bcphysics
which version for an older v1 model B?
Sun May 07, 2017 7:32 pm
I have an older Raspberry Pi 1 model B and I tried putting a new raspbian os on it, but it runs poorly. I'm guessing that an older OS version would work better. I know where to find older versions but I don't know how far back to go, which version I should try first. I could do trial-and-error but I assume that others have traveled this path already.
thanks
Re: which version for an older v1 model B?
Sun May 07, 2017 7:34 pm
It won't be any better or worse, it'll just be 100% insecure.
If your old RPi isn't fast enough for your project replace it with a RPi3B.
pcmanbob
Sun May 07, 2017 8:16 pm
You have not said what you want to do with your pi, but if you don't need a desktop environment try using Jessie lite,
will even run reasonably fast on an original pi with 256 meg ram.
mikerr
Sun May 07, 2017 8:37 pm
If its the 256MB version, then memory is tight:
a) set memory split/GPU usage to 16MB
b) use a different browser than the now default chrome
alphanumeric
Tue May 09, 2017 7:27 pm
I have a couple of A+'s I run headless. Instead of running Jessie Lite, I just set them to boot to the command line interface instead of the desktop GUI. Works for me. They do boot up faster and my python file runs sooner. I just run sudo raspi-config if I need to toggle back to the desktop for some reason. Different strokes for different folks. ;)
bcphysics
Thu May 11, 2017 2:37 am
Thanks for the ideas and responses.
I want to build a small weatherstation. Originally I was going to use an Arduino but I thought I'd try the raspberry pi instead. Previously it was used for Kodi/osmc, but I just got a new rpi3.
I had to run the installation three times before the OS would even boot properly (having just downloaded the newest rasbian. Once running it would barely open a chromium browser. I assumed that it was the newer OS causing the problem. Maybe it was something else. I'll try again.
ghans
Thu May 11, 2017 4:38 am
I would not expect wonders. Chromium being sluggish on the first models is to be expeted.
ghans
Return to “Raspberry Pi OS”
