I'm trying to simply record output audio (to ffmpeg).
I tried with pulse but it crash when I play audio while recording (...).
So I wanted to try alsa loopback :
sudo modprobe snd-aloop
Added snd-aloop to sudo nano /etc/modules
and here is my asound.conf :
pcm.!default {
type plug
slave.pcm "loop"
# output device
pcm.loopout {
type dmix
ipc_key 328211
slave.pcm "hw:1,0,0"
# input device
pcm.loopin {
type dsnoop
ipc_key 686592
slave.pcm "hw:1,1,0"
# duplex plug device
pcm.loop {
type plug
slave {
pcm {
type asym
playback.pcm "loopout"
capture.pcm "loopin"
}When I try to record from Loopback, there is just *no sound*,
and if I try this command while recording from hw:Loopback:1,0
aplay sm64_here_we_go.wav -D hw:Loopback,0,0 -c 2Code: Select all
aplay: set_params:1239: Channels count non availableCan you help me please ?
