xcom
Downgrade php5
Sun Sep 23, 2012 4:07 pm
In the mist of doing a full blown upgrade my sdcard took a dump... :(
So I went and bought a new one and back in business...
The problem I have is that after restoring the install of gallery3 I am getting on my apache2 error logs:
child pid 21971 exit signal Segmentation fault (11)
Some research seems to indicate that is the version of php5 I am using "5.4.4-7" and that the best course of action is to upgrade and worst case scenario downgrade.
I try searching on the raspberry pi repos but only found the current "5.4.4-7" version. Any other place I can find an older version?
Thank You.
xcom
Re: Downgrade php5
Sun Sep 23, 2012 8:01 pm
Any body? :)
xcom
Re: Downgrade php5
Fri Sep 28, 2012 10:31 pm
bump
Dweeber
Re: Downgrade php5
Fri Sep 28, 2012 10:58 pm
What RPi Distro are you using and what versions are you at?
With regards to issues with PHP5 Are you referring to this bug report?
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=687064
Which then leads to:
http://gallery.menalto.com/node/107345
Dweeber A.K.A. Kevin...
My RPI Info Pages including Current Setup - http://rpi.tnet.com
xcom
Re: Downgrade php5
Sat Sep 29, 2012 2:14 am
I am using 2012-09-18-wheezy-raspbian.
And no is not the same. I am using gallery3. I get segfaults every time I try to go my site.
Thanks for the reply.
Dweeber
Re: Downgrade php5
Sat Sep 29, 2012 2:18 am
xcom wrote:And no is not the same. I am using gallery3. I get segfaults every time I try to go my site.
Okay.... so where are you getting that you need to down rev PHP5 to fix your problem.
xcom
Re: Downgrade php5
Sat Sep 29, 2012 2:50 pm
When I enable apache2 debug it spills out a bunch of php segfaults. I was told i could try to disable php5 modules but I only have one and that's php-mysql and is need it.
Dweeber
Re: Downgrade php5
Sat Sep 29, 2012 5:53 pm
Did you do any optimizations to the MySQL and apache configurations (adjust memory split) to make them play nicer in the very small environment that the Raspberry Pi has available?
vpspr
Re: Downgrade php5
Sat Mar 30, 2013 11:09 pm
Hello xcom ... were you able to fix this? ... I'm having same issue with gallery3 and seg faults.
Thx
