ilman
Measuring distance using 2 ultrasonic
Sat Apr 15, 2017 5:07 am
hello, i am a newbe with raspi or python. so i have a project to measuring distance with two ultrasonic sensor. i've try with one sensor and it works. i try to write the script with two sensor and it's not work. i know the problem coming from my code. so i need a help to fix my problem please. what's wrong with my code. thanks before
this is script with one ultrasonic
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
TRIG = 23
ECHO = 24
print "Distance Measurement In Progress"
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
GPIO.output(TRIG, False)
print "Waiting For Sensor To Settle"
time.sleep(2)
GPIO.output(TRIG, True)
time.sleep(0.00001)
while GPIO.input(ECHO)==0:
  pulse_start = time.time()
while GPIO.input(ECHO)==1:
  pulse_end = time.time()
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * 17150
distance = round(distance, 2)
print "Distance:",distance,"cm"
GPIO.cleanup()
and this is an error script with two ultrasonic
import RPi.GPIO as GPIO #
Import GPIO library import time #Import time library
GPIO.setmode(GPIO.BCM) #Set GPIO pin numbering
GPIO.setwarnings(False)
 TRIG = 23 #Associate pin 23 to TRIG
ECHO = 24 #Associate pin 24 to ECHO
TRIG1 = 17
ECHO1 = 27
print "Distance measurement in progress"
GPIO.setup(TRIG,GPIO.OUT) #Set pin as GPIO out
GPIO.setup(ECHO,GPIO.IN) #Set pin as GPIO in
GPIO.setup(TRIG1,GPIO.OUT) #Set pin as GPIO out
GPIO.setup(ECHO1,GPIO.IN) #Set pin as GPIO in
while True:
GPIO.output(TRIG, False) #Set TRIG as LOW
print "Waitng For Sensor To Settle"
time.sleep(2) #Delay of 2 seconds
GPIO.output(TRIG, True) #Set TRIG as HIGH
time.sleep(0.00001) #Delay of 0.00001 seconds
while GPIO.input(ECHO)==0: #Check whether the ECHO is LOW
pulse_start = time.time() #Saves the last known time of LOW pulse
while GPIO.input(ECHO)==1: #Check whether the ECHO is HIGH
pulse_end = time.time() #Saves the last known time of HIGH pulse
pulse_duration = pulse_end - pulse_start #Get pulse duration to a variable
distance = pulse_duration * 17160 + 1.1 #Multiply pulse duration by 17150 to get distance
distance = round(distance, 2) #Round to two decimal points
while True:
GPIO.output(TRIG1, False) #Set TRIG as LOW
GPIO.output(TRIG1, True) #Set TRIG as HIGH
while GPIO.input(ECHO1)==0: #Check whether the ECHO is LOW
pulse_start1 = time.time() #Saves the last known time of LOW pulse
 while GPIO.input(ECHO1)==1: #Check whether the ECHO is HIGH
pulse_end1 = time.time() #Saves the last known time of HIGH pulse
pulse_duration1 = pulse_end1 - pulse_start1 #Get pulse duration to a variable
distance1 = pulse_duration1 * 17160 + 1.1 #Multiply pulse duration by 17150 to get distance
distance1 = round1(distance, 2) #Round to two decimal points
print "Distance1:",distance - 0.5,"cm","Distance2:", distance1 - 0.5,"cm" #Print distance with 0.5 cm calibration
joan
Re: Measuring distance using 2 ultrasonic
Sat Apr 15, 2017 8:31 am
I can't help with that code.
When you get it working you could compare it with my code for a similar problem. See my answer at https://raspberrypi.stackexchange.com/q ... 0300#60300
Gavinmc42
Sat Apr 15, 2017 10:50 am
Two
 while true:
Had a quick look, obvious white space issues but that could be just be a cut paste bug.
Don't think it will get to second while true loop because it will stay in the first while loop.
I'm dancing on Rainbows.
ilman
Sat Apr 15, 2017 3:23 pm
Gavinmc42 wrote:Two
 while true:
so what should i do? can you help me to get this code work? i really appreciate your answer, i'm a novice in this case
Burngate
Sat Apr 15, 2017 5:42 pm
It looks to me as though the second script is more-or-less a copy of the first, but the "more-or-less" is where your problems start. You didn't manage to copy it precisely.
Python uses white spaces as controls, so you have to get them exactly right, not just more-or-less right.
Go through the second script, correcting them.
So line 6 has a space at the beginning that may confuse Python.
And when Python reaches the "while true" statement, it will continue to obey all the statements following it that are indented - but there aren't any! - so it will continue doing nothing for the rest of eternity?
