Sun Apr 09, 2017 2:42 pm
waldmattis wrote:
The download page says:
"The NOOBS files contained in the ZIP archive are over 4GB in size,
which means that these archives use features which are not supported
by older unzip tools on some platforms"
Is this incorrect?
As I wrote, after unZIPing I only got 1.1GB uncompressed folder size.
Just for clarification - what tool and under what O.S. did you use to unzip NOOBS? (eg. for Windows 7zip is recommended)
Note also that the "im(a)g(e)" file(s) that NOOBS uses to install the O.S.('s) are also compressed (IIRC, NOOBS itself uncompresses it/them during the install process - and, at that point, they/it will become >4Gb)**
Trev.
** ie. NOOBS effectively does what I did here "manually" (see link below) for a Raspbian image file (but the NOOBS compressed image is compressed using a different method):
http://www.cpmspectrepi.uk/raspberry_pi ... Win10.html
