jeebo
USB HDD wont auto mount
Fri May 26, 2017 10:26 am
Hi All,
I have my pi home server setup, but seem to be having considerable problems getting it to automount at boot.
I have changed the /etc/fstab file as so:
proc            /proc           proc    defaults          0       0
PARTUUID=29469a15-01  /boot           vfat    defaults          0       2
PARTUUID=29469a15-02  /               ext4    defaults,noatime  0       1
/dev/sda1/      /Media/pHDD_Other       ntfs-3g defaults,nofail 0       0
# a swapfile is not a swap partition, no line here
#   use  dphys-swapfile swap[on|off]  for that
if I try to mount the device manually:
mount -t auto /dev/sda1 /media/pHDD_Other
it works until I reboot the Pi.
Basically, its running Samba which when the drive is mounted, I can connect to the Pi from another device and can access it as a file server. Unfortunately though, it needs that manual intervention after boot to get it to work.
Can anyone advise the potential reason for this?
fred44nl
Re: USB HDD wont auto mount
Fri May 26, 2017 10:53 am
is the usb-hdd truly formatted with ntfs ??
or is it ext4 ??
you have proc and sda1 both on "0" (last char on the line)
not sure if that's really a problem :)
headless RPi 3B running from usbhdd.
RaTTuS
Contact: Twitter YouTube
Fri May 26, 2017 11:05 am
/proc should be 0 0
/dev/sda1 should be 0 1 possibly with an auto in it also ...
Covfefe
thagrol
Tue May 30, 2017 6:09 pm
What's the output of
sudo mount -t ntfs-3g /dev/sda1 /media/pHDD_Other
with the drive unmounted and
mount | grep sda1
after mounting manually as above?
Attempts to contact me outside of thes forums will be ignored unless signed in triplicate, sent in, sent back, queried, lost, found, subjected to public enquiry, lost again, and finally buried in soft peat for three months and recycled as firelighters
Return to “Advanced users”
