R3nN1
VPN Libreelec Problem
Tue May 23, 2017 5:42 pm
Hallo,
habe über Windscripe nen VPN über Kodi 16.1 (Libreelec) am laufen gehabt
seit ich nen Update auf Kodi 17 durchgeführt habe, connectect er nich mehr
habe dann Kodi 17 komplett neu aufgesetzt, funktioniert auch nicht
dann wieder 16.1, und es funktioniert wieder
Kann mir jemand sagen, an was es liegt, das ich unter Kodi 17 keine Verbindung zum VPN bekomme?
benutz den VPN Manager für OpenVPN
R3nN1
Re: VPN Libreelec Problem
Tue May 23, 2017 6:13 pm
19:57:33.282 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 OpenSSL: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed
19:57:33.282 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 TLS_ERROR: BIO read tls_read_plaintext error
19:57:33.283 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 TLS Error: TLS object -> incoming plaintext read error
19:57:33.283 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 TLS Error: TLS handshake failed
19:57:33.283 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 Fatal TLS error (check_tls_errors_co), restarting
19:57:33.283 T:1753215904 NOTICE: Tue May 23 19:57:31 2017 SIGUSR1[soft,tls-error] received, process restarting
19:57:33.283 T:1753215904 NOTICE: Tue May 23 19:57:32 2017 SIGTERM[hard,init_instance] received, process exiting
19:57:33.283 T:1753215904 NOTICE: VPN Mgr : (platform.py) <<< VPN log file end
20:03:23.708 T:1769993120 ERROR: GetDirectory - Error getting
20:03:35.538 T:1599075232 ERROR: Previous line repeats 2 times.
20:03:35.539 T:1599075232 WARNING: CPythonInvoker(4): Script invoked without an addon. Adding all addon modules installed to python path as fallback. This behaviour will be removed in future version.
20:03:44.862 T:1599075232 NOTICE: VPN Mgr : (platform.py) VPN log file start >>>
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 WARNING: file '/storage/.kodi/addons/service.vpn.manager/Windscribe/ta.key' is group or others accessible
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 WARNING: file '/storage/.kodi/addons/service.vpn.manager/Windscribe/pass.txt' is group or others accessible
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 OpenVPN 2.4.0 armv7ve-libreelec-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [AEAD] built on Feb 26 2017
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 library versions: LibreSSL 2.4.4, LZO 2.09
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 TCP/UDP: Preserving recently used remote address: [AF_INET]176.10.116.112:443
20:03:44.862 T:1599075232 NOTICE: Tue May 23 19:57:30 2017 Attempting to establish TCP connection with [AF_INET]176.10.116.112:443 [nonblock]
20:03:44.863 T:1599075232 NOTICE: Tue May 23 19:57:31 2017 TCP connection established with [AF_INET]176.10.116.112:443
20:03:44.863 T:1599075232 NOTICE: Tue May 23 19:57:31 2017 TCP_CLIENT link local: (not bound)
20:03:44.863 T:1599075232 NOTICE: Tue May 23 19:57:31 2017 TCP_CLIENT link remote: [AF_INET]176.10.116.112:443
20:03:44.863 T:1599075232 NOTICE: Tue May 23 19:57:31 2017 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
20:03:44.863 T:1599075232 NOTICE: Tue May 23 19:57:31 2017 VERIFY ERROR: depth=1, error=format error in certificate's notAfter field: C=CA, ST=ON, L=Toronto, O=Windscribe Limited, OU=Operations, CN=Windscribe Node CA
Return to “Deutsch”
