ritika27
raspberry pi - using laptop as HDMI
Mon Apr 10, 2017 6:05 am
I have loaded noobs software on sd card and connected hdmi on laptop and also pluged power button on. But still i cannot see raspberry pi 3 boot up on my laptop screen.
I am using windows 10 . what could the problem be... plz help
texy
Re: raspberry pi - using laptop as HDMI
Mon Apr 10, 2017 7:08 am
Hi and welcome to the forum.
So - you are trying to use your laptops HDMI connector as an Input? That wont work - both the Pi and the laptops HDMI port are Output ports.
You'll need to connect the Pi to a monitor if you want to use the HDMI port.
Texy
ritika27
Mon Apr 10, 2017 8:53 am
so i cannot use my laptop as a display for my pi 3 board ?
Mon Apr 10, 2017 8:59 am
ritika27 wrote:so i cannot use my laptop as a display for my pi 3 board ?
Welcome, as above stated clearly the HDMi on the Laptop is OUTPUT ONLY.
If you have installed Raspbian Jessie with Pixel you can use RealVNC to remote access from the Windows 10 Laptop:
https://www.raspberrypi.org/documentati ... ccess/vnc/
RPi 4B 4GB (SSD Boot)..
i486
Mon Apr 10, 2017 9:08 am
You cannot use it directly - only with remote access. Probably the most simple solution is to use TV as Pi display.
