The ssh server/daemon is disabled by default on recent versions of Raspian Jessie. Have you enabled it?kahve wrote:I am using putty to connect my raspberry pi. And I haven't got any keyboard... So I am using Ethernet. I tried all methods which is inside of youtube etc. But I always get an error says "connection refused". Is there any methods to solve that? Thanks...
https://www.raspberrypi.org/blog/a-secu ... ian-pixel/First, from now on SSH will be disabled by default on our images.
The boot partition on a Pi should be accessible from any machine with an SD card reader, on Windows, Mac, or Linux. If you want to enable SSH, all you need to do is to put a file called ssh in the /boot/ directory.
