NewPi
Best waterproof temperature and humidity sensor solution..
Tue Sep 25, 2012 9:58 am
I am looking for a waterproof temperature and humidity sensor which works with Rpi GPIO, it seems DHT11 and SHT1X works with rpi but are not waterproof, would love some pointers to proceed.
Raspberry Pi Howto, Tips, Tricks and Tools -> http://bit.ly/RPiTricks
bredman
Re: Best waterproof temperature and humidity sensor solution
Tue Sep 25, 2012 10:29 am
It will be impossible to find a waterproof humidity sensor. By definition, a humidity sensor needs to be water permeable.
malakai
Tue Sep 25, 2012 10:45 am
What is the intended application where to place maybe we can brainstorm something around these I really want to make one up.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
g1gsw
Tue Sep 25, 2012 10:48 am
You can spray the boards with water proofing lacquer but as was said above keep the humidity sensor component itself clear as it needs to absorb moisture to give a reading. I have mine inside a Stevenson Screen which protects them from the bulk of the weather.
gordonendersby
Tue Sep 25, 2012 4:34 pm
I have a DHT11 tucked up under the eaves outside my office window.
So its out of the worst of the weather.
I soldered cat5 cable directly to the leads and covered the soldered jounts and expose leads from the device with Sugru(http://sugru.com/). Sticks like super glue, is mouldable and waterproof.
Obviously I didnt cover the vents on the DHT11.
It not only insulated the wires but also provides strain relief for the cable.
Gordon
NewPi
Wed Sep 26, 2012 2:46 pm
bredman wrote:It will be impossible to find a waterproof humidity sensor. By definition, a humidity sensor needs to be water permeable.
That makes sense :oops: , what was I thinking :? .
NewPi
Wed Sep 26, 2012 2:47 pm
malakai wrote:What is the intended application where to place maybe we can brainstorm something around these I really want to make one up.
I live at a hill-station with a lot of tourist activity all round the year, I would like to have a cheap weather update mechanism which will post temperature and humidity updates to my blog and other weather channels for public consumption.
NewPi
Wed Sep 26, 2012 2:49 pm
gordonendersby wrote:I have a DHT11 tucked up under the eaves outside my office window.
Gordon
I guess this should do the trick, DHT11's are cheap and can be spared. BTW, how long we can have the cable length, wouldnt it impact the reading somehow ?
