Raspberry Pie Expert wanted !!
I am from an older generation of electronics hobbyists. I am familiar with solid state electronics such as Transistors, Capacitors, Transformers, chokes... etc. As well as assembling my own PC from off the shelf parts, but that is as far as things go.
I need a Raspberry Pie based controller for my Excess Solar Energy Battery charger. It needs to be able to monitor the current flow in the incoming mains supply for my home using a Hall Effect Transducer. Detecting either positive or negative flows and the value of that flow. This will provide data as to how much excess (unused within the home) Solar Power is being generated. Additionally a second sensor will be required to monitor the DC current flow to the batteries. As this can vary depending upon the state of charge.
Using data from these two sensors, the Raspberry Pie will need to be able to output very short low voltage dc control pulses to a solid state relay. These pulses should increase in frequency when more power is available and lower frequency when less power is available. The SSR relay will then send pulses of high current AC power to my smart battery charger which I have already designed to accept this type of input.
I am happy to pay for someone to assist me with this project Or if they would like to become part of the project for commercial purposes, I am willing to be partners.
Please call me on; 07779 615354
Rob
