pjetson
pi zero w problem?
Wed May 10, 2017 4:54 am
I've just purchased a pi zero w board. I initially loaded Jessie Lite on it, and everything ran fine via SSH. I then tried to install some software, but lost network connectivity during the installs (my fault) and now it seems that I can't get the board to run properly :-(
I reinstalled Jessie Lite on my sdcard, and when it starts, the board prompts for a login and password, but then does nothing at all after I enter the password - nothing else is displayed on the screen. I downloaded Jessie Lite again and loaded it onto my sdcard again, but no change.
I then installed ("non-Lite") Jessie and tried booting that. It boots properly and displays the desktop, but neither mouse nor keyboard work.
Does anyone have any ideas about what I might have broken? And how I might fix it?
4LULZ
Re: pi zero w problem?
Wed May 10, 2017 9:34 am
Might not be broken, I had a similar issue when I first got my Zero W's.
viewtopic.php?f=28&t=180185&p=1145628#p1145628
tl;dr - double check that your USB's are plugged in to the correct inputs, it'll still power on and boot even if they're the wrong way around. Power should be connected to the mirco USB that's furthest away from the SD card, keyboard in the one to it's left.
mattmiller
Wed May 10, 2017 11:07 am
Can you ssh into it (having created an ssh.txt file on the FAT32 partition 1st) ?
pjetson
Wed May 10, 2017 12:19 pm
Yes, I can SSH into it, and I can log in and enter my pasword, but nothing appears on the screen after that - no intro text, no command prompt.
mattmiller
Wed May 10, 2017 2:28 pm
All that's left to do is try another SD card
pjetson
Wed May 10, 2017 10:49 pm
Thanks, Matt, but I've already tried another sdcard, with the same result.
mattmiller
Thu May 11, 2017 5:53 am
Well this is a really strange one - either the PiZero is broken in a VERY strange way or you have a bad batch of SD cards
Do you know anyone else with a Pi that you could borrow to try your cards in?
pjetson
Thu May 11, 2017 9:56 am
Hi, Matt. Sometimes I think I'm a bit of a magnet for strange problems.
Anyway, the problem might be resolved - at least it's working now. I found a blog post that seemed to describe a similar problem here https://expresshosting.net/ssh-hanging-authentication/
I currently have an old Linksys access point, but I had a new unused Edimax access point put away in a cupboard, so I hooked that up and connected the pi 0 w to it, and now I can log in!
I might eventually try changing the settings that the blog guy talks about, but for now I just need to stop wasting any more time on the problem and get on with actually using my pi 0 w!
mattmiller
Thu May 11, 2017 12:33 pm
Glad it gots going.
Very interesting to find out that a network router can cause problems between 2 clients - the only previous problems I've had was when I developed a "find a pi" prog and then discovered that a lot of routers filter out LAN broadcast messages so that scuppered that plan
