montypython76
"lp: not allowed to print" when using a python script
Sun Jun 11, 2017 2:40 pm
Hi there,
I hve an issue printing a textfile with a python script. The script is simple:
import os
os.system('lp "testdatei.txt"')
But instead of a clean print I get the error above. Tried also with "sudo". Using 'lp "testdatei.txt"' directly in a terminal windows works perfectly. Even using the code above within the python interactive mode works, but not as a script. User "pi" is in the lp group. I have no idea were the right problem exists.
davef21370
Re: "lp: not allowed to print" when using a python script
Sun Jun 11, 2017 3:31 pm
Use subprocess instead.
Dave.
Apple say... Monkey do !!
montypython76
Mon Jun 12, 2017 12:16 pm
Testet the following, but got the same error message:
subprocess.Popen(['lp','alarm.txt'])
montypython76
Mon Jun 12, 2017 6:22 pm
Found the solution:
1. I installed the package "cups-bsd" to try the correct "lpr" command. But this also turns out the error message.
2. I changed the code to explicitly set the user pi for the printjob:
os.system ('lpr -U pi testdatei.txt')
Voila... works.
Return to “Python”
