType
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.registry.RenderingRegistry
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderItemInFrameEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Pre
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.RenderLivingEvent$Specials$Post
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.client.event.ScreenshotEvent
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.fml.client.SplashProgress
[17:13:59] [main/INFO]: [OptiFine] (Reflector) Class not present: net.minecraftforge.event.world.WorldEvent$Load
[17:13:59] [main/INFO]: [OptiFine] *** Reflector Vanilla ***
[17:14:00] [main/INFO]: LWJGL Version: 2.9.4
[17:14:02] [main/INFO]: [OptiFine]
[17:14:02] [main/INFO]: [OptiFine] OptiFine_1.12.1_HD_U_C5
[17:14:02] [main/INFO]: [OptiFine] Build: 20170807-181132
[17:14:02] [main/INFO]: [OptiFine] OS: Linux (arm) version 4.4.38-v7+
[17:14:02] [main/INFO]: [OptiFine] Java: 1.8.0_151, Oracle Corporation
[17:14:02] [main/INFO]: [OptiFine] VM: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
[17:14:02] [main/INFO]: [OptiFine] LWJGL: 2.9.4
[17:14:02] [main/INFO]: [OptiFine] OpenGL: Gallium 0.4 on VC4 V3D 2.1, version 2.1 Mesa 17.0.7, Broadcom
[17:14:02] [main/INFO]: [OptiFine] OpenGL Version: 2.1.0
[17:14:02] [main/INFO]: [OptiFine] Maximum texture size: 2048x2048
[17:14:02] [Thread-3/INFO]: [OptiFine] Checking for new version
[17:14:02] [main/INFO]: [Shaders] ShadersMod version: 2.4.12
[17:14:02] [main/INFO]: [Shaders] OpenGL Version: 2.1 Mesa 17.0.7
[17:14:02] [main/INFO]: [Shaders] Vendor: Broadcom
[17:14:02] [main/INFO]: [Shaders] Renderer: Gallium 0.4 on VC4 V3D 2.1
[17:14:02] [main/INFO]: [Shaders] Capabilities: 2.0 2.1 - - -
[17:14:02] [main/INFO]: [Shaders] GL_MAX_DRAW_BUFFERS: 1
[17:14:02] [main/INFO]: [Shaders] GL_MAX_COLOR_ATTACHMENTS_EXT: 1
[17:14:02] [main/INFO]: [Shaders] GL_MAX_TEXTURE_IMAGE_UNITS: 16
[17:14:02] [main/INFO]: [Shaders] Load ShadersMod configuration.
[17:14:02] [main/INFO]: [Shaders] Save ShadersMod configuration.
[17:14:02] [main/INFO]: [Shaders] Shaders can not be loaded, Fast Render is enabled.
[17:14:02] [main/INFO]: [Shaders] No shaderpack loaded.
[17:14:02] [main/INFO]: Reloading ResourceManager: Default
[17:14:02] [main/INFO]: [OptiFine] *** Reloading textures ***
[17:14:02] [main/INFO]: [OptiFine] Resource packs: Default
[17:14:02] [Thread-3/INFO]: [OptiFine] Version found: C6
[17:14:04] [Sound Library Loader/INFO]: Starting up SoundSystem...
[17:14:04] [Thread-4/INFO]: Initializing LWJGL OpenAL
[17:14:04] [Thread-4/INFO]: (The LWJGL binding of OpenAL. For more information, see http://www.lwjgl.org)
[17:14:04] [Thread-4/INFO]: OpenAL initialized.
[17:14:05] [Sound Library Loader/INFO]: Sound engine started
[17:14:12] [main/INFO]: [OptiFine] Mipmap levels: 4
[17:14:12] [main/INFO]: [OptiFine] Multitexture: false
[17:14:12] [main/INFO]: [OptiFine] BetterGrass: Parsing default configuration optifine/bettergrass.properties
[17:14:16] [main/INFO]: Created: 512x512 textures-atlas
[17:14:20] [main/WARN]: ERROR : Couldn't load Narrator library : Unable to load library 'fliteWrapper': Native library (linux-arm/libfliteWrapper.so) not found in resource path ([file:/home/xynus/.minecraft/libraries/optifine/OptiFine/1.12.1_HD_U_C5/OptiFine-1.12.1_HD_U_C5.jar, file:/home/xynus/.minecraft/libraries/net/minecraft/launchwrapper/1.12/launchwrapper-1.12.jar, file:/home/xynus/.minecraft/libraries/com/mojang/patchy/1.1/patchy-1.1.jar, file:/home/xynus/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar, file:/home/xynus/.minecraft/libraries/net/java/dev/jna/jna/4.4.0/jna-4.4.0.jar, file:/home/xynus/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar, file:/home/xynus/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar, file:/home/xynus/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/5.0.3/jopt-simple-5.0.3.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar, file:/home/xynus/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar, file:/home/xynus/.minecraft/libraries/io/netty/netty-all/4.1.9.Final/netty-all-4.1.9.Final.jar, file:/home/xynus/.minecraft/libraries/com/google/guava/guava/21.0/guava-21.0.jar, file:/home/xynus/.minecraft/libraries/org/apache/commons/commons-lang3/3.5/commons-lang3-3.5.jar, file:/home/xynus/.minecraft/libraries/commons-io/commons-io/2.5/commons-io-2.5.jar, file:/home/xynus/.minecraft/libraries/commons-codec/commons-codec/1.10/commons-codec-1.10.jar, file:/home/xynus/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar, file:/home/xynus/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar, file:/home/xynus/.minecraft/libraries/com/google/code/gson/gson/2.8.0/gson-2.8.0.jar, file:/home/xynus/.minecraft/libraries/com/mojang/authlib/1.5.25/authlib-1.5.25.jar, file:/home/xynus/.minecraft/libraries/com/mojang/realms/1.10.17/realms-1.10.17.jar, file:/home/xynus/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar, file:/home/xynus/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar, file:/home/xynus/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar, file:/home/xynus/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar, file:/home/xynus/.minecraft/libraries/it/unimi/dsi/fastutil/7.1.0/fastutil-7.1.0.jar, file:/home/xynus/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.8.1/log4j-api-2.8.1.jar, file:/home/xynus/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.8.1/log4j-core-2.8.1.jar, file:/home/xynus/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar, file:/home/xynus/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar, file:/home/xynus/.minecraft/libraries/com/mojang/text2speech/1.10.3/text2speech-1.10.3.jar, file:/home/xynus/.minecraft/versions/1.12.1-OptiFine_HD_U_C5/1.12.1-OptiFine_HD_U_C5.jar])
[17:14:21] [main/INFO]: [OptiFine] *** Reloading custom textures ***
Xynus
Wed Dec 13, 2017 2:13 am
I finally got it running! It turns out it had something to do with the maximum ram value in the .sh, so i cranked it down from 1024 to 512, and it runs!
VeraDra
Sun Dec 17, 2017 7:35 pm
Xynus wrote: I finally got it running! It turns out it had something to do with the maximum ram value in the .sh, so i cranked it down from 1024 to 512, and it runs!
That's because the RPi 3 only has about 1000 MB of RAM.
Dedicating it all to MC is equivalent to wondering why your PC won't boot when you remove all the RAM from your computer.
Xynus
Thu Dec 21, 2017 12:09 am
Well, now I'm going through new issues on Stretch >.> Whenever I run the 1.12.1 script with optifine, I get this;
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:-- 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--100 436 100 271 100 165 682 415 --:--:-- --:--:-- --:--:-- 682
todays access token = 6b82cfa27531406da09dbfc3f03a0847
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--100 79 100 65 100 14 198 42 --:--:-- --:--:-- --:--:-- 199
[00:06:38] [main/INFO]: Loading tweak class name optifine.OptiFineTweaker
[00:06:38] [main/ERROR]: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_65]
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:1.8.0_65]
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:106) ~[launchwrapper-1.12.jar:?]
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_65]
at java.lang.Class.forName(Class.java:348) ~[?:1.8.0_65]
at net.minecraft.launchwrapper.Launch.launch(Launch.java:98) [launchwrapper-1.12.jar:?]
at net.minecraft.launchwrapper.Launch.main(Launch.java:28) [launchwrapper-1.12.jar:?]
Has this been discussed before?
Return to “Gaming”
