rohit_b
ros installation on RPi 3
Thu May 11, 2017 11:32 am
Hi I followed the tutorial http://wiki.ros.org/kinetic/Installation/Debian .
I got the error :
E: Unable to locate package
output of
$ sudo apt-get update
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://mirrordirector.raspbian.org testing InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://packages.ros.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://mirrordirector.raspbian.org testing/main Sources
Hit http://mirrordirector.raspbian.org testing/contrib Sources
Hit http://mirrordirector.raspbian.org testing/non-free Sources
Hit http://mirrordirector.raspbian.org testing/rpi Sources
Hit http://packages.ros.org jessie/main armhf Packages
Ign http://archive.raspberrypi.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
Ign http://archive.raspberrypi.org jessie/ui Translation-en
Ign http://mirrordirector.raspbian.org jessie/main Translation-en
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
Ign http://packages.ros.org jessie/main Translation-en
Reading package lists... Done
Re: ros installation on RPi 3
Thu May 11, 2017 11:39 am
rohit_b wrote:Hi I followed the tutorial http://wiki.ros.org/kinetic/Installation/Debian .
I got the error :
output of
You are trying to install packages for the wrong CPU architecture, there is an identical post here
viewtopic.php?f=37&t=182197
rohit_b
Thu May 11, 2017 11:51 am
I am using jessie
which is the correct one.
cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Thu May 11, 2017 12:00 pm
I am using jessie
cat /etc/os-release
VERSION_ID="8"
ID=raspbian
ID_LIKE=debian
You are trying to follow instructions for the wrong CPU architecture......please read the other Post
rohit_b
Thu May 11, 2017 12:37 pm
fruitoftheloom wrote: You are trying to follow instructions for the wrong CPU architecture......please read the other Post
sorry , I am following this post http://wiki.ros.org/ROSberryPi/Installi ... berry%20Pi now
Still I am not able to install using apt-get . Is it not possible on RPi 3? do I need to follow source code installation guide ?
Thu May 11, 2017 12:51 pm
Try: ""An SD Card Image with Ubuntu Mate 16.04 and Ros Kinetic installed can be downloaded here""
rohit_b
Tue May 16, 2017 6:37 pm
Thanks , I switched to Ubuntu mate 16.04 and successfully installed ROS kinetic distribution on RPi 3
