PokeEngineer
OneShot on the Raspberry Pi 2 & 3
Wed Apr 12, 2017 10:28 pm
After a couple of days working on this, I have managed to get OneShot (the Steam version) working full speed on the Raspberry Pi using the experimental OpenGL driver. :D
*DISCLAIMER*: I have only tested this on a Raspberry Pi 3, so this might be a little slower on a Raspberry Pi 2.
Step 1: Install needed packages:
- Update repository list
sudo apt-get update
- Install dependencies
sudo apt-get -y install libsdl2-dev libsdl2-ttf-dev libsdl2-image-dev libvorbis-dev libboost-dev libboost-program-options-dev qt5-default libsigc++-2.0-dev libbison-dev libopenal-dev libpixman-1-dev autoconf mercurial cmake libtool imagemagick libxcb-icccm4-dev libxcb-ewmh-dev xcb libxcb-image0-dev libxcb-shape0-dev libxcb-util0-dev
- Clone PhysicsFS
hg clone https://hg.icculus.org/icculus/physfs/
- cd into the directory
- Download my patch
wget https://raw.githubusercontent.com/PokeEngineer/OneShot-RPI/master/patch.diff
- Apply my patch
hg import patch.diff
- Run CMake
cmake .
- Make the project
make
- Install the project
sudo make install
- cd out of the directory
- Clone this fork of SDL_sound
git clone https://github.com/Ancurio/SDL_sound.git
- Run ./bootstrap
./bootstrap
- Configure the Makefile
./configure
- Make the project
make
sudo make install
Now, cd out of the directory for the next step.
Step 2: Use my script that will handle stuff from here on out:
- Clone the script repository
git clone https://github.com/PokeEngineer/OneShot-RPI.git
- Run the script
./install.sh
Once the above is finished, cd out of the directory and now you can delete the folders, physfs, SDL_sound, and OneShot-RPI.
Step 3: Copy the OneShot data:
Next, copy the folders, Audio, Data, Fonts, Graphics, Wallpaper, and the files, CREDITS.txt and README.txt, from your OneShot Steam folder to ~/OneShot.
Step 4: Enable the OpenGL driver:
- Open Raspi-Config
sudo raspi-config
Go to Advanced Options > GL Driver > GL (Full KMS) > Ok
And now, select Finish > Yes to reboot
Step 5: Play!:
- cd into the OneShot folder in ~/
And finally type
./oneshot
to launch OneShot and
./journal
to launch the OneShot Journal.
Be happy! Take a BYTE out of life!
(Also, a proud owner of 1 RPI B+, 1 RPI Zero, and 1 RPI 3)
:D
Check out my GitHub account: https://github.com/PokeEngineer
DatKiko
Re: OneShot on the Raspberry Pi 2 & 3
Fri Apr 27, 2018 7:23 pm
When I try to install your patch, it says Error: 404 not found :/
PokeEngineer
Sat Apr 28, 2018 12:17 am
Hey @DatKiko, I will get to your issue when I can, my PC is on the fritz right now, and I'm a bit busy.
:D
DatKiko
Sat Apr 28, 2018 1:21 pm
Im sorry, I was typing it out wrong, and i succesfully downloaded it
But my issue is that when I hg import patch.diff, i says "no repoitory found"
DatKiko
Sat Apr 28, 2018 1:23 pm
Also I can clearly see it on the pi/home in the folder, so is there something im missing?
B.Goode
Sat Apr 28, 2018 1:37 pm
If you have followed the instructions accurately patch.diff should have been downloaded to the directory ~/physfs, and that directory should be your Current Working Directory.
DatKiko
Sat Apr 28, 2018 3:07 pm
I tried to do it once again, but with no success, so I reinstalled the whole raspbian and followed the guide again, but with no success again, the atch was still where it was before, in the home/pi folder. How can I fix this issue?
B.Goode
Sat Apr 28, 2018 3:32 pm
Maybe the instructions are not quite precise enough, and rely on a little basic understanding of Linux file management.
Expanding a little - original text like this
- Clone PhysicsFS
[You have probably already done this. If successful there should be a new directory physfs in your home directory.]
[ This might be the step you are missing. It is shorthand for cd into the new directory created in the previous step.]
cd physfs
- Download my patch
[ You should now have patch.diff in the directory ~/physfs ]
- Apply my patch
B.Goode
Sat Apr 28, 2018 4:30 pm
Unfortunately, you will probably find that the application of the patch will fail:
[email protected]:~/physfs $ hg import patch.diff
applying patch.diff
unable to find 'src/archiver_zip.c' for patching
(use '--prefix' to apply patch relative to the current directory)
1 out of 1 hunks FAILED -- saving rejects to file src/archiver_zip.c.rej
abort: patch failed to apply
The patch appears to be incompatible with the source tree cloned from the icculus.org repository - you will need seek advice from @pokengineer about this.
(I can see a file in the src directory with a similar name and would be tempted to edit that file by hand to make the changes in the patch file, but that is a "hacker's" solution... )
PokeEngineer
Sat Apr 28, 2018 4:34 pm
Seems like the repo was updated and the patch broke. I will see if I can update the patch when I have time.
:D
PokeEngineer
Sat Apr 28, 2018 4:59 pm
@DatKiko, It's
cd ..
:D
B.Goode
Sat Apr 28, 2018 5:23 pm
@DatKiko, It's
cd ..
I don't want to argue with you in public, because it is your tutorial, but I thought I had demonstrated that it was necessary to cd into the cloned directory tree? (Because hg import only makes sense in a directory that is under hg version control.)
PokeEngineer
Sat Apr 28, 2018 5:48 pm
Oh, I was just helping out @DatKiko because he asked in a post (which is now gone, for some reason) how to cd out of a directory.
:D
DatKiko
Thu May 03, 2018 4:27 pm
I deleted the post in which i was asking about the "cd" command, because I didnt read the "cd out of the directory", and when I posted the post, I saw the point when I was reading the guide again. So I am very sorry.
Return to “Gaming”
