timmoore46
Getting DosBox to work - HELP !
Sun Jun 11, 2017 12:31 pm
I'm used to Ubuntu so I followed the procedure and it normally works....
I use terminal to create the necessary files viz;-
home/pi/dos/c/application.exe
using $ mkdir -p ~/dos/c
also down load dosbox with:-
sudo apt-get install dosbox
which works fine,
then at the pi$ prompt;-
dosbox
and Z: appears on the screen with lots of expected banner stuff.
But 'Oh Dear' the keyboard has given up ! With the back space yields '5' and then locks up !
What do I do next ?
Any thoughts most welcome !
A puzzled,
Tim
Re: Getting DosBox to work - HELP !
Sun Jun 11, 2017 3:44 pm
timmoore46 wrote:I'm used to Ubuntu so I followed the procedure and it normally works....
which works fine,
dosbox
What do I do next ?
A puzzled,
Tim
Actually you may be better off with a pre-configured Raspbian Jessie with emulators like RetroPie:
https://retropie.org.uk/about/systems/
FYI this forum has a Gaming Section which likely covers your issues
RPi 4B 4GB (SSD Boot)..
