karl101
Bluetooth not starting on boot?
Sat Apr 29, 2017 12:49 pm
Hello
I have compiled and installed the latest version of bluez (v5.44) from source code with this configuration: ./configure --enable-experimental --enable-library and can't get the service to start on boot. I try to enable it with:
$ sudo systemctl enable bluetooth
Created symlink from /etc/systemd/system/dbus-org.bluez.service to /lib/systemd/system/bluetooth.service.
Created symlink from /etc/systemd/system/bluetooth.target.wants/bluetooth.service to /lib/systemd/system/bluetooth.service.
but on reboot checking the service status it says no:
 $ sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
   Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled)
   Active: inactive (dead)
     Docs: man:bluetoothd(8)
if I start it manually it works fine:
$ sudo systemctl start bluetooth
   Active: active (running) since Sat 2017-04-29 13:44:45 BST; 8s ago
 Main PID: 1391 (bluetoothd)
   Status: "Running"
   CGroup: /system.slice/bluetooth.service
           └─1391 /usr/local/libexec/bluetooth/bluetoothd
Apr 29 13:44:45 raspberry bluetoothd[1391]: Bluetooth daemon 5.44
Apr 29 13:44:45 raspberry systemd[1]: Started Bluetooth service.
Apr 29 13:44:45 raspberry bluetoothd[1391]: Starting SDP server
Apr 29 13:44:46 raspberry bluetoothd[1391]: Bluetooth management interface 1.14 initialized
I can't see any errors in dmsg
$ dmesg | grep Bluetooth
[    6.208836] Bluetooth: Core ver 2.22
[    6.208986] Bluetooth: HCI device and connection manager initialized
[    6.209026] Bluetooth: HCI socket layer initialized
[    6.209049] Bluetooth: L2CAP socket layer initialized
[    6.209110] Bluetooth: SCO socket layer initialized
[  206.603329] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  206.603346] Bluetooth: BNEP filters: protocol multicast
[  206.603375] Bluetooth: BNEP socket layer initialized
Any ideas?
Karl.
Return to “Raspberry Pi OS”
