pieuser
Raspberry Pi3
Tue Jun 06, 2017 11:11 am
Hi, everyone i am a beginner for raspberry Pi 3 . I am using windows 7. For connect a set up with IOT what should be the system requirement.
Re: Raspberry Pi3
Tue Jun 06, 2017 1:10 pm
I believe setting up to program for WinIot on pi is covered on the Microsoft website for WinIoT on Pi. Google should find it.
Re: Raspberry Pi3
Tue Jun 06, 2017 1:16 pm
pieuser wrote:Hi, everyone i am a beginner for raspberry Pi 3 . I am using windows 7. For connect a set up with IOT what should be the system requirement.
FYI Windows 10 IoT Core presumes you are running Windows 10 Desktop Edition on your x86 machine:
https://developer.microsoft.com/en-us/windows/iot
pieuser
Re: Raspberry Pi3
Wed Jun 07, 2017 5:33 am
Is there only one thing windows 10 for IOT for writing code in c in pi3 model B.
rpdom
Re: Raspberry Pi3
Wed Jun 07, 2017 5:43 am
pieuser wrote:Is there only one thing windows 10 for IOT for writing code in c in pi3 model B.
C (and many other languages) are standard in Raspbian Linux OS. There is no reason you can't write IoT code to run on Raspbian. Many people do that.
pieuser
Re: Raspberry Pi3
Wed Jun 07, 2017 5:57 am
my requirement is raspberry pi3 model B with raspbian os writing c language to run IOT and other functionality. Is this system will work.
pieuser
Re: Raspberry Pi3
Wed Jun 07, 2017 6:00 am
I am using 8 GB sd card. is the system will work fast or slow in this configuration.
bensimmo
Re: Raspberry Pi3
Wed Jun 07, 2017 7:57 am
Yes you can use Raspian.
It will probably do your IoT, many people do. It depends on the challenge of what you are trying to do and interface with.
It'll be as fast as it is, not all cards are equal in speed.
For IoT once it is running, it tends not to matter.
Just have a play and see what you can do.
Many other people also add Arduino and ESP boards to do some of the interfacing an leave the Pi for the heavy centralised work.
You could also look at Android of Things as other option to Raspbian (debian/linux) and Win10 IoT (Windows)
pieuser
Re: Raspberry Pi3
Mon Jun 12, 2017 1:08 pm
for writing code in c in pi3 and iot configuration i use vi editor. is there any other ide i need to install for this.
pieuser
Re: Raspberry Pi3
Wed Jul 05, 2017 7:08 am
Is IOT programming can be done with raspbian os or i have to install other os.[/quote]
Re: Raspberry Pi3
Wed Jul 05, 2017 7:36 am
pieuser wrote:Is IOT programming can be done with raspbian os or i have to install other os.
Maybe some indication of what you are trying to achieve would elicit a focused answer ??
Last edited by fruitoftheloom on Wed Jul 05, 2017 8:02 am, edited 1 time in total.
KLL
Re: Raspberry Pi3
Wed Jul 05, 2017 7:53 am
possibly you noticed that your questions not got the answers you expect??
most problem is your wording "IoT programming .. configuration ..."
i understand you have
+ RPI3 with RASPIAN already setup
+ win7 PC ( connected putty / VNC for headless working?)
- you want learn coding "C" and want use other editor as "VI"
there is installed already GEANY, try that,
i test-install this some time ago:
sudo apt-get install codeblocks
so instead using that one term you need to tell what you want to do/learn?
++ linux programming
++ with making GUI program?
++ or web pages?
++ RPI GPIO
++ RPI network to IoT devices ( like MQTT https://www.baldengineer.com/mqtt-tutorial.html )
or what is your idea?
pieuser
Re: Raspberry Pi3
i am try to do raspberry pie with IOT and MQTT . i have noobs os . what other things i need to install to write program in c.
Re: Raspberry Pi3
Wed Jul 05, 2017 8:05 am
pieuser wrote:[""]
It is a Raspberry Pi, a PIE is a dessert you eat whilst NoobS is an installer / chooser and not an Operating System
https://www.raspberrypi.org/magpi/issue ... ials-c-v1/
https://randomnerdtutorials.com/how-to- ... pberry-pi/
Last edited by fruitoftheloom on Wed Jul 05, 2017 8:11 am, edited 1 time in total.
rpdom
Re: Raspberry Pi3
Wed Jul 05, 2017 8:09 am
The Raspbian OS that is recommended for the Pi (and is the default install from NOOBS) comes with everything you need to compile many programs with C. There is a choice of editors, and a full compiler (gcc). If you are doing something fancy you may need to install additional header libraries (like if you are writing something that will use USB directly).
pieuser
Re: Raspberry Pi3
Wed Jul 05, 2017 8:14 am
i want to implement iot and mqtt with pi3. i have noobs os installed and want to write program in c. what other thing i need to install.
B.Goode
Re: Raspberry Pi3
Wed Jul 05, 2017 8:33 am
pieuser wrote:i want to implement iot and mqtt with pi3. i have noobs os installed and want to write program in c. what other thing i need to install.
MQTT has already been implemented for many Programming languages used by Raspbian on an RPi. Are you sure you need to re-implement it? Or do you simply mean you wish to use that protocol in your own application?
Please be specific, or at least give a reasonable sample, of what you want to achieve. Just interface a particular sensor or controller, or build a 'whole house' monitoring system?
NOOBS is not an OS, it is an Installer. It would be helpful to confirm that you have used NOOBS to install the recommended and supported Raspbian OS.
I... want to write program in c
Raspbian by default contains tools that allow you to program in C on and for the RPi: nothing else is necessary. (But if you have preferred tools such as editors or IDEs that are not present by default you can probably add them.)
Edit: just to add that the majority of what I have written has already appeared in other replies in this thread, I have simply summarised them in one place. If you don't read and show some sign of acknowledgement of what people contribute it is likely that the flow of replies will dry up.
bensimmo
Re: Raspberry Pi3
Wed Jul 05, 2017 8:50 am
What is your native language?
Somebody may be able to talk to you in it.
pieuser
Re: Raspberry Pi3
Wed Jul 12, 2017 8:29 am
[]Is Windows 10 necessary for installation of IOT in pi 3 or raspbian os is enough for it.[/quote]
Re: Raspberry Pi3
Wed Jul 12, 2017 8:39 am
pieuser wrote:[]Is Windows 10 necessary for installation of IOT in pi 3 or raspbian os is enough for it.
[/quote]
You appear to be asking the same questions rather than responding to your replies. If English is not your first language then post in the section of this forum for your Language ;)
B.Goode
Re: Raspberry Pi3
Wed Jul 12, 2017 8:42 am
If you are referring to
WINDOWS 10 IOT CORE /
Windows 10 for the Internet of Things
as linked from https://www.raspberrypi.org/downloads/
That is a Microsoft solution and their documentation is here: https://developer.microsoft.com/en-us/w ... getstarted
Those instructions say:
Make sure you are running the public release of Windows 10
(Of course, there might be a 'hackers' way of doing the same thing with some other Operating System: but given your apparent difficulty getting started with this project it seems to me you would be well advised to try the supplier's recommended and supported way first.)
KLL
Re: Raspberry Pi3
Wed Jul 12, 2017 8:46 am
as it is now a week you have a RPI3 with NOOBS >> RASPBIAN installed,
did you try to write a "C" program?
did find a IDE what could make that faster (or more difficult at the beginning )?
did you try to write a desktop application already?
if you not happy with RASPBIAN and you want test other OS pls. do so.
Re: Raspberry Pi3
Wed Jul 12, 2017 8:47 am
B.Goode wrote:If you are referring to
Yep already stated that but the OP goes off on a tangent about MQTT
viewtopic.php?f=91&t=185452#p1172014
IF YOU ARE RUNNING Windows 10 IoT Core and want to utilise MQTT see: https://paolopatierno.wordpress.com/201 ... -marriage/
B.Goode
Re: Raspberry Pi3
Wed Jul 12, 2017 8:53 am
So, as a promise not a threat, this is likely to be my final attempt to help before @pieuser goes on my 'ignore' list...
pieuser
Re: Raspberry Pi3
Wed Jul 12, 2017 9:13 am
thanks
Return to “Beginners”
