deejay01
Openelec filesystem corruption
Wed Jun 14, 2017 12:46 pm
When I turn on my Raspberry Pi 2 Model B I get the following error message:
Filesystem corruption has been detected
To prevent an automatic repair attempt continuing press any key or power off your system within the next 120 seconds
repairing filesystem...
CP437: Invalid argument
fsck.fat 3.0.28 (2015-05-16)
e2fsck 1.42.13 (17-May-2015)
/dev/mmcblk0p7: 169 files, 32798/40915 clusters
/dev/mmcblk0p8: recovering journal
fsck.ext4: unable to set superblock flags on /dev/mmcblk0p8
/dev/mmcblk0p8: ******** WARNING: Filesystem still has errors ********
Forced fsck failed. Your system is broken beyond repair
Please re-install OpenELEC
Press enter to shutdown now
Could someone please tell me the best way to re-install OpenELEC. I can still reboot into raspbian and I'm hoping that means I don't have to reformat the sd card and lose the other software that I have installed.
Thanks in advance...
Re: Openelec filesystem corruption
Wed Jun 14, 2017 4:06 pm
Your only option is a new SDCard. You can't replace individual parts of a NOOBS system without trashing the whole NOOBS set-up.
deejay01
Thu Jun 15, 2017 1:20 am
Is it possible to just format the sd card (using, for example, the SDformatter utility in Windows) rather than buy a new one?
rpdom
Thu Jun 15, 2017 4:50 am
deejay01 wrote:Is it possible to just format the sd card (using, for example, the SDformatter utility in Windows) rather than buy a new one?
Yes, but using that method would lose your existing Raspbian installation. By installing on a new card you would be able to copy your work from the old Raspbian to the new one - and then you would have a spare card to use for making backups.
