I'm running home automation software on my Pi (Home Assistant) and recently noticed the time was off by exactly one hour and 4 minutes. I thought it was a time zone issue, but after checking all settings and help from another user, I found that ntp has a broken install and I cannot get it to install or reinstall. I'm not new to the raspberry pi, but I'm new when I comes to issues of dependancies and problems like this. I started with a clean install of Raspbian Jessie if that helps. Any help would be appreciated!!
Here's the log when I try to install ntp:
pi@raspberrypi:~ $ sudo aptitude install ntp
The following partially installed packages will be configured:
bsd-mailx exim4-daemon-light ntp
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 197 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Setting up ntp (1:4.2.6.p5+dfsg-7+deb8u2) ...
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Job for ntp.service failed. See 'systemctl status ntp.service' and 'journalctl -xn' for details.
invoke-rc.d: initscript ntp, action "start" failed.
dpkg: error processing package ntp (--configure):
subprocess installed post-installation script returned error exit status 1
Setting up exim4-daemon-light (4.84.2-2+deb8u3) ...
Job for exim4.service failed. See 'systemctl status exim4.service' and 'journalctl -xn' for details.
invoke-rc.d: initscript exim4, action "start" failed.
dpkg: error processing package exim4-daemon-light (--configure):
dpkg: dependency problems prevent configuration of bsd-mailx:
bsd-mailx depends on default-mta | mail-transport-agent; however:
Package default-mta is not installed.
Package exim4-daemon-light which provides default-mta is not configured yet.
Package mail-transport-agent is not installed.
Package exim4-daemon-light which provides mail-transport-agent is not configured yet.
dpkg: error processing package bsd-mailx (--configure):
dependency problems - leaving unconfigured
Errors were encountered while processing:
ntp
exim4-daemon-light
bsd-mailx
E: Sub-process /usr/bin/dpkg returned an error code (1)
Failed to perform requested operation on package. Trying to recover:
ntp
exim4-daemon-light
bsd-mailx
