pilot_ngb
Issues with formatting Micro SD Card
Mon Jun 19, 2017 4:22 pm
I am trying to use Win32DiskImager to upload a new image to my microSD card. I am doing this on a Windows 7 64 bit PC. The image does get uploaded, however the old image is not getting removed. My understanding is that the old image is formatted prior to the new image being read to the card when using Win32DiskImager. Is this correct?
I've tried to format the card using SDFormatter but the sofware is saying that the card is write protected. I am using a holder for the microSD card so that it will fit into a standard SD slot on my PC but despite moving the button on the left the of reader, it is still saying write protected. Any ideas?
Thanks,
Neil
FTrevorGowen
Re: Issues with formatting Micro SD Card
Mon Jun 19, 2017 7:55 pm
pilot_ngb wrote:Hello,
Thanks,
Neil
You're correct that Win32DiskImager does not need the uSDHC card to be formatted before its use. However the currently preferred tool for writing *.img files is Etcher: https://www.raspberrypi.org/documentati ... /README.md
Occasionally a uSDHC may "end up" becoming read-only (as far as Windows is concerned). Sometimes this is a permanent failure or a "possibly recoverable" issue - two things to try a) if you have a USB-based card reader/writer, try that (not all built-in card slot are fully uSDHC ccompatible) b) if a) failed but you have (access to) a Digital Camera try its "formatting" option. If its still "read only" then it's time for a new one (they do wear out).
Trev.
Still running Raspbian Jessie on some older Pi's (an A, B1, B2, B+, P2B, 3xP0, P0W) but Stretch on my 2xP3A+, P3B+, P3B, B+, A+ and a B2. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
pilot_ngb
Mon Jun 19, 2017 11:07 pm
I've tried Etcher and it comes up with a message "You're not authorized to perfom this operation." Time for me to order a new card I think.
What is strange is that I am able to write the new image to the drive (using Win32DiskImager) but not format the drive.
Time for me to order a new card I think. Thanks for your help.
KLL
Tue Jun 20, 2017 12:17 am
pilot_ngb wrote:Time for me to order a new card I think.
+ even if you fix the problem with the adapter write lock
+ and your laptop card reader is not the problem
you still not able to use "RPI raspbian best feature of last year"
the SD card copier tool
so, better get a external card reader (uSD HC/XC )
i got this one: https://jib.co.th/web/index.php/product ... RA410-BLUE 5euro
slipstream42
Sat Jun 02, 2018 1:58 pm
I had this issue when trying to flash raspbian to a 32gb sandisk sd card on Win10
You're not authorized to perform this operation
Please ensure you have necessary permissions for this task
Fixed by temporarily turning off Win 10 Controlled File Access
open windows defender
open virus & threat protection
open ransomware protection
turn off controlled file access
Etcher was able to flash the raspbian image to the sd card
turn controlled file access back on
drgeoff
Sat Jun 02, 2018 3:40 pm
Neither the card nor the old image is formatted prior to the new image being written to the card. The old image (which includes the partition table and file systems) is overwritten by the partition table and file systems of the new image.
That the old image is not being removed is a sure sign that despite the image being "uploaded" it is not being written to the card. Possible reasons have been given in the other replies.
ccriley613
Tue Oct 23, 2018 1:59 am
This needs to be moved to the top! The Ransom ware protection was my issue. Tried so many solutions before finding this. Figured it was a security setting, but looked past this one.
Thanks!
