I have trouble getting 2 of my DVB-T dongles (Hauppauge Nova-TD Stick) to work together on my USB Hub AFTER A REBOOT.
They work perfectly one by one on the HUB but not both at the same time, in this case only one is working, the driver of the second failed to load
All other DVB dongles using different tuners chip are not impacted at all and work perfectly regardless of the Nova-TD dongle being both plugged or not.
Let me insist that the issue appear after a reboot (through SSH), if I plugged both dongle when system is alive then the driver is correctly loaded.
dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.30-v7+ (pi@PIgpsTVfm) (gcc version 4.9.2 (Raspbian 4.9.2-10) ) #1 SMP Sat Jun 3 21:00:14 CEST 2017
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x36800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 225280
[ 0.000000] free_area_init_node: node 0, pgdat 80c6edc0, node_mem_map b603a000
[ 0.000000] Normal zone: 1980 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 225280 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 14 pages/cpu @b5ff4000 s25600 r8192 d23552 u57344
[ 0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 223300
[ 0.000000] Kernel command line: 8250.nr_uarts=1 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.fiq_enable=0 dwc_otg.fiq_fsm_enable=0 dwc_otg.nak_holdoff=0 dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=57347952-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 871340K/901120K available (7168K kernel code, 483K rwdata, 2012K rodata, 1024K init, 778K bss, 21588K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xb7800000 - 0xff800000 (1152 MB)
lowmem : 0x80000000 - 0xb7000000 ( 880 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x80800000 (8160 kB)
.init : 0x80b00000 - 0x80c00000 (1024 kB)
.data : 0x80c00000 - 0x80c78f94 ( 484 kB)
.bss : 0x80c7a000 - 0x80d3ca64 ( 779 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000326] Console: colour dummy device 80x30
[ 0.000345] console [tty1] enabled
[ 0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000391] pid_max: default: 32768 minimum: 301
[ 0.000724] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000734] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001727] Disabling cpuset control group subsystem
[ 0.001888] CPU: Testing write buffer coherency: ok
[ 0.001930] ftrace: allocating 22386 entries in 66 pages
[ 0.053075] CPU0: update cpu_capacity 1024
[ 0.053094] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.053172] Setting up static identity map for 0x100000 - 0x100034
[ 0.055297] CPU1: update cpu_capacity 1024
[ 0.055305] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.055965] CPU2: update cpu_capacity 1024
[ 0.055971] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.056590] CPU3: update cpu_capacity 1024
[ 0.056597] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.056681] Brought up 4 CPUs
[ 0.056692] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.056696] CPU: All CPU(s) started in HYP mode.
[ 0.056700] CPU: Virtualization extensions available.
[ 0.057490] devtmpfs: initialized
[ 0.068932] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.069199] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.069216] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.069753] pinctrl core: initialized pinctrl subsystem
[ 0.070648] NET: Registered protocol family 16
[ 0.073056] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.081976] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.081981] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.082129] Serial: AMBA PL011 UART driver
[ 0.084131] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.084657] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.084967] irq: no irq domain found for /soc/aux@0x7e215000 !
[ 0.153714] bcm2835-dma 3f007000.dma: DMA legacy API manager at b780f000, dmachans=0x1
[ 0.155516] SCSI subsystem initialized
[ 0.155670] usbcore: registered new interface driver usbfs
[ 0.155744] usbcore: registered new interface driver hub
[ 0.155833] usbcore: registered new device driver usb
[ 0.162612] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-04-27 17:19
[ 0.164128] clocksource: Switched to clocksource arch_sys_counter
[ 0.210557] VFS: Disk quotas dquot_6.6.0
[ 0.210635] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.210830] FS-Cache: Loaded
[ 0.211077] CacheFiles: Loaded
[ 0.223242] NET: Registered protocol family 2
[ 0.224107] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.224257] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.224442] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.224531] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.224572] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.224781] NET: Registered protocol family 1
[ 0.225193] RPC: Registered named UNIX socket transport module.
[ 0.225198] RPC: Registered udp transport module.
[ 0.225202] RPC: Registered tcp transport module.
[ 0.225207] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.226300] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.228563] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 0.244531] FS-Cache: Netfs 'nfs' registered for caching
[ 0.245491] NFS: Registering the id_resolver key type
[ 0.245521] Key type id_resolver registered
[ 0.245525] Key type id_legacy registered
[ 0.247939] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 0.248045] io scheduler noop registered
[ 0.248051] io scheduler deadline registered (default)
[ 0.248347] io scheduler cfq registered
[ 0.253929] BCM2708FB: allocated DMA memory f6910000
[ 0.253950] BCM2708FB: allocated DMA channel 0 @ b780f000
[ 0.313576] Console: switching to colour frame buffer device 240x67
[ 0.347722] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.349338] bcm2835-aux-uart 3f215040.serial: could not get clk: -517
[ 0.350595] bcm2835-rng 3f104000.rng: hwrng registered
[ 0.350700] vc-cma: Videocore CMA driver
[ 0.350706] vc-cma: vc_cma_base = 0x00000000
[ 0.350712] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.350717] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.350913] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.366449] brd: module loaded
[ 0.375398] loop: module loaded
[ 0.375410] Loading iSCSI transport class v2.0-870.
[ 0.375956] usbcore: registered new interface driver smsc95xx
[ 0.375970] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.602046] Core Release: 2.80a
[ 0.602054] Setting default values for core params
[ 0.602087] Finished setting default values for core params
[ 0.802481] Using Buffer DMA mode
[ 0.802486] Periodic Transfer Interrupt Enhancement - disabled
[ 0.802491] Multiprocessor Interrupt Enhancement - disabled
[ 0.802497] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 0.802511] Dedicated Tx FIFOs mode
[ 0.802825] dwc_otg: Microframe scheduler enabled
[ 0.802887] dwc_otg 3f980000.usb: DWC OTG Controller
[ 0.802923] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 0.802955] dwc_otg 3f980000.usb: irq 39, io mem 0x00000000
[ 0.803004] Init: Port Power? op_state=1
[ 0.803009] Init: Power Port (0)
[ 0.803215] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.803225] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.803234] usb usb1: Product: DWC OTG Controller
[ 0.803241] usb usb1: Manufacturer: Linux 4.9.30-v7+ dwc_otg_hcd
[ 0.803249] usb usb1: SerialNumber: 3f980000.usb
[ 0.804086] hub 1-0:1.0: USB hub found
[ 0.804163] hub 1-0:1.0: 1 port detected
[ 0.804874] dwc_otg: FIQ disabled
[ 0.804879] dwc_otg: NAK holdoff disabled
[ 0.804883] dwc_otg: FIQ split-transaction FSM disabled
[ 0.804897] Module dwc_common_port init
[ 0.805147] usbcore: registered new interface driver usb-storage
[ 0.805366] mousedev: PS/2 mouse device common for all mice
[ 0.806314] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 0.806581] bcm2835-cpufreq: min=600000 max=1200000
[ 0.806983] sdhci: Secure Digital Host Controller Interface driver
[ 0.806987] sdhci: Copyright(c) Pierre Ossman
[ 0.807286] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
[ 0.807486] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.814791] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.814925] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.815110] usbcore: registered new interface driver usbhid
[ 0.815115] usbhid: USB HID core driver
[ 0.815997] vchiq: vchiq_init_state: slot_zero = 0xb6980000, is_master = 0
[ 0.823302] Initializing XFRM netlink socket
[ 0.823327] NET: Registered protocol family 17
[ 0.823436] Key type dns_resolver registered
[ 0.823987] Registering SWP/SWPB emulation handler
[ 0.824768] registered taskstats version 1
[ 0.825125] vc-sm: Videocore shared memory driver
[ 0.825135] [vc_sm_connected_init]: start
[ 0.832745] [vc_sm_connected_init]: end - returning 0
[ 0.837841] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 0.840399] 3f215040.serial: ttyS0 at MMIO 0x0 (irq = 220, base_baud = 50000000) is a 16550
[ 0.841062] sdhost: log_buf @ b6904000 (f6904000)
[ 0.914160] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 0.914250] of_cfs_init
[ 0.914337] of_cfs_init: OK
[ 0.914834] Waiting for root device PARTUUID=57347952-02...
[ 1.024229] Indeed it is in host mode hprt0 = 00021501
[ 1.094216] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.097143] mmc0: overclocking to 100000000Hz
[ 1.097225] mmc0: new high speed SDHC card at address aaaa
[ 1.097869] mmcblk0: mmc0:aaaa SE32G 29.7 GiB
[ 1.099375] mmcblk0: p1 p2
[ 1.216095] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.216147] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.221587] devtmpfs: mounted
[ 1.223481] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
[ 1.224379] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.224521] Indeed it is in host mode hprt0 = 00001101
[ 1.418862] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.423561] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 1.423923] systemd[1]: Detected architecture 'arm'.
[ 1.454448] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.454460] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.455287] hub 1-1:1.0: USB hub found
[ 1.455374] hub 1-1:1.0: 5 ports detected
[ 1.501784] NET: Registered protocol family 10
[ 1.503271] systemd[1]: Inserted module 'ipv6'
[ 1.506533] systemd[1]: Set hostname to <PIgpsTVfm>.
[ 1.506732] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.506765] systemd[1]: Initializing machine ID from random generator.
[ 1.506991] systemd[1]: Installed transient /etc/machine-id file.
[ 1.577130] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read)
[ 1.658828] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.660143] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.661573] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.677362] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.678106] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.678254] random: systemd: uninitialized urandom read (16 bytes read)
[ 1.701277] random: fast init done
[ 1.774199] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 1.819198] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[ 1.822931] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 1.823306] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 1.823381] systemd[1]: Starting Remote File Systems (Pre).
[ 1.904887] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 1.904915] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.908204] smsc95xx v1.0.5
[ 1.962776] fuse init (API version 7.26)
[ 1.997724] i2c /dev entries driver
[ 2.001040] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:43:42:b4
[ 2.012288] pps_core: LinuxPPS API ver. 1 registered
[ 2.012298] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 2.021162] pps pps0: new PPS source pps.-1
[ 2.021261] pps pps0: Registered IRQ 184 as PPS source
[ 2.094203] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 2.193288] systemd-udevd[137]: starting version 215
[ 2.229035] usb 1-1.4: New USB device found, idVendor=2109, idProduct=2813
[ 2.229052] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.229061] usb 1-1.4: Product: USB2.0 Hub
[ 2.229069] usb 1-1.4: Manufacturer: VIA Labs, Inc.
[ 2.230163] hub 1-1.4:1.0: USB hub found
[ 2.230925] hub 1-1.4:1.0: 4 ports detected
[ 2.624255] usb 1-1.4.1: new low-speed USB device number 5 using dwc_otg
[ 2.807459] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 2.858146] random: crng init done
[ 2.980483] usb 1-1.4.1: New USB device found, idVendor=051d, idProduct=0002
[ 2.980498] usb 1-1.4.1: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 2.980507] usb 1-1.4.1: Product: Back-UPS RS 1000 FW:7.g9 .I USB FW:g9
[ 2.980515] usb 1-1.4.1: Manufacturer: American Power Conversion
[ 2.980523] usb 1-1.4.1: SerialNumber: NB0646029832
[ 3.885930] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.063040] hid-generic 0003:051D:0002.0001: hiddev0,hidraw0: USB HID v1.10 Device [American Power Conversion Back-UPS RS 1000 FW:7.g9 .I USB FW:g9 ] on usb-3f980000.usb-1.4.1/input0
[ 4.174201] usb 1-1.4.3: new high-speed USB device number 6 using dwc_otg
[ 4.315384] usb 1-1.4.3: New USB device found, idVendor=2040, idProduct=0265
[ 4.315406] usb 1-1.4.3: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 4.315416] usb 1-1.4.3: Product: dualHD
[ 4.315425] usb 1-1.4.3: Manufacturer: HCW
[ 4.315433] usb 1-1.4.3: SerialNumber: 0011559123
[ 4.367412] systemd-journald[141]: Received request to flush runtime journal from PID 1
[ 4.424207] usb 1-1.4.4: new high-speed USB device number 7 using dwc_otg
[ 4.577492] usb 1-1.4.4: New USB device found, idVendor=2109, idProduct=2813
[ 4.577502] usb 1-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.577506] usb 1-1.4.4: Product: USB2.0 Hub
[ 4.577510] usb 1-1.4.4: Manufacturer: VIA Labs, Inc.
[ 4.578517] hub 1-1.4.4:1.0: USB hub found
[ 4.579331] hub 1-1.4.4:1.0: 4 ports detected
[ 4.934142] usb 1-1.4.4.2: new high-speed USB device number 8 using dwc_otg
[ 5.085910] usb 1-1.4.4.2: New USB device found, idVendor=0bda, idProduct=2838
[ 5.085924] usb 1-1.4.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.085934] usb 1-1.4.4.2: Product: RTL2838UHIDIR
[ 5.085942] usb 1-1.4.4.2: Manufacturer: Realtek
[ 5.085950] usb 1-1.4.4.2: SerialNumber: 00000001
[ 5.204176] usb 1-1.4.4.3: new high-speed USB device number 9 using dwc_otg
[ 5.345988] usb 1-1.4.4.3: New USB device found, idVendor=2040, idProduct=5200
[ 5.346000] usb 1-1.4.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.346009] usb 1-1.4.4.3: Product: NovaT 500Stick
[ 5.346017] usb 1-1.4.4.3: Manufacturer: Hauppauge
[ 5.346024] usb 1-1.4.4.3: SerialNumber: 4035604867
[ 5.454175] usb 1-1.4.4.4: new high-speed USB device number 10 using dwc_otg
[ 5.595984] usb 1-1.4.4.4: New USB device found, idVendor=2040, idProduct=5200
[ 5.595995] usb 1-1.4.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.596005] usb 1-1.4.4.4: Product: NovaT 500Stick
[ 5.596012] usb 1-1.4.4.4: Manufacturer: Hauppauge
[ 5.596020] usb 1-1.4.4.4: SerialNumber: 4035677563
[ 5.637762] media: Linux media interface: v0.10
[ 5.658010] Linux video capture interface: v2.00
[ 5.671991] em28xx: New device HCW dualHD @ 480 Mbps (2040:0265, interface 0, class 0)
[ 5.672003] em28xx: DVB interface 0 found: isoc
[ 5.672266] em28xx: chip ID is em28174
[ 6.440666] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in warm state.
[ 6.441167] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 6.441553] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 6.727266] usb 1-1.4.4.3: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
[ 6.971850] em28174 #0: EEPROM ID = 26 00 01 00, EEPROM hash = 0xabe7c6c8
[ 6.971860] em28174 #0: EEPROM info:
[ 6.971866] em28174 #0: microcode start address = 0x0004, boot configuration = 0x01
[ 6.979081] em28174 #0: AC97 audio (5 sample rates)
[ 6.979089] em28174 #0: 500mA max power
[ 6.979099] em28174 #0: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e
[ 6.979555] em28174 #0: Identified as Hauppauge WinTV-dualHD DVB (card=99)
[ 6.985029] tveeprom 10-0050: Hauppauge model 204109, rev B3I6, serial# 11559123
[ 6.985043] tveeprom 10-0050: tuner model is SiLabs Si2157 (idx 186, type 4)
[ 6.985054] tveeprom 10-0050: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc)
[ 6.985062] tveeprom 10-0050: audio processor is None (idx 0)
[ 6.985070] tveeprom 10-0050: has no radio, has IR receiver, has no IR transmitter
[ 6.985078] em28174 #0: dvb set to isoc mode.
[ 6.985266] em28xx: chip ID is em28174
[ 6.991520] DiB0070: successfully identified
[ 6.991533] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 6.991896] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 7.172768] usb 1-1.4.4.3: DVB: registering adapter 1 frontend 0 (DiBcom 7000PC)...
[ 7.421265] DiB0070: successfully identified
[ 7.464172] Registered IR keymap rc-dib0700-rc5
[ 7.464960] input: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.3/rc/rc0/input0
[ 7.464992] rc rc0: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.3/rc/rc0
[ 7.465131] dvb-usb: schedule remote query interval to 50 msecs.
[ 7.465144] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully initialized and connected.
[ 7.465592] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in warm state.
[ 7.466073] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7.466395] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 7.732144] usb 1-1.4.4.4: DVB: registering adapter 2 frontend 0 (DiBcom 7000PC)...
[ 7.991013] DiB0070: successfully identified
[ 7.991026] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[b][ 7.996363] dvb-usb: Hauppauge Nova-TD Stick (52009) error while loading driver (-12)[/b]
[ 7.996538] usbcore: registered new interface driver dvb_usb_dib0700
[ 8.291851] em28174 #1: EEPROM ID = 26 00 01 00, EEPROM hash = 0xabe7c6c8
[ 8.291862] em28174 #1: EEPROM info:
[ 8.291869] em28174 #1: microcode start address = 0x0004, boot configuration = 0x01
[ 8.299087] em28174 #1: AC97 audio (5 sample rates)
[ 8.299093] em28174 #1: 500mA max power
[ 8.299101] em28174 #1: Table at offset 0x27, strings=0x0e6a, 0x1888, 0x087e
[ 8.299580] em28174 #1: Identified as Hauppauge WinTV-dualHD DVB (card=99)
[ 8.304847] tveeprom 17-0050: Hauppauge model 204109, rev B3I6, serial# 11559123
[ 8.304862] tveeprom 17-0050: tuner model is SiLabs Si2157 (idx 186, type 4)
[ 8.304872] tveeprom 17-0050: TV standards PAL(B/G) NTSC(M) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xfc)
[ 8.304881] tveeprom 17-0050: audio processor is None (idx 0)
[ 8.304889] tveeprom 17-0050: has no radio, has IR receiver, has no IR transmitter
[ 8.304898] em28174 #0: dvb ts2 set to isoc mode.
[ 8.506137] usbcore: registered new interface driver em28xx
[ 8.512847] em28174 #0: Binding DVB extension
[ 8.525812] i2c i2c-10: Added multiplexed i2c bus 18
[ 8.525829] si2168 10-0064: Silicon Labs Si2168-B40 successfully identified
[ 8.525834] si2168 10-0064: firmware version: B 4.0.2
[ 8.539699] si2157 18-0060: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 8.539756] DVB: registering new adapter (em28174 #0)
[ 8.539785] usb 1-1.4.3: DVB: registering adapter 2 frontend 0 (Silicon Labs Si2168)...
[ 8.541240] em28174 #0: DVB extension successfully initialized
[ 8.541251] em28174 #1: Binding DVB extension
[ 8.552378] i2c i2c-17: Added multiplexed i2c bus 19
[ 8.552391] si2168 17-0067: Silicon Labs Si2168-B40 successfully identified
[ 8.552395] si2168 17-0067: firmware version: B 4.0.2
[ 8.557069] si2157 19-0063: Silicon Labs Si2147/2148/2157/2158 successfully attached
[ 8.557099] DVB: registering new adapter (em28174 #1)
[ 8.557109] usb 1-1.4.3: DVB: registering adapter 3 frontend 0 (Silicon Labs Si2168)...
[ 8.558200] em28174 #1: DVB extension successfully initialized
[ 8.558211] em28xx: Registered (Em28xx dvb Extension) extension
[ 8.571139] em28174 #0: Registering input extension
[ 8.614173] Registered IR keymap rc-hauppauge
[ 8.614625] input: em28xx IR (em28174 #0) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.3/rc/rc1/input1
[ 8.616162] rc rc1: em28xx IR (em28174 #0) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.3/rc/rc1
[ 8.616555] em28174 #0: Input extension successfully initalized
[ 8.616561] em28174 #1: Registering input extension
[ 8.616927] Registered IR keymap rc-hauppauge
[ 8.617270] input: em28xx IR (em28174 #1) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.3/rc/rc2/input2
[ 8.617449] rc rc2: em28xx IR (em28174 #1) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.3/rc/rc2
[ 8.617806] em28174 #1: Input extension successfully initalized
[ 8.617812] em28xx: Registered (Em28xx Input Extension) extension
[ 9.505302] uart-pl011 3f201000.serial: no DMA platform data
[ 9.971310] Adding 102396k swap on /var/swap. Priority:-1 extents:5 across:225280k SSFS
[ 10.157842] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 10.700436] si2168 17-0067: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[ 11.130300] pps_ldisc: PPS line discipline registered
[ 11.131135] pps pps1: new PPS source ttyAMA0
[ 11.131208] pps pps1: source "/dev/ttyAMA0" added
[ 11.389184] si2168 17-0067: firmware version: B 4.0.25
[ 11.393978] si2157 19-0063: found a 'Silicon Labs Si2157-A30'
[ 11.443183] si2157 19-0063: firmware version: 3.0.5
[ 11.443228] usb 1-1.4.3: DVB: adapter 3 frontend 0 frequency 0 out of range (42000000..870000000)
[ 11.448405] si2168 17-0067: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[ 11.448948] si2168 10-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[ 11.674482] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 12.382319] si2168 17-0067: firmware version: B 4.0.25
[ 12.429892] si2168 10-0064: firmware version: B 4.0.25
[ 12.446008] si2157 18-0060: found a 'Silicon Labs Si2157-A30'
[ 12.500244] si2157 18-0060: firmware version: 3.0.5
[ 12.501232] usb 1-1.4.3: DVB: adapter 2 frontend 0 frequency 0 out of range (42000000..870000000)
[ 12.515666] si2168 10-0064: downloading firmware from file 'dvb-demod-si2168-b40-01.fw'
[ 12.542365] usb 1-1.4.4.3: DVB: adapter 1 frontend 0 frequency 0 out of range (45000000..860000000)
[ 12.598556] FS-Cache: Netfs 'cifs' registered for caching
[ 12.599165] Key type cifs.spnego registered
[ 12.599187] Key type cifs.idmap registered
[ 12.637377] usb 1-1.4.4.3: DVB: adapter 0 frontend 0 frequency 0 out of range (45000000..860000000)
[ 13.321736] input: vnc-keyboard as /devices/virtual/input/input3
[ 13.322136] input: vnc-abspointer as /devices/virtual/input/input4
[ 13.322506] input: vnc-relpointer as /devices/virtual/input/input5
[ 13.385465] si2168 10-0064: firmware version: B 4.0.25
[ 14.578589] input: vnc-keyboard as /devices/virtual/input/input6
[ 14.578970] input: vnc-abspointer as /devices/virtual/input/input7
[ 14.579459] input: vnc-relpointer as /devices/virtual/input/input8
[ 16.611439] Bluetooth: Core ver 2.22
[ 16.611502] NET: Registered protocol family 31
[ 16.611505] Bluetooth: HCI device and connection manager initialized
[ 16.611521] Bluetooth: HCI socket layer initialized
[ 16.611532] Bluetooth: L2CAP socket layer initialized
[ 16.611558] Bluetooth: SCO socket layer initialized
[ 16.644913] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.644923] Bluetooth: BNEP filters: protocol multicast
[ 16.644939] Bluetooth: BNEP socket layer initialized
[ 1855.297018] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully deinitialized and disconnected.
[ 1856.730687] usb 1-1.4.4.4: USB disconnect, device number 10
[ 1860.882723] usb 1-1.4.4.4: new high-speed USB device number 11 using dwc_otg
[ 1861.023609] usb 1-1.4.4.4: New USB device found, idVendor=2040, idProduct=5200
[ 1861.023618] usb 1-1.4.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1861.023622] usb 1-1.4.4.4: Product: NovaT 500Stick
[ 1861.023626] usb 1-1.4.4.4: Manufacturer: Hauppauge
[ 1861.023630] usb 1-1.4.4.4: SerialNumber: 4035677563
[ 1861.024326] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in cold state, will try to load a firmware
[ 1861.027837] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[ 1861.236679] dib0700: firmware started successfully.
[ 1861.752875] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in warm state.
[ 1861.753223] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1861.753351] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 1862.027792] usb 1-1.4.4.4: DVB: registering adapter 0 frontend 0 (DiBcom 7000PC)...
[ 1862.289927] DiB0070: successfully identified
[ 1862.289936] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1862.290090] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 1862.467027] usb 1-1.4.4.4: DVB: registering adapter 1 frontend 0 (DiBcom 7000PC)...
[ 1862.729924] DiB0070: successfully identified
[ 1862.729946] Registered IR keymap rc-dib0700-rc5
[ 1862.730376] input: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.4/rc/rc0/input9
[ 1862.730549] rc rc0: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.4/rc/rc0
[ 1862.730751] dvb-usb: schedule remote query interval to 50 msecs.
[ 1862.730756] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully initialized and connected.
[ 1862.874055] usb 1-1.4.4.4: DVB: adapter 0 frontend 0 frequency 0 out of range (45000000..860000000)
[ 1862.930722] usb 1-1.4.4.4: DVB: adapter 1 frontend 0 frequency 0 out of range (45000000..860000000)
[ 1866.002754] usb 1-1.4.4.3: new high-speed USB device number 12 using dwc_otg
[ 1866.143612] usb 1-1.4.4.3: New USB device found, idVendor=2040, idProduct=5200
[ 1866.143620] usb 1-1.4.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1866.143625] usb 1-1.4.4.3: Product: NovaT 500Stick
[ 1866.143629] usb 1-1.4.4.3: Manufacturer: Hauppauge
[ 1866.143633] usb 1-1.4.4.3: SerialNumber: 4035604867
[ 1866.144461] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in cold state, will try to load a firmware
[ 1866.144575] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[ 1866.351306] dib0700: firmware started successfully.
[ 1866.863012] dvb-usb: found a 'Hauppauge Nova-TD Stick (52009)' in warm state.
[ 1866.863384] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1866.863600] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 1867.136901] usb 1-1.4.4.3: DVB: registering adapter 4 frontend 0 (DiBcom 7000PC)...
[ 1867.399932] DiB0070: successfully identified
[ 1867.399941] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 1867.400097] DVB: registering new adapter (Hauppauge Nova-TD Stick (52009))
[ 1867.576769] usb 1-1.4.4.3: DVB: registering adapter 5 frontend 0 (DiBcom 7000PC)...
[ 1867.840432] DiB0070: successfully identified
[ 1867.840455] Registered IR keymap rc-dib0700-rc5
[ 1867.840901] input: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.3/rc/rc3/input10
[ 1867.841079] rc rc3: IR-receiver inside an USB DVB receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4.3/rc/rc3
[ 1867.841275] dvb-usb: schedule remote query interval to 50 msecs.
[ 1867.841288] dvb-usb: Hauppauge Nova-TD Stick (52009) successfully initialized and connected.
PS : the kernel I am running is patched and recompiled BUT, I just did a test with a fresh rasbian lite install and the issue is exactly the same.
