mfa298 wrote:phods wrote:
ok I shouldn't, but if I wanted?? because for me is the easy way, in the future I will change for the best model, but now, i needed of a functional version. ( and I don't know how to use the hhtp e json right now
MySQL by default only listens on localhost (127.0.0.1). You can change that with a config setting in /etc/mysql/my.cnf. From memory the option is bind-address and the simplest option is probably to comment it out.
You will also need to grant access within MySQL to users on remote hosts (these don't have to match the system users on any host).
I'm not really sure how you plan to connect arduinos to your MySQL database, I don't think they'll be able to run a full MySQL client to connect to the DB directly so you're going to need something in the middle providing an API the arduino can talk to.
Going back to an earlier comment this isn't anything to do with ssh security. I suspect you were using SSH as a way to tunnel the MySQL connection between hosts rather than changing the MySQL security model.
I already connect the arduino with mysql server in my online host, but now I need one offline.(I just use a properly library for arduino, and connect directly to a mysql and execute querys)
#include "EmonLib.h"
#include <SPI.h>
#include <Wire.h>
#include <ESP8266WiFi.h>
// Create an instance of the server
// specify the port to listen on as an argument
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
const char* ssid = "******";
const char* password = "******";
EnergyMonitor emon1;
//Tensao da rede eletrica
int rede = 220;
//Pino do sensor SCT
int pino_sct = A0;
//dbsim.allianse.com.br
IPAddress addr(******); // IP of the MySQL *server* here
char user[] = "******"; // MySQL user login username
char pass[] = "******"; // MySQL user login password
int cont=3;
char INSERT_DATA[] = "INSERT INTO allsim.energia (power,corrente) VALUES ('%s',%s)";
//char INSERT_DATA[] = "INSERT INTO test.arduino (esp1) VALUES (%s)";
char query[128];
char var[10];
char var2[10];
WiFiClient client;
MySQL_Connection conn((Client *)&client);
void setup() {
Wire.begin();
Serial.begin(115200);
// Connect to WiFi network
Serial.println();
//Pino, calibracao - Cur Const= Ratio/BurdenR. 2000/33 = 60
emon1.current(pino_sct, 60);
//emon1.current(pino_sct, 111.1); // Current: input pin, calibration.
//emon1.current(pino_sct, 56.49);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
//Serial.println("WiFi connected");
// Print the IP address
//Serial.println(WiFi.localIP());
//conectar na wifi
// Serial.println("Connecting BD...");
if (conn.connect(addr, 3306, user, pass)) {
delay(1000);
else
Serial.println("Connection failed.");
void loop() {
Serial.println();
Serial.println("Recording data.");
//Calcula a corrente
double Irms = emon1.calcIrms(1480);
//Mostra o valor da corrente no serial monitor e display
dtostrf(Irms, 1, 2, var);
dtostrf(Irms*230, 1,1, var2);
sprintf(query, INSERT_DATA,var2, var);
// Initiate the query class instance
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
// Execute the query
cur_mem->execute(query);
// Note: since there are no results, we do not need to read any data
// Deleting the cursor also frees up memory used
delete cur_mem;
delay(1000);
one more thing, when I create one mysql server with Xampp in a Windows machine, I can acess directly with a python script or an arduino code, but if this server is in raspberry i just access with python script using a library of sshtunnel
