solar3000
Rotate background
Fri May 12, 2017 10:25 am
raspbian boots up with a picture of a road as background.
You can manually change that.
Is there a way to automatically change that?
What file is updated when that picture is changed?
I guess if anyone knows of an app or if you can just write a script.
Antikythera
Paeryn
Re: Rotate background
Fri May 12, 2017 10:45 am
solar3000 wrote:raspbian boots up with a picture of a road as background.
It's set in ~/.config/pcmanfm/LXDE-pi/desktop-items-0.conf
wallpaper=/usr/share/images/desktop-base/desktop-background
But that is a symlink (to another symlink) before you get to the real file
[email protected]:~ $ ll /usr/share/images/desktop-base/desktop-background
lrwxrwxrwx 1 root root 36 Nov 21  2015 /usr/share/images/desktop-base/desktop-background -> /etc/alternatives/desktop-background
[email protected]:~ $ ll /etc/alternatives/desktop-background
lrwxrwxrwx 1 root root 52 Nov 21  2015 /etc/alternatives/desktop-background -> /usr/share/raspberrypi-artwork/raspberry-pi-logo.png
So I'd say the easiest way to change it on rotation is to keep changing the symlink /etc/alternatives/desktop-background to point whatever you want next time.
solar3000
Fri May 12, 2017 3:18 pm
cool that will work. right in my face and I didnt see it.
mine says
wallpaper=.... points to a photo I placed.
so I guess I can either write a script to update that file or like you said, just symlink it.
Antikythera
W. H. Heydt
Fri May 12, 2017 3:45 pm
Since--obviously--you have to be running the GUI to see the image...right click on an otherwise empty part of the screen, select "Desktop Preferences", on the window that comes up, the "Picture" entry is where the selected image is specified. If you click on the "folder" icon, a window will come up where you can change the wallpaper image. The path to the current one is at the top.
solar3000
Fri May 12, 2017 7:06 pm
W. H. Heydt wrote:Since--obviously--you have to be running the GUI to see the image...right click on an otherwise empty part of the screen, select "Desktop Preferences", on the window that comes up, the "Picture" entry is where the selected image is specified. If you click on the "folder" icon, a window will come up where you can change the wallpaper image. The path to the current one is at the top.
Right sir. But that won't rotate between different images.
On a PC running Linux and perhaps KDE, you can select a folder with a thousand pictures and every ten minutes you get a different desktop background.
Antikythera
W. H. Heydt
Fri May 12, 2017 8:15 pm
Sounds awful, but tastes differ. It could be done with "fbi" rather easily though (I think). The image could certainly be changed using fib, but I don't--off hand--know if it would act like wallpaper as I don't use it that way.
