bennetty
win 10 iot core in noobs?
Mon May 08, 2017 7:11 am
hi, all,
i used noobs ver 2.4, and i found after i got wifi network connection,
i did not have a os named windows 10 iot core option to install,
currently, noobs ver 2.4 is not support win 10 iot core?
how do i make multiboot in noobs system?
thanks for any one help or suggestion.
Re: win 10 iot core in noobs?
Mon May 08, 2017 10:00 am
bennetty wrote:hi, all,
Unfortunately the NoobS documentation is out of date.
Microsoft have made many changes therefore it is probably easier to install Windows 10 IoT Core Insider Preview standalone considering you will need a machine running Windows 10 Desktop Edition to be able to setup and deploy:
https://developer.microsoft.com/en-us/w ... /Downloads
RPi 4B 4GB (SSD Boot)..
procount
Mon May 08, 2017 10:11 am
Which Raspberry Pi model do you have?
NOOBS will only present a list of OSes appropriate for your Pi model.
Win 10 IoT is only available for the Pi2 or Pi3.
bennetty
Thu May 11, 2017 8:20 am
thanks. i had know this before.
i just think noobs has the option to install ms iot core.
bennetty
Thu May 11, 2017 8:24 am
procount wrote:Which Raspberry Pi model do you have?
thanks. my pi model is 3.
and as above comment, noobs dont support win iot core installation option any more.
ShiftPlusOne
Fri May 12, 2017 6:48 pm
To the best of my knowledge, NOOBS documentation is up to date with regard to win 10 iot. It has not been removed and I've just installed it without any problems.
Chrispy_Cracker
Thu May 18, 2017 1:59 am
Hello ShiftPlusOne,
I have been beating my head against the wall trying to learn and get Windows 10 IoT running on my Raspberry PI 3B.
I must be missing something somewhere.
I used the IoT Dashboard and load Windows IoT Core on a chip (I have tried several chips) and it just wont boot.
I can put a Clean NOOBS chip and it will boot right up so I know the PI 3B is not the problem.
Where can I get step by step instruction that I can follow where even a knuckle-Head like me can follow?
Please help me with this.
bennetty
Thu May 18, 2017 2:22 am
ShiftPlusOne wrote:To the best of my knowledge, NOOBS documentation is up to date with regard to win 10 iot. It has not been removed and I've just installed it without any problems.
really? how did u do that?
after my pi3 first-time booting with noobs, and connected wifi network,
then i saw two os options only - Raspbian and LibreELEC .
i could not see any other third party images.
and of course, i did install these 2 images correctly.
(i use noobs, not noobs-lite)
ShiftPlusOne
Thu May 18, 2017 2:31 am
Chrispy_Cracker wrote:Hello ShiftPlusOne,
It sounds like you're following the install instructions of Microsoft's site rather than using NOOBS. I don't know what their recommended way is, but you can find NOOBS installation instructions here: https://www.raspberrypi.org/documentati ... n/noobs.md
It sounds like you don't have a network connection. NOOBS only comes with LibreELEC and Raspbian on the card, the rest are downloaded during installation.
rahulm
Wed Jan 17, 2018 5:30 am
to be more specific i have installed Noobs_lite_v2_4 but cannot see iot core.
procount
Wed Jan 17, 2018 1:36 pm
Which RPi midel do you have?
Is it connected to the internet when running NOOBS?
Which OSes can you see?
koenVdB
Tue Apr 03, 2018 7:19 pm
I have a Pi 3 model B+ and want to install the windows 10 iot core.
when i boot from noobs i only can see the options:
- Raspbian
- LibreELEC_RPi2
- Raspbian Lite
- Dat Partition
- OSMC_Pi2
but i would like to have the Windows 10 iot core. i already created another micro sd card from the windows iot dashboard but when i put that card into the pi it is not booting.
Can someone help me how i can install the windows 10 iot core on my raspberry pi 3 model B+
thanks
mahjongg
Tue Apr 03, 2018 7:35 pm
Not possible!
Microsoft has not yet updated its Win 10 IOT for the RPI 3B+.
inquire on the Microsoft forum for a timescale for the update, could be months.
idergi
Tue Apr 17, 2018 10:40 am
I've found two forum threads at Microsoft about the issue:
Raspberry Pi 3B+
https://social.msdn.microsoft.com/Forum ... WindowsIoT
and
Raspberry Pi 3 B+ Windows IOT Core Boot Work Around
schlaflosin030
Sat Jun 16, 2018 6:09 am
- Raspbian
- LibreELEC_RPi2
- Raspbian Lite
- Dat Partition
- OSMC_Pi2
Hi
I have to 100% the same problem but i will get a MultiBOOT SD with
Raspbian, Windows10 and a Dat Partition. Have a 32GB SD in use.
Hope for Help
Sat Jun 16, 2018 12:35 pm
Since Win10IoT wasn't ready when the 3B+ was launched you're going to have to wait for NOOBS 2.9 (or later) before you'll get it as a "multiboot" component. I'm not sure whether Mr Procount has it in his latest version of PINN yet. At the current time the only option (if it's not in PINN) is a stand-alone SDCard built with the Microsoft beta 3B+ ready version.
procount
Sat Jun 16, 2018 5:14 pm
I don't think it will need a point release of NOOBS or PINN to have this. But we are waiting for a NOOBS-formatted installation of a version of WinIoT that works with the 3B+ from Microsoft. Once we have that it should be available through both NOOBS and PINN. The current version only works with the pi2 and pi3.
TheQWERTYCoder
Please upgrade NOOBS.
Sat Dec 15, 2018 6:04 pm
Windows 10 IoT Core is not available in older versions of NOOBS.
Please upgrade to NOOBS v3.0 to have the following options:
Raspbian Full - Raspbian Desktop with recommended programs and features.
LibreELEC - Kodi Media Center distro.
Raspbian - Raspbian Desktop, same as Raspbian Full, but with fewer features.
Raspbian Lite - Raspbian without the desktop environment.
Lakka - Retro emulator powered by RetroArch.
Extra 512MB Partition - ext4 partition for storing things.
OSMC - Modern Kodi Media Center distro.
recalboxOS - Retro emulator powered by emulationStation.
Screenly OSE - Digital signage platform for the RPi.
RISC OS - Compact yet powerful OS.
Windows 10 IoT Core - IoT Core for building apps and other projects.
ThinLinXOS - 30-day free trial of Debian-based ThinLinXOS.
procount
Sat Dec 15, 2018 6:30 pm
When you install Win10 IoT you are given the choice of the RTM version, or the Windows Insider version.
To use with the 3B+, you must select the Windows Insider version.
Neither version is compatible with the 3A+
code_exec
Sun Dec 16, 2018 6:06 am
I doubt the Pi 3A+ would be able to run Windows 10 IoT because it lacks the RAM.
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
