psergiu
ENC28J60 SPI Ethernet
Tue Sep 25, 2012 1:08 pm
Hi everyone,
I want to use a ENC28J60 SPI ethernet board with the latest Raspbian.
It's possible, the driver exists in the kernel source code, and Chris Boot already did-it before.
Can anyone give me some hints on how i can accomplish this ? Do i need to recompile the whole kernel or just the enc28j60.c kernel module ? Any pointers on the kernel source (shall i use the kernel.org image or shall i download a RPi-speciffic one, from where) ?
Thanks a lot.
RaTTuS
Contact: Twitter YouTube
Re: ENC28J60 SPI Ethernet
Tue Sep 25, 2012 1:14 pm
sudo apt-get update && sudo apt-get upgrade -y
reboot
git clone --depth 1 https://github.com/raspberrypi/linux.git
cd linux
zcat /proc/config.gz >.config
edit .config and enable
CONFIG_ENC28J6
make modules
sudo make modules_install
sacrifice 1st born
reboot
YMMV
Covfefe
psergiu
Tue Sep 25, 2012 7:14 pm
Thank you very much.
Thankfully i skiped the last step. And i backed up the old modules.
I somehow managed to compile broken kernel modules. "modinfo" says the are the same as the old ones, "file" says they are the same as the old ones but they are a couple ok Kb smaller and "modprobe" says: "ERROR: could not insert 'enc28j60': Exec format error"
and in "dmesg" i get "enc28j60: no symbol version for module_layout"
s/enc28j60/every_other_newly_compiled_module_i_tried/g
psergiu
Wed Sep 26, 2012 5:56 am
I succesfuly compiled the module
ln -s /wherever/i/downloaded/the/kernel /usr/src/linux
ln -s /usr/src/linux /lib/modules/`uname -r`/build
cd /lib/modules/`uname -r`/build
make -C /lib/modules/`uname -r`/build
i insmod the enc28j60 module aaaand ... nothing.
further reading on the interwebs tells me that for the 3.2.x kernel i have to edit a file somewhere to tell the kernel where my board is physically connected SPI BUS & CS
something like:
static struct spi_board_info spi1_board_info[] __initdata = {
      .modalias       = "enc28j60",
      .mode          = SPI_MODE_0,
      .irq         = AT32_EXTINT(0),
      .max_speed_hz      = 12000000,
      .chip_select      = 0,
and some init code.
http://www.avrfreaks.net/index.php?name ... ic&t=75282
http://ww2.cs.fsu.edu/~rosentha/linux/2 ... e1197.html
http://www.jumpnowtek.com/index.php?opt ... &Itemid=62
But where i'm supposed to put those code snippets and are there any specifics for Raspberry Pi ?
psergiu
Thu Sep 27, 2012 10:00 pm
Success.
file to edit: arch/arm/mach-bcm2708/bcm2708.c
search for "spi_board_info bcm2708_spi_devices" and modify as follows (assuming your ENC28J60 is connected to spi0.0 (CE0):
static struct spi_board_info bcm2708_spi_devices[] = {
                .bus_num = 0,
                .chip_select = 0,
                .mode = SPI_MODE_0,
                .modalias = "spidev",
                .max_speed_hz = 500000,
                .bus_num = 0,
                .chip_select = 1,
                .mode = SPI_MODE_0,
Recompile kernel & modules as in the previous post
cp arch/arm/boot/zImage /boot/kernel.img
cp drivers/net/ethernet/microchip/enc28j60.ko /lib/modules/`uname -r`/kernel/drivers/net/ethernet/microchip/
shutdown -r now
then after it starts up: modprobe enc28j60
and victory:
[  847.810450] enc28j60 spi0.0: enc28j60 Ethernet driver 1.01 loaded
[  847.822819] net eth1: enc28j60 driver registered
[  847.947228] net eth1: link down
[  847.947297] net eth1: normal mode
[  847.947331] net eth1: normal mode
[  847.947558] net eth1: multicast mode
[  850.154955] net eth1: link up - Half duplex
Right now, the network card is working "IRQ-less" so the speed is not great ( ~100KB/sec).
Next step - connecting the network card's IRQ signal to a GPIO.
RaTTuS
Fri Sep 28, 2012 8:20 am
psergiu wrote:...
ooh I never knew you could just copy the zImage .... I've been using the imagetoo-uncompressed.py script ...
/me goes to change my special build machine
Covfefe
ezz
Fri Dec 28, 2012 10:20 pm
Anybody has a schematics of connection ?
psergiu
Fri Dec 28, 2012 10:50 pm
6 jumper wires:
ENC - RPi
VCC - 3v3
GND - GND
CS - CE0 (gpio 8)
SI - MOSI (gpio 10)
SCK - SCKL (gpio 11)
SO - MISO (gpio 9)
Also, pin INT can be connected to another GPIO pin and the driver configured to use-it as IRQ (haven't done this yet so i cannot tell you exactly how)
msperl
Wed Nov 06, 2013 1:43 pm
For those of you who try to use this device with a current kernel:
you will need to configure the interrupt edge outside of the driver.
If you use spi-config to configure the SPI-parts (see: http://www.raspberrypi.org/phpBB3/viewt ... 44&t=57157), then assuming you have:
  • the IRQ line on GPIO 25
  • the ENC28j60 CS on CS1
Then with this you can set up the network:
echo "25" > /sys/class/gpio/export
echo "falling" > /sys/class/gpio/gpio25/edge
echo "25" > /sys/class/gpio/unexport
modprobe spi-config devices=bus=0:cs=1:modalias=enc28j60:speed=12000000:gpioirq=25
the above will load the enc28j60 driver (if you have it compiled as a module) and then start it up as "expected"...
Network is up almost immediately - but do not expect an extremely fast network...
Martin
psegura
Wed Mar 19, 2014 7:21 pm
Hello!
As I understand the steps are:
Wired connection:
6 jumper wires:
ENC - RPi
VCC - 3v3
GND - GND
CS - CE0 (gpio 8)
SI - MOSI (gpio 10)
SO - MISO (gpio 9)
1.-
reboot
cd linux
CONFIG_ENC28J6
2.-
.bus_num = 0,
.chip_select = 0,
.mode = SPI_MODE_0,
.bus_num = 0,
.chip_select = 1,
.mode = SPI_MODE_0,
3.-
4.-
shutdown -r now
If I'm not forgetting nothing please let me know why I do not have the enc28j60.ko file? Can I use enc28j60.o? And, how? modprobe? insmod?
I tried to recompile the module with this:
make -C /lib/modules/3.10.25+/build M=drivers/net/ethernet/microchip/enc28j60.ko
But just recived a ko directory:
[email protected]:/lib/modules/3.10.25+/build# ls -l drivers/net/ethernet/microchip/
total 132
-rw-r--r-- 1 root root 24982 Mar 18 18:29 built-in.o
-rw-r--r-- 1 root root 45356 Mar 4 18:02 enc28j60.c
-rw-r--r-- 1 root root 8913 Mar 4 18:02 enc28j60_hw.h
drwxr-xr-x 3 root root 4096 Mar 19 12:57 enc28j60.ko
-rw-r--r-- 1 root root 24984 Mar 18 18:29 enc28j60.o
-rw-r--r-- 1 root root 1035 Mar 4 18:02 Kconfig
-rw-r--r-- 1 root root 95 Mar 4 18:02 Makefile
-rw-r--r-- 1 root root 50 Mar 18 23:02 modules.builtin
-rw-r--r-- 1 root root 0 Mar 19 12:40 modules.order
-rw-r--r-- 1 root root 0 Mar 19 12:40 Module.symvers
Thanks.
DirkS
Thu Dec 18, 2014 7:24 pm
I have the ENC28J60 working but not as I want it.
First time I cross-compiled the RPF kernel with the module enabled and the code changes mentioned above I had some problems so I decided to try it with Martin's spi-config (also cross-compiled).
Added spi-config to rc.local (including enabling the irq) and it works great (better than I expected actually).
Now I decided to go back to changing bcm2708.c; using above mentioned change
  .bus_num = 0,
  .chip_select = 0,
  .mode = SPI_MODE_0,
<etcetera>
It compiles fine, but the result is slow and fairly unstable. Don't have a lot of experience with these things, but my guess is that this has something to do with the IRQ.
So my question is: are there any additional changes needed?
Gr.
Dirk.
Thu Dec 18, 2014 7:58 pm
It gets easier with the 3.18.y kernel and the device tree.
For 3.12.33 I got it running with this code modification
#ifdef CONFIG_BCM2708_SPIDEV
#ifdef CONFIG_SPI_SPIDEV
                .modalias = "enc28j60",  # changed for SPI ethernet
                .max_speed_hz = 12000000, # changed for SPI ethernet
                .bus_num = 0,
                .chip_select = 0,
                .mode = SPI_MODE_0,
                .bus_num = 0,
                .chip_select = 1,
                .mode = SPI_MODE_0,
#endif
#endif
And
CONFIG_ENC28J60=m
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
CONFIG_SPI_BCM2708=y
CONFIG_SPI_SPIDEV=y
in .config
For 3.18.y
CONFIG_ENC28J60=m
in .config is all that's needed. The hard work is done in the dts/dtb.
                [email protected] {
                        compatible = "brcm,bcm2708-spi";
                        reg = <0x7e204000 0x1000>;
                        interrupts = <0x2 0x16>;
                        clocks = <0x3>;
                        #address-cells = <0x1>;
                        #size-cells = <0x0>;
                        status = "okay";
                        pinctrl-names = "default";
                        pinctrl-0 = <0x4>;
                        [email protected] {
                                compatible = "enc28j60";
                                reg = <0x0>;
                                spi-max-frequency = <0xb71b00>;
                        [email protected] {
                                compatible = "spidev";
                                reg = <0x1>;
                                spi-max-frequency = <0x7a120>;
Note: 0xB71B00 == 12,000,000. There's no IRQ values in there at all. I've got mine wired on SCLK, MISO, MOSI and pin# 24 SPI CS0.
This is a doctor free zone.
DirkS
Thu Dec 18, 2014 8:08 pm
Cheers, Dougie.
I'll give that a go...
Gr.
Dirk.
BMS Doug
Sat Dec 20, 2014 2:41 pm
I've got one of these on order now (delivery in mid january), I'm hoping to use it with my A+ to make a NAS drive.
Doug.
Sun Feb 08, 2015 10:25 pm
Good news. The very nice folks who build the kernel are giving us a device tree overlay for the ENC28J60.
https://github.com/raspberrypi/linux/issues/795
abishur
Sun Feb 15, 2015 1:42 am
DougieLawson wrote:Good news. The very nice folks who build the kernel are giving us a device tree overlay for the ENC28J60.
So how does one actually make use of the device tree overlay for the enc28j60? Surely it's not just connect the device to the pi as described above and you're essentially plug and play, right?
Dear forum: Play nice ;-)
Sun Feb 15, 2015 1:50 am
Don't know yet, because PhilE hasn't finished the code or the docs for it.
plugwash
Sun Feb 15, 2015 2:17 am
AIUI you add an entry in config.txt (or possiblly a HAT eeprom) to load the device tree overlay. That overlay tells the kernel to expect an enc28j60 and where to expect it. Then it should just work like any other ethernet controller.
abishur
Sun Feb 15, 2015 3:04 am
DougieLawson wrote:Don't know yet, because PhilE hasn't finished the code or the docs for it.
Ah, my bad, I thought the dts you were refering to in a previous post was the a device tree thing. How are you loading this module right now?
abishur
Sun Feb 15, 2015 3:09 am
plugwash wrote:AIUI you add an entry in config.txt (or possiblly a HAT eeprom) to load the device tree overlay. That overlay tells the kernel to expect an enc28j60 and where to expect it. Then it should just work like any other ethernet controller.
Do you know the syntax for it by the way? I notice that in the documentation for the device tree on the raspberrypi github (here) it shows the syntax as
#device_tree_param=spi=on
But in the latest version of raspi-config I enabled the device tree and it added an entry like this for SPI
dtparam=spi=on
Sun Feb 15, 2015 9:35 am
At the moment my A+ is running on WiFi. I'll experiment with the ENC28J60 when the code from PhilE is ready.
DirkS
Sun Feb 15, 2015 10:05 am
dtparam=spi=on
Both are valid, you can also leave out '=on'. See https://github.com/raspberrypi/document ... short-cuts
Killertechno
Thu Nov 22, 2018 10:41 am
Hi to all, I write here avoiding open new thread.
I bought ENC28J60 module from web, I connected wires (I left INT on GPIO25) and I added
dtoverlay=enc28j60
on config.txt.
I correctly find new eth1 interface running ifconfig (missing interface if enc28j60 module unconnected).
I use eth0 on dhcp (original dhcpcd.conf) so I supposed to do the same with eth1.
If I connect eth1 to router, router does not detect cable connected, all led (enc28j60 port and router) are off.
Any ideas about issue?
There could be any conflicts in dhcpcd.conf standard file adding enc28j60 module?
Thanks.
DirkS
Thu Nov 22, 2018 10:57 am
Did you enable SPI with 'sudo raspi-config'?
Can you show us how you wired the module?
Are you sure you used the correct pins (using Broadcom numbering, not physical numbering)?
Can you see eth1 with 'ifconfig'?
Can you see the enc28j60 driver with 'lsmod'
Can you see any errors in the log re 'spi', 'enc28j60', 'eth1' (use e.g. dmesg)?
Killertechno
Thu Nov 22, 2018 3:54 pm
Obviously, I followed guides on connecting ENC28J60 on Raspberry forum.
ifconfig output (ENC28J60 is eth1)
[email protected]:~ $ ifconfig
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether b8:27:eb:50:10:c0  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 06:96:73:40:e8:39  txqueuelen 1000  (Ethernet)
        device interrupt 169
eth2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 192.168.31.109  netmask 255.255.255.0  broadcast 158.110.30.255
        inet6 fe80::14ba:fa79:7f28:2df3  prefixlen 64  scopeid 0x20<link>
        ether 00:00:00:00:00:3c  txqueuelen 1000  (Ethernet)
        RX packets 1035  bytes 84260 (82.2 KiB)
        RX errors 0  dropped 149  overruns 0  frame 0
        TX packets 76  bytes 11456 (11.1 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
[email protected]:~ $ lsmod
asix                   36864  0
cfg80211              573440  0
rfkill                 28672  2 cfg80211
enc28j60               32768  0
spidev                 16384  0
evdev                  24576  2
joydev                 20480  0
snd_bcm2835            32768  0
snd_pcm                98304  1 snd_bcm2835
snd_timer              32768  1 snd_pcm
snd                    69632  3 snd_timer,snd_bcm2835,snd_pcm
spi_bcm2835            16384  0
uio_pdrv_genirq        16384  0
uio                    20480  1 uio_pdrv_genirq
fixed                  16384  0
ip_tables              24576  0
x_tables               32768  1 ip_tables
ipv6                  434176  24
[email protected]:~ $ dmesg | grep enc
[    0.001020] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.002900] CPU: Testing write buffer coherency: ok
[    6.655301] enc28j60 spi0.0: enc28j60 Ethernet driver 1.02 loaded
[    6.664479] net eth1: enc28j60 driver registered
[email protected]:~ $ dmesg | grep eth1
[    8.385332] net eth1: link down
[    8.385380] net eth1: multicast mode
[    8.385660] net eth1: multicast mode
[    8.385686] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    8.409314] net eth1: multicast mode
[    8.477722] net eth1: multicast mode
