vvkozmenko
Raspberry Pi for traveling photography
Thu Apr 27, 2017 2:45 pm
I would like to use one of my Raspberry Pi for the traveling photography needs.
I plan to have a portable Raspberry Pi 3 with 3.5 inch screen setup. I need to be able to perform the following steps:
1. copy Olympus RAW (ORF) images from SD card to a USB backup drive
2. on the USB drive create JPEG copies of the backed up files (in a separate folder)
3. move JPEGs to the USB drive that can be connected to an iPhone or iPad
4. view JPEGs on an iPad
So, basically, I need to be able to backup ORF files from SD to USB, and convert ORF into JPEG.
I am trying to find an application that would be the best for ORF-to-JPEG batch conversion.
Any help or guidance is highly appreciated.
Thank you,
Val
lmarmisa
Re: Raspberry Pi for traveling photography
Thu Apr 27, 2017 3:58 pm
vvkozmenko
Thu Apr 27, 2017 4:54 pm
Thank you, Immarisa,
The link that you gave me was pretty interesting. Some of the Linux packages that they mention at DPReview are available for RP, and some are not. I will need to go through them and try them out.
Again, thank you for your response.
Val
olav216
Mon May 01, 2017 1:18 am
Say, that's an interesting idea to use Raspberry Pi to empty the cards with. I work with Canon cameras and RAW CR2s so my suggestion may not be directly helpful for you, but in experimenting, I was able to offload all of the images from my camera through gphoto2's CLI ('gphoto --get-all-files', for example. Apt-get it and man gphoto2 for more commands). Maybe with gphoto2, ufraw-batch, and cp/mv/rm commands, you could come up with a script that will do all you want it to do.
Return to “Beginners”
