Sun May 07, 2017 6:25 pm
Hi.
So what do you actually what help with ?
No one is going to build your project for you, it down to you to find what hardware you want to use or at least to ask for help/suggestions on hardware, then its down to you to start programming , if you get stuck then ask a question about a particular problem.
Just asking for help with out having a problem will probably not get you much help at all.
