antonn
USB not working anymore - RPi 3
Tue May 02, 2017 5:49 pm
Whenever I connect any USB device it won't show itself when I execute lsusb. Even devices that used to work before.
lsusb
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
dmesg gives me a constant error of over-current
[  220.596929] usb 1-1-port2: over-current change
[  220.852896] usb 1-1-port2: over-current change
[  221.108927] usb 1-1-port2: over-current change
[  221.364921] usb 1-1-port2: over-current change
[  221.620900] usb 1-1-port2: over-current change
[  221.876922] usb 1-1-port2: over-current change
[  222.132898] usb 1-1-port2: over-current change
[  222.388899] usb 1-1-port2: over-current change
[  222.644918] usb 1-1-port2: over-current change
[  222.900902] usb 1-1-port2: over-current change
[  223.156899] usb 1-1-port2: over-current change
[  223.412899] usb 1-1-port2: over-current change
[  223.668923] usb 1-1-port2: over-current change
I've appended max_usb_current=1 already to the /boot/config.txt as recommended in some other fixes, but that changed nothing. I am using a 5V 2.1A PSU and powering my Pi by the micro-USB connection. Powering it straight on the 5V pins with 1.9A gives the same result.
Anyone has some possible solutions for this problem? How can I use my USB ports again? Is my Pi broken?
Thanks for the help...
Re: USB not working anymore - RPi 3
Tue May 02, 2017 5:51 pm
Do you mean dmesg gives a list of overcurrent warning?
antonn
Tue May 02, 2017 5:56 pm
jamesh wrote:Do you mean dmesg gives a list of overcurrent warning?
Oops indeed, my bad. Any idea about this issue?
antonn
Thu May 04, 2017 5:27 pm
Nobody?
dgordon42
Thu May 04, 2017 5:58 pm
Have a read of this thread.
Hope this helps,
Dave.
