klintkrossa
imports 2 to 3
Thu Apr 27, 2017 10:15 pm
Is there a way that python3.X.X able to import any python import either a python2 or python3 import?
For you guru's can it be made?
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
scotty101
Re: imports 2 to 3
Fri Apr 28, 2017 8:43 am
Python modules that are written for Python2 won't work with Python3 unless you rewrite them (or someone else has rewritten it). There is no magic command.
klintkrossa
Re: imports 2 to 3
Fri Apr 28, 2017 4:03 pm
scotty101 wrote:Python modules that are written for Python2 won't work with Python3 unless you rewrite them (or someone else has rewritten it). There is no magic command.
I though so. Now there would be a python script.
kusti8
Re: imports 2 to 3
Fri Apr 28, 2017 6:32 pm
There is a script called 2to3 that can convert, but many simple scripts already have it done and complex ones are complicated to do.
paddyg
Re: imports 2 to 3
Fri Apr 28, 2017 10:56 pm
in pi3d we used the six module functions so the code gets converted 'on the fly' which means the same code runs with py2 or py3 (and pypy) However there is a small processing cost for doing this.
You *could* patch the 'wrong' path to dist packages using sys.path.insert(1,...) but some modules will almost certainly not work and it would end in a horrible mess.
Return to “Python”
