So I saw this here: https://www.raspberrypi.org/documentati ... des/msd.md which basically shows how to boot from a usb hard drive. I understand once this is set that it is permanent. I primarily have windows devices though so i am a little nervous. When it comes to making an image i use win32 disk imager, i have also heard for us windows folks ether is good but i have not yet used it.
I am curious though once this bit is set to have the pi boot from usb is it set to boot from 1 specific usb slot, drive or anything like that or basically is this more like just changing it to look at the usb ports for bootable media rather than looking at the microsc card?
I am also curious if there is a way i can test this before making a change that is permanent?
I also have one other assumption i am curious if its correct, in raspbian there is that nice option to clone the sd card and it looks like i can clone it to the usb drive, now if i clone it and then set this option to boot from usb should that make this a pain free transition?
