Hi. I've been following discussions about monitors and I bought an HDMI to SVGA converter (Neewer Black HDMI Input To VGA Adapter Converter For PC Laptop) no problem when the initialization program ran and then I could use RasPi. After switching off and on again monitor will not work; is this likely to be a fault the converter- not sure how I can test an HDMI output to the monitor; or did the initialization run contain some code which I need to write into config.sys ?
Like everyone I want to use old bits of gear rather than buying new tv just for RasPi.
Chris
