Makogan
USB peripherals in bare metal?
Tue Jun 13, 2017 6:43 pm
First, I apologize for posting so much asking for help. I have 2 weeks left to do as much as I can in this project, so I am very desperate, thank you for your patience.
How exactly would I go about integrating USB peripherals into my code. For practical purposes, let's say I have an Xbox controller, how would I go about knowing when and which button is pressed. If an xbox controller is too complicated then any other common USB peripheral works.
dwelch67
Re: USB peripherals in bare metal?
Tue Jun 13, 2017 9:15 pm
this is the massive one, two weeks is probably not enough if you want to do it yourself. circle I think is what I am remembering, someone here probably more than one someone here has baremetal usb code, you might be able to get it pulled in and working in time...much easier to just use a serial port and dumb terminal (and the dumb terminal has complete keyboard/display support and all you need to do on your side is uart/serial characters).
Makogan
Tue Jun 13, 2017 9:27 pm
hmmm, that is a problem. The purpose of the project is no external libraries that do "OS" things for you, things like math, scheduling algorithms, font things like true type, are fine but memory management, hardware initialisation, I/O management I am supposed to do myself, it is not a problem to read and check someone else's code as long as I properly credit them,, but the implementation I have to do myself. I'll try and look around for anything, see if I can get things working.
Gavinmc42
Wed Jun 14, 2017 1:35 am
Baremetal USB has been done a few times, mostly for Mouse, Keyboard, MSD.
Look in the sticky
Anything else and you are pretty much on your own.
2 Weeks and in a hurry? hmm, you would not be a student by any chance?
From scratch, baremetal USB anything, allow 6+ months, if you have zero USB experience.
So is this VC4 baremetal or ARM baremetal. one could take ten times longer than the other.
I'm dancing on Rainbows.
Makogan
Wed Jun 14, 2017 2:02 am
Yup as you guessed, I am a student, and one that got abandoned at that (out of 3 people taking the class everybody but me dropped, so I am now juggling a 3 man job on my own :C) and the class I am taking is very self directed, so I am also on my own for that.
Gavinmc42
Wed Jun 14, 2017 5:20 am
So the others are the smart ones and figured out how hard it was going to be :lol:
Not many choices, not many have made it to USB driver stage
http://www.cl.cam.ac.uk/projects/raspbe ... orials/os/
https://ultibo.org/
https://github.com/rsta2/circle
LdB
Wed Jun 14, 2017 7:53 am
Ask and you shall receive :-)
I offer the simplest baremetal USB you can just about do. It is my redux of CSUD to the nth degree in a single file USB.C.
No malloc required the driver blocks allocate static driver array blocks at startup.
It is reasonably well documented but as it is using only the control channel even for the HID comms not suitable if you wanted to do disk IO or anything heavy. It will however give you the basics of enumerating the bus, HID and what the fake host does.
I used it as a launch point to write a proper interrupt based USB system.
To try it so you get the idea put the files in the diskimg directory on your baremetal SD card. Plug in a mouse in the USB port and start it up. It has the most up todate firmware on it (I made sure after the other day) :-)
Download from
http://dropcanvas.com/24j23oEGhRw957
All being equal it should display something like
I am guessing the X-Box controller will report as a HID and you should be able to see it and use it ;-)
Wed Jun 14, 2017 8:27 am
Makogan wrote:Yup as you guessed, I am a student, and one that got abandoned at that (out of 3 people taking the class everybody but me dropped, so I am now juggling a 3 man job on my own :C) and the class I am taking is very self directed, so I am also on my own for that.
You need to talk to your lecturer. Bare metal USB code, as stated above, is a 1/2 man year project for someone who knows about USB, unless you use someone else's libraries. So I cannot believe the lecturer is expecting this level of work. Find out what the actual requirements for your project are.
Gavinmc42
Wed Jun 14, 2017 9:07 am
I really do need a baremetal wireless USB Xbox/PS gamepad driver for my Ultibo bots :(
It is on my list below the Zero Wifi/BT driver, above the baremetal camera driver. :lol:
moahrs
Tue Nov 13, 2018 6:52 pm
LDB,
can you post again your usb.c, plz ? The site is not working anymore: http://dropcanvas.com/24j23oEGhRw957
ty a lot
Moacir Jr.
Download from
bzt
Wed Nov 14, 2018 11:14 am
LDB,
ty a lot
Moacir Jr.
Have you tried his git repo? https://github.com/LdB-ECM/Raspberry-Pi ... m32_64_USB
Also I think what he meant by "reasonably well documented" is that his code is full of comments but you have to have some understanding on the USB for those comments to make any sense to you. Even though @LdB did an awesome job to create a library out of it, I think you shouldn't use his code blindly. Do yourself a favour, read some documentation, learn the USB basics, match that with LdB's code, look for the relevant comments before you integrate it.
(I'd like to point out this advice is not specific to the USB code, you should do this with all low-level libraries. Blindly copy'n'pasting code together without any understanding may work for some high level languages, but definitely will fail for low-level applications.)
As for the OP, I also think you should talk to your lecturer, your goal seems insane. Maybe some genius can do that if they live on coffee and pizza for two weeks without sleeping, but that's totally irrealistic to expect that.
Cheers,
bzt
LdB
Wed Nov 14, 2018 6:07 pm
As bzt said it's on the GitHub site :-)
Looking at your original post you said you wanted to mess around and understand interrupts.
If you work your way thru the following samples you should get it all.
1.) The old blinking activity led every second or so is the easiest way to start
https://github.com/LdB-ECM/Raspberry-Pi ... /myBlinker
2.) Then you can move up to taking an interrupt on a core other than 0 in this case Core 3
https://github.com/LdB-ECM/Raspberry-Pi ... 3Interrupt
3.) Finally you can look at taking all interrupt sources into a context switcher on a RTOS
https://github.com/LdB-ECM/Raspberry-Pi ... r/FreeRTOS
All 73 interrupt sources are covered on the RTOS system which is an extension of the
XINU interrupt handler. It adds routing core interrupts (datasheet QA7) to the basic XINU
code as they never allowed for multicore operation. This is the basic handler code ....
void irqHandler(void)
	uint32_t ulMaskedStatus = (*BCM2835_INTC_IRQ_BASIC);
	// Bit 8 in IRQBasic indicates interrupts in Pending1 (interrupts 31-0):
	if (ulMaskedStatus & (1UL << 8))
		handleRange((*BCM2835_IRQ_PENDING1) & enabled[0], 0);
	// Bit 9 in IRQBasic indicates interrupts in Pending2 (interrupts 63-32):
	if (ulMaskedStatus & (1UL << 9))
		handleRange((*BCM2835_IRQ_PENDING2) & enabled[1], 32);
	// Bits 7 through 0 in IRQBasic represent interrupts 64-71:
	if (ulMaskedStatus & 0xFF) {
		handleRange(ulMaskedStatus & 0xFF & enabled[2], 64);
	// We can get interrupts without any source set from a core interrupt
	// routed as per data sheet QA7. After handling all bit id interrupts
	// we need to check core interrupts if a core irq handler exists
	if (Core_Irq.pfnHandler)
		Core_Irq.pfnHandler(Core_Irq.pFCB, 0, Core_Irq.pParam);
