kabads
Just installed 2012-09-18 wheezy raspbian - md5sum prob
Sun Sep 23, 2012 8:55 am
I've downloaded this several times and can't get the md5sum to work - once I do it I always get
f28795ef7901ba00d13d8a5de004acf0 *2012-09-18-wheezy-raspbian.img
- the images boot, but I always have problems with apt-get update. I'm not sure what could be the problem here, as usually when I download other distros md5sum always works out for me - is there something wrong with the file on the server? Can anyone get a proper md5sum to check out on this file?
stevepdp
Re: Just installed 2012-09-18 wheezy raspbian - md5sum prob
Sun Sep 23, 2012 11:18 am
You shouldn't be testing it with md5sum, you should instead be running sha1sum.
Here's what you'll see with sha1sum:
stevepdp@glitch:~$ sha1sum 2012-09-18-wheezy-raspbian.zip
3bc788d447bc88feaae8382d61364eaba1088e78  2012-09-18-wheezy-raspbian.zip
Remember also that it's the zip you need to check, not the image file contained. The full instructions for checking images can be found here.
(edited for corrections)
kabads
Sun Sep 23, 2012 11:49 am
D'oh! Thanks - will check it now.
RogerRamJet
Fri Sep 28, 2012 7:07 pm
Glad I found this help. I was doing the same. Should have been the .zip file I compared it with not the image file.
Re-read it on the web site and there it was.
Lesson - must read the instructions twice or three times!
Tanks and best regards RRJ
Return to “Beginners”
