musei wrote: ↑Wed Nov 01, 2017 4:32 am
Hey guys, I know this is an old post, but I'm having a similar issue, though I'm not running arcade games.
I'm using a Neutrik USB USB pass-through (
2.0 model http://www.neutrik.com/en/multimedia/usb/nausb-w-b). So I'm looking for recommendations for the USB micro to Type A, and then a USB Type B cable to a power adapter if anyone has any recommendations.
I've been trying to buy off amazon combination of cables, but can't seem to find any reliable ones that allow me to have consistent power throughout it's usage (half the time the lightning bolt appears in the corner of the screen).
I'm have a
Raspberry Pi 3 Model B and using various 1ft micro usb cables to the Neutrik, and then trying to use a 6ft USB Type A to B.
With that said, do you think moving to the Neutrik USB 3.0 (
http://www.neutrik.com/en/multimedia/nausb3-b) pass-through would work better for power?
Any help would be really appreciated.
The USB version of the pass-through won't make a difference. Either one will cause some resistive losses.
You didn't say what you are using for your power supply, which is important because it's likely the source of your troubles. Note that some phone chargers do not deliver their rated voltage, because charging batteries does not require precise voltage control. I have tested phone chargers rated for 5V/2.4A that dipped well below 5V at only 1A load.
Also, the USB cables in between need to have at least 24 AWG power wires, and preferably larger (lower wire gauge = fatter wires, so 20 AWG is better than 24 AWG).
Another option would be to move the PSU inside the case/cabinet and have the mains power connect to the outside. That would eliminate extra USB cables and connector losses. Barring that, a pass-through with a micro-USB cable on the back would eliminate 1 connector loss, but you would likely have to make something like that.
Bottom line, you need to test your PSU to see if it can maintain 5V under load, then you need to eliminate interconnection losses by reducing the number of plugs and jacks, and finally you need to use cables with nice fat wires.
Using the official RPF Pi3 PSU and running the power cord through the back of the cabinet with a grommet would eliminate all issues, but your power cord would not be detachable. The official RPF PSU is rated at 5.1V/2.5A with an attached 18 AWG micro-USB power cord.
