balonchiks
rPi stucks on boot before entering gui
Tue Apr 11, 2017 8:45 am
Hi all!
I have a raspberry pi zero wireless with the noobz raspbian installed there with no major modifications. Yesterday i was trying to setup a Hyperion software on my pi to control the led strip on the back of my TV, however, the led strip was not responding and was not working. I decided that i would restart my pi just in case, and there you go: my pi does not boot anymore. Or shall i say it boots up to the point where GUI should be displayed, and it stucks there with the green led on the pi stays lit all the time. it even starts up SSH server for around 4-5 seconds as i'm able to enter login, but not the password.
Here's a video of the process - https://www.youtube.com/watch?v=SAVG6-f9zb8
As you can see, it starts up normally, but at the end, when you see a blinking cursor - it just hangs (sometimes with a purple artifacts on the screen, sometimes not)
To make sure the pi itself is OK this morning i installed noobz on a different sd card - everything went well, pi is working flawlessly, so it must be something with my installation. I suspect that installation of Hyperion might affected or changed something in my that broke the whole system...
So my question is - how do i fix that? My knowledge only allows me to start the recovery (and edit boot config txt a bit, without any luck) or install noobz once again - but that is not an option as this will destroy all my files and programs.
What are the possible fixes/solutions to my problem?
Thank you all in advance!
balonchiks
Re: rPi stucks on boot before entering gui
Tue Apr 11, 2017 10:55 am
managed to fix it myself. the issue was hyperion starting as a system service and halting everything. removing hyperion.service from system.d fixed everything.
